I am not familiar with DTED but try to follow the problem.
The tcltkgrass line is something like this:
m.dem.extract input=dted output=out blocksize=22 start=1 end=1999
right?
And the help tells me:
m.dem.extract help
m.dem.extract input=name [output=name] [blocksize=value] [start=value]
[end=value]
Parameters:
input Input device or file
output Output raster map (examine only if none specified)
blocksize Blocksize of tape data
default: 10240
start First file to look at
default: 1
end Last file to look at
default: 9999999
Now I cannot see anything with West here. Is it a module internal problem?
(I have currently no DTED data)
right?
You're looking at the wrong menu option. The original report said:
When trying to extract DTED files into binary raster using the option
under Misc->DEM/DTED->DTED Extraction, the resulting pop-up menu which
This runs "m.dted.extract".
You're looking at:
Misc->DEM/DTED->DEM Extraction
The error is obvious enough; the last line of
src/tcltkgrass/module/m.dted.extract should be changed from:
{entry north {North longitude of region to extract (ddd:mm:ss{E|W}):} 0 ""}
to:
{entry west {West longitude of region to extract (ddd:mm:ss{E|W}):} 0 ""}
> right?
You're looking at:
to:
