[GRASS5] [bug #874] (grass) v.extract bug with file parameter
this bug's URL: http://intevation.de/rt/webrt?serial_num=874
Subject: v.extract bug with file parameter
unfortunately the file parameter of v.extract is not functional.
Please try with Spearfish dataset:
cat fields.extr
C. Mitchell#1
C. Mitchell#2
C. Mitchell#3
C. Mitchell#4
C. Mitchell#5
v.extract -n fields type=area out=fields.mitchell new=0 file=fields.extr
The result is an empty file. Using the "list" parameter the module
runs well.
Thanks for a fix :slight_smile:
