Subject: Can't start monitor on latest cvs (19/12/2001)
Platform: Linux/Intel
Linux distro: RedHat
linux cpu: Intel (i486, i586, pentium ...)
Xwindows version: Xfree 4.0.x
Xwindows manager: KDE 2.x
TclTk version: tcl/tk 8.3
grass downloaded at: CVS Server, Germany
grass binary for platform: I compiled the sources myself
grass sources source: yes, I am using the latest GRASS from CVS
d.mon reports the following error:
d.mon start=x0
Could not execute monitor: No such file or directory
No socket to connect to for monitor <x0>
d.mon start=x0
It works here (at least 1 minute ago...).
Are you on the wrong CVS branch?
The main branch is not working, development is on the
"releasebranch_11_april_2001_5_0_0", check here for more details:
I see the correct branch in the CVS/Entries file, anyway I updated
again my cvs copy with
cvs update -r releasebranch_11_april_2001_5_0_0
cvs up -dP
as suggested on the GRASS web site, just to make sure I haven't
overlooked anything, and compiled again... same problem.
See also my configure problem in bug 882.
This evening I will check how it works at home on my Mandrake box.
Best regards
Andrea aime
Andreas Lange wrote:
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=880
> d.mon start=x0
I deleted the old install directory /usr/local/grass5, deleted
$HOME/.grassrc5, made configure (with the same problems reported in bug
802),
make, make install and the problem is still there...
can anyone with a RedHat 7.2 install try the same?
Sigh, it worked with my first install, when I checked out GRASS two days
ago...
Best regards
Andrea Aime
PS: is the any monitor related file that may haven't been deleted
while erasing /usr/local/grass5?
cvs up -dP
Best regards
Andrea aime
> Hi,
> > d.mon start=x0
> http://grass.itc.it/grasscvstags.html
> HTH,
> Andreas
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> url: http://mitglied.tripod.de/AndreasLange
> mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
> grass5 mailing list
> grass5@grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
grass5 mailing list
grass5@grass.itc.it http://grass.itc.it/mailman/listinfo/grass5
802),
ago...
Best regards
Andrea Aime
Andrea,
that's really strange. Please check following:
the d.mon socket files are stored in
/tmp/grass-$USER
do you have write permission there?
Just a guess,
> cvs up -dP
> Best regards
> Andrea aime
> > Hi,
> > > d.mon start=x0
> > HTH,
> > Andreas
> > _______________________________________________
> > grass5 mailing list
> > grass5@grass.itc.it
> grass5 mailing list
> grass5@grass.itc.it
grass5 mailing list
I can find the /tmp/grass-$USER and it has full permissions
for my user, but there are no files in it... d.mon raises
an error before creating these files... what does "Could not execute
monitor: No such file or directory" means?
Best regards
Andrea Aime
Markus Neteler wrote:
Andrea,
/tmp/grass-$USER
could you test if there is an executable file $GISBASE/driver/XDRIVER ?
If this is missing the driver is not built or installed.
Or look into the file $GISBASE/etc/monitorcap, there should be an entry
for each x monitor in the form:
x0:driver/XDRIVER:X-windows graphics display:/pathtograss/dev/fifo.1a
/pathtograss/dev/fifo.1b::any terminal
Did you use 'make install' to install grass? Do you run from the
dist.... directory?
There must be something obvious wrong, it still works over here...
What strikes me too:
I am able to do:
./configure --with-postgres-includes=/usr/include/pgsql,
no need to disable blas, lapack, motif, freetype.
Are you sure that you are using the latest sources?
Try rm conf* and update via cvs.
