[GRASS5] [bug #876] (grass) v.support option=edit permissions bug
this bug's URL: http://intevation.de/rt/webrt?serial_num=876
Subject: v.support option=edit permissions bug
Platform: Solaris 8/SPARC
Xwindows version: Sun X11R6.4
Xwindows manager: dtwm/CDE
grass downloaded at: CVS Server, Germany
grass binary for platform: I compiled the sources myself
grass sources source: yes, I am using the latest GRASS from CVS
c compiler name: gcc
does not correctly recognize map=map@PERMANENT.
v.supprot should not start in interactive mode if there is no write permission to the mapset. But it does.
e. g. in active mapset andreas:
v.support option=edit map=roads@PERMANENT
after editing:
G__open(w): xmapset (PERMANENT) != G_mapset() (andreas)
Category file for [roads@PERMANENT] updated
(but it is really not updated, the change is lost!)
There are IMHO some other minor inconsistencies with v.support option=edit and v.support option=build.
Andreas
On Mon, 17 Dec 2001 00:34:09 +0100 (CET), Request Tracker <grass-bugs@intevation.de> wrote:
after editing:
I put in some checks that the map is in the current mapset before
continuing. So, it should exit with an error now if the map is
not editable. v.support is pretty ugly the way it was constructed.
It probably wouldn't hurt to rewrite it (it's pretty short, since
it mostly just launches other programs to do the work).
Eric G. Miller <egm2@jps.net>
