this bug's URL: http://intevation.de/rt/webrt?serial_num=844
$ r.contour
OPTION: Name of an existing raster map
key: input
required: YES
Enter the name of an existing raster file
Enter 'list' for a list of existing raster files
Hit RETURN to cancel request
topo
<topo>
OPTION: List of contour levels
key: levels
required: NO
multiple: YES
enter option >
OPTION: Minimum contour level
key: minlevel
required: NO <<<<<<<<<<<<<<<<<<<<<<see, it says NO
enter option >
OPTION: Maximum contour level
key: maxlevel
required: NO
enter option >
OPTION: Increment between contour levels
key: step
required: NO
enter option >
OPTION: Minimum number of points for a contour line (0 -> no limit)
key: cut
default: 0
required: NO
enter option >
OPTION: Name of output vector file
key: output
required: YES
enter option > contour
You have chosen:
output=contour
Is this correct? (y/n) [y] y
FLAG: Set the following flag?
Suppress progress report & min/max information?(y/n) [n]
Suppress single crossing error messages?(y/n) [n]
Reading data.
Percent complete: 100%
FPRange of data: min = 40.000000 max = 278.000000
ERROR: Minimum parameters not set. <<<<<<<<<<<<<<<<<but it said it wasn't required
Either a step or a list of levels must be specified
ERROR:
1grass$
--- Headers Follow ---
From neteler@itc.it Fri Nov 16 16:39:49 2001
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id 0BA15139CC
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:39:49 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFdmf23959
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:39:48 +0100
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFdld19390
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:39:47 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFdiE19198
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:39:45 +0100 (MET)
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAGFdiv29631
for grass-bugs@intevation.de; Fri, 16 Nov 2001 16:39:44 +0100
Resent-Message-Id: <200111161539.fAGFdiv29631@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMXE16802
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:39 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMQd18917
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:27 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
id B407316DE; Fri, 16 Nov 2001 22:27:27 +0800 (CST)
To: Markus Neteler <neteler@itc.it>
Subject: cheated by r.contour
Reply-To: jidanni@yahoo.com.tw
Date: Fri, 16 Nov 2001 22:27:26 +0800 01:00:00 +0000 (GMT)
Message-ID: <m2elmy23ld.fsf@Mdan.jacobson.tw>
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Resent-From: neteler@itc.it
Resent-Date: Fri, 16 Nov 2001 16:39:44 +0100
Resent-To: grass-bugs@intevation.de
