[GRASS5] [bug #976] (grass) v.transform would not read that header of files
this bug's URL: http://intevation.de/rt/webrt?serial_num=976
Subject: v.transform would not read that header of files
Roger Miller /Carl Worth wrote
> > 10. v.out.ascii gave me a header with a blank line imbedded in it, and
> > v.transform would not read that header.
> As far as I used v.transform, it doesn't need a header. From
> http://grass.itc.it/gdp/html_grass5/html/v.transform.html
> "An example of the pointsfile file:
I just ran into the same bug. It's not in the pointsfile, but rather
that v.out.ascii makes a blanks line in the header of the generated
vector ascii file. Then, v.transform aborts when it encounters the
blank line.
I don't know which module is buggy here.
blank line.
I have changed v.transform to read/write binary vectors.
Roger, can you test it?
BTW: I know, that it seems, that bug is in v.out.ascii, but because I have
never had such problems with v.out.ascii, I was not searching for that.
I can look at it, if you send me location with example map causing problems
(blank rows).
Radim
