this bug's URL: http://intevation.de/rt/webrt?serial_num=849
$ v.support map=vect_sites option=build
PNT_TO_AREA failed: (447825.000000, 318525.000000) (Category 1)
The command apparently suceeded, but I think the man page should
explain why one would get this message and if it is important or not.
http://www.geocities.com/jidanni/ Tel+886-4-25854780 ¿n¤¦¥§
--- Headers Follow ---
From neteler@itc.it Fri Nov 16 16:40:32 2001
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by lists.intevation.de (Postfix) with ESMTP id 0403F13A03
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:31 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFeVf24017
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFeTd19456
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:29 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFeQE19409
for <grass-bugs@intevation.de>; Fri, 16 Nov 2001 16:40:27 +0100 (MET)
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id fAGFeQH29656
for grass-bugs@intevation.de; Fri, 16 Nov 2001 16:40:26 +0100
Resent-Message-Id: <200111161540.fAGFeQH29656@thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMWE16796
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:37 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMQd18918
for <neteler@itc.it>; Fri, 16 Nov 2001 16:22:27 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
id 25C8216D5; Fri, 16 Nov 2001 19:11:47 +0800 (CST)
To: Markus Neteler <neteler@itc.it>
Subject: v.support: PNT_TO_AREA scary message
Reply-To: jidanni@yahoo.com.tw
Date: Fri, 16 Nov 2001 19:11:45 +0800 01:00:00 +0000 (GMT)
Message-ID: <m2wv0r2cni.fsf@Mdan.jacobson.tw>
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
MIME-Version: 1.0
Content-Type: text/plain; charset=cn-big5
Content-Transfer-Encoding: 8bit
X-MIME-Autoconverted: from quoted-printable to 8bit by artemide.itc.it id fAGFMWE16796
Resent-From: neteler@itc.it
Resent-Date: Fri, 16 Nov 2001 16:40:26 +0100
Resent-To: grass-bugs@intevation.de
