this bug's URL: http://intevation.de/rt/webrt?serial_num=840
on the man page of r.reclass is shows that one can also manipulate the
"no data" areas... [but they are 0 there and NULL for me using this
"leics roads" example] anyway, it would be good to allow the user to
change "no data=NULL" to other values from this same screen.
s$ g.version
GRASS 5.0.0pre1 (May 2001)
ENTER NEW CATEGORY NUMBERS FOR THESE CATEGORIES
OLD CATEGORY NAME OLD NEW
NUM NUM
Motorway . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 0____
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 0____
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 0____
Proposed . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 0____
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 0____
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 0____
'A' roads . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 0____
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 0____
'B' roads . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 0____
'C' roads . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 0____
Next category: end__ (3 thru 12)
AFTER COMPLETING ALL ANSWERS, HIT <ESC><ENTER> TO CONTINUE
(OR <Ctrl-C> TO CANCEL)
http://www.geocities.com/jidanni/ Tel+886-4-25854780 ¿n¤¦¥§
--- Headers Follow ---
From neteler@itc.it Fri Nov 16 16:33:43 2001
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id 3A853139CC
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:33:43 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFXgf23471
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:33:42 +0100
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFXfd19184
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:33:41 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFXeE18203
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAGFXe129555
for grass-bugs@intevation.de; Fri, 16 Nov 2001 16:33:40 +0100
Resent-Message-Id: <200111161533.fAGFXe129555@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMME16727
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:22 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMHd18877
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:19 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
id 226CB16D1; Fri, 16 Nov 2001 13:53:22 +0800 (CST)
To: Markus Neteler <neteler@itc.it>
Subject: Re: r.reclass NULL
Reply-To: jidanni@yahoo.com.tw
Date: Fri, 16 Nov 2001 13:53:20 +0800 01:00:00 +0000 (GMT)
In-Reply-To: <20011015171336.X29694@itc.it>
Message-ID: <m2k7wr45yn.fsf_-_@Mdan.jacobson.tw>
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
MIME-Version: 1.0
Content-Type: text/plain; charset=cn-big5
Content-Transfer-Encoding: 8bit
X-MIME-Autoconverted: from quoted-printable to 8bit by artemide.itc.it id fAGFMME16727
Resent-From: neteler@itc.it
Resent-Date: Fri, 16 Nov 2001 16:33:40 +0100
Resent-To: grass-bugs@intevation.de
