this bug's URL: http://intevation.de/rt/webrt?serial_num=847
d.grid assumes that one wants to draw square grids.
I want to draw 800 x 500 grids
--- Headers Follow ---
From neteler@itc.it Fri Nov 16 16:40:22 2001
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id 8FB21139CC
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:22 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFeMf23996
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFeKd19448
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:20 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFeEE19331
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:17 +0100 (MET)
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAGFeDY29646
for grass-bugs@intevation.de; Fri, 16 Nov 2001 16:40:13 +0100
Resent-Message-Id: <200111161540.fAGFeDY29646@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMTE16769
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:32 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMPd18909
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:25 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
id 26BE016DD; Fri, 16 Nov 2001 22:16:46 +0800 (CST)
To: neteler@itc.it
Subject: d.grid
Message-Id: <20011116141646.26BE016DD@localhost.localdomain>
Date: Fri, 16 Nov 2001 22:16:46 +0800 (CST)
Resent-From: neteler@itc.it
Resent-Date: Fri, 16 Nov 2001 16:40:13 +0100
Resent-To: grass-bugs@intevation.de
