this bug's URL: http://intevation.de/rt/webrt?serial_num=922
Subject: NVIZ and tcl/tk AND Startup-script under Linux (SuSE 7.3)
Platform: Linux/Intel
Linux distro: SuSe
linux cpu: Intel (i486, i586, pentium ...)
Xwindows version: Xfree 4.0.x
Xwindows manager: KDE 2.x
TclTk version: tcl/tk 8.3
grass downloaded at: Trento site
grass binary for platform: Linux/Intel binaries
Two small glitches:
1. Installation was ok with the script, but nviz complained about not having access to libtk.so and libtcl.so, I had to link the most recent libtk8.3.so and libtcl8.3.so to the before mentioned files in /usr/lib (GRASS itself was not affected, only nviz).
2. I use a network-wide login on my machine which utilized YP which in turn needs a shell called "msh" as login-shell. msh is (at least here) a link to /bin/bash. Because msh itself is unknown to the ~grass5/etc/Init.sh-script, it fails to set the environment and the grass-console does not work properly (the tcl-surface is not affected).
I solved the problem by adding a msh-case in Init.sh which does the same as bash (ok this is a hack
Maybe these are problems on my side, but all other programs work well with this construction, except grass5, so maybe you wan't to change it.
Thanks in advance!
We should ensure that Linux binary distributions are correctly
labelled, e.g. "RedHat 6.2 i386 Linux", not just "Linux". A package
with as many dependencies as GRASS is unlikely to work fully on a
distribution which differs from the one on which it was compiled.
affected).
This is arguably an installation bug. The fix is to ensure that SHELL
gets set to something which programs will recognise, e.g. by adding
something like:
if [ "$SHELL" = /bin/msh ] ; then
SHELL=/bin/bash
export SHELL
fi
to /etc/profile. I suspect that GRASS isn't the only program which
does case matching on $SHELL.
OTOH, GRASS should work with unknown shells. The main case statement
has a default case; does anyone know what's wrong with it?
You don't need to duplicate the bash case; you can just use "|", e.g.
bash|msh)
