this bug's URL: http://intevation.de/rt/webrt?serial_num=897
Subject: obviously bug in G_set_cats() function
while updating r.param.scale to FP I realized that G_set_cats() function
is not working for 0 values.
Try:
- r.slope.aspect / aspect map / prec=int
-> the aspect 0 degree is not labeled although coded in src'es
- r.param.scale:
-> feature map doesn't get "Planar" labeled. As a workaround
I increased all numbers by one (planar, ridge, saddle etc).
However, now compliance is gone.
Looking briefly into G_set_cats() function I cannot find the problem.
Sounds like a GRASS 4.x story?!
Thanks for someone looking into this..
