[GRASS5] [bug #927] (grass) r.mapcalc3 does not compile on solaris 8/SPARC
this bug's URL: http://intevation.de/rt/webrt?serial_num=927
Subject: r.mapcalc3 does not compile on solaris 8/SPARC
Platform: Solaris 8/SPARC
Xwindows version: XSun
Xwindows manager: dtwm
TclTk version: tcl/tk 8.3
grass downloaded at: CVS Server, Germany
grass binary for platform: I compiled the sources myself
grass sources source: yes, I am using the latest GRASS from CVS
c compiler name: gcc
bash-2.03$ gmake5 src/raster/r.mapcalc3
  SRC = /opt2/grass50/grass/src
  CMD = /opt2/grass50/grass/src/CMD
  UNUSED = /opt2/grass50/grass/unused
  HEADER = head.sparc-sun-solaris2.8
  ARCH = sparc-sun-solaris2.8
  GISBASE = /opt2/grass50/grass/dist.sparc-sun-solaris2.8
  VERSION = 5.0.0pre3 January 2002
/opt2/grass50/grass/src/raster/r.mapcalc3
  make -f OBJ.sparc-sun-solaris2.8/make.rules
gcc -I/opt2/grass50/grass/src/include -g -O2 -I/usr/local/include -c xabs.c -o OBJ.sparc-sun-solaris2.8/xabs.o
In file included from xabs.c:4:
expression.h:87: `single' redeclared as different kind of symbol
/usr/include/floatingpoint.h:62: previous declaration of `single'
make: *** [OBJ.sparc-sun-solaris2.8/xabs.o] Error 1
bash-2.03$ gcc -v
Reading specs from /opt/sfw/lib/gcc-lib/sparc-sun-solaris2.8/2.95.2/specs
gcc version 2.95.2 19991024 (release)
bash-2.03$
r.mapcalc3 does not compile. Is this ok that it is in the default compile list?
Andreas
OK, thanks for the info; I'll rename that function.
compile list?
That's the only way that platform-specific problems like this will be
discovered.
