this bug's URL: http://intevation.de/rt/webrt?serial_num=998
Subject: Vask (curses) problems with KDE terminal
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: CVS
a long term problem on KDE is that in KDE terminal the carriage return (or whatever)
doesn't seem to work properly. The problem must be related to curses in the
VASK library.
It happens in all coordinate windows (g.region etc) as well as v.digit etc.
A screenshot (46kb) is here:
http://mpa.itc.it/markus/tmp/kde_term_problem.gif
Here, using "t" in Digitize menu to toggle the vector type, end up with
above result.
When entering the raster resolution in g.region (menu1), the second line is reached
at mid of the line, not at the beginning.
I think that quite a few people are using KDE and KDE-term. It would be great to
have that problem fixed. In xterm everything is fine.
VASK library.
This sounds like a curses problem; in which case, GRASS can't do
anything about it.
> VASK library.
anything about it.
... if so: why does it work well for xterm? Or does curses behave
differently in xterm and KDE (or other) terminals?
> > VASK library.
> anything about it.
Yes and no.
In general[1], curses uses the value of $TERM to obtain a terminal
description from either termcap or terminfo[2]. It uses that
description to determine exactly which codes should be sent to the
terminal to redraw the screen.
If curses doesn't redraw the screen correctly, this indicates that the
terminfo (or termcap) entry corresponding to $TERM doesn't accurately
describe the behaviour of the terminal.
Note that terminal emulators (e.g. xterm) have historically been
problematic. Their behaviour is often highly configurable, but any
given terminal description corresponds to a specific configuration.
The usual way to support this is to provide multiple terminal
descriptions (look in e.g. /usr/share/terminfo/x for all of the
different xterm variants), corresponding to different option settings.
However, this only works if the user ensures that TERM is set to the
variant which matches the settings which are actually in use.
[1] Some systems allow a complete terminal description to be specified
via $TERMCAP.
[2] Depending upon how curses was compiled. Some older systems only
support termcap. Newer systems may either only use terminfo, or try
terminfo first, then try termcap if a terminfo entry can't be found.
