[GRASS5] [bug #839] (grass) g.mremove
this bug's URL: http://intevation.de/rt/webrt?serial_num=839
now way to restrict mapset...
e.g. rast=* will also match PERMANENT layers
--- Headers Follow ---
From neteler@itc.it Fri Nov 16 16:33:10 2001
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
  by lists.intevation.de (Postfix) with ESMTP id 5EEE9139CC
  for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:33:10 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
  by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFX9f23446
  for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:33:09 +0100
Received: from artemide.itc.it (artemide [10.0.10.10])
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFX8d19172
  for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:33:08 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
  by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFX8E18167
Received: (from neteler@localhost)
  by thuille.itc.it. (8.11.6/8.11.2) id fAGFX7Y29550
  for grass-bugs@intevation.de; Fri, 16 Nov 2001 16:33:07 +0100
Resent-Message-Id: <200111161533.fAGFX7Y29550@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
  by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMdE16828
  for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:46 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
  by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMZd18954
  for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:36 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
  id 2D4C016DF; Fri, 16 Nov 2001 22:41:27 +0800 (CST)
To: neteler@itc.it
Subject: g.mremove
Message-Id: <20011116144127.2D4C016DF@localhost.localdomain>
Date: Fri, 16 Nov 2001 22:41:27 +0800 (CST)
Resent-From: neteler@itc.it
Resent-Date: Fri, 16 Nov 2001 16:33:07 +0100
Resent-To: grass-bugs@intevation.de
