Radim wrote:
> Subject: v.transform would not read that header of files
> Roger Miller /Carl Worth wrote
> > > 10. v.out.ascii gave me a header with a blank line imbedded in
it, and
> > > v.transform would not read that header.
> > As far as I used v.transform, it doesn't need a header. From
> > http://grass.itc.it/gdp/html_grass5/html/v.transform.html
> > "An example of the pointsfile file:
> I just ran into the same bug. It's not in the pointsfile, but
rather
> that v.out.ascii makes a blanks line in the header of the generated
> vector ascii file. Then, v.transform aborts when it encounters the
> blank line.
> I don't know which module is buggy here.
I have changed v.transform to read/write binary vectors.
Roger, can you test it?
Thank's a lot Radim. I ran a test. The new v.transform read and wrote
the binary files correctly, but died on a segmentation fault after
writing the output file. Is it supposed to also transform the dig_atts
file? It did not.
BTW: I know, that it seems, that bug is in v.out.ascii, but because I
have
never had such problems with v.out.ascii, I was not searching for
that.
I can look at it, if you send me location with example map causing
problems
(blank rows).
I'll see if I can find that set again, or another that does the same
thing. Perhaps Carl can find the set that created the problem for him.
Roger Miller
Lee Wilson and Associates
file? It did not.
dig_att should be transformed, where it crashes? For me it prints:
Now transforming the vectors ...
'v.transform' has finished the transformation of the vectors.
'v.transform' has finished the transformation of the vector's attribute file.
Transformation is complete.
The code for transformation of attributes was not changed, and i cannot get
the segfault - i tested warious combinations of non existing files
/directories and incorect records in dig_att. So i don't know.
You could maybe 'strace v.transform' so that we know if dig_att was opened.
Radim
On Apr 3, rgrmill@rt66.com wrote:
> have
> that.
> problems
> > (blank rows).
I'll have to look to see if I can dig something up or reproduce this.
My recollection is that it was a map generated by v.in.dxf.
-Carl
