this bug's URL: http://intevation.de/rt/webrt?serial_num=867
Subject: v.out.sdts crashes
it seems that v.out.sdts just crashes. Does anyone have a
better experience? I having trying to export the "roads" map
from Spearfish just to see if it is working.
On Tue, 11 Dec 2001 02:26:58 +0100 (CET), Request Tracker <grass-bugs@intevation.de> wrote:
It didn't crash on me, but...
1) It is outdated in it's handling of projections/datums.
It only supports lat/lon or UTM and only checks ellipsoid,
not datum.
2) It really requires the associated metadata routines to be
functional in order to produce "correct" output.
But, I was able to successfully export and reimport data with it...
Eric G. Miller <egm2@jps.net>
