this bug's URL: http://intevation.de/rt/webrt?serial_num=848
You should have a standard: X then Y:
$ v.dump map=vect_sites|grep mark
mark at: E 447725.00 N 319975.00
$ v.area map=vect_sites
Point at cross hairs: 319874.37 (N) 447779.52 (E)
Area centroid: 319975.00 (N) 447725.00 (E)
so fix v.area to print E before N
--- Headers Follow ---
From neteler@itc.it Fri Nov 16 16:40:32 2001
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id EFE4D139CC
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:27 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFeRf24002
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFePd19452
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:25 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFeME19377
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:23 +0100 (MET)
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAGFeL129651
for grass-bugs@intevation.de; Fri, 16 Nov 2001 16:40:21 +0100
Resent-Message-Id: <200111161540.fAGFeL129651@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMUE16779
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:35 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMPd18911
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:26 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
id EF38E16D8; Fri, 16 Nov 2001 19:45:42 +0800 (CST)
To: Markus Neteler <neteler@itc.it>
Subject: N vs. E first
Reply-To: jidanni@yahoo.com.tw
Date: Fri, 16 Nov 2001 19:45:41 +0800 01:00:00 +0000 (GMT)
Message-ID: <m2lmh72b2y.fsf@Mdan.jacobson.tw>
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Resent-From: neteler@itc.it
Resent-Date: Fri, 16 Nov 2001 16:40:21 +0100
Resent-To: grass-bugs@intevation.de
