[GRASS5] Buggy Tcltk GUI 2
Greetings,
After I deleted tcltk 8.3.2, reinstalled tcltk 8.0.5, adjusted the header and recompiled the XDRIVER, the TclTk GUI is still buggy (see my last post).
The GUI seems to work until I start a monitor a which point the GUI stops working and does not redraw.
After I kill the monitor with X windows Twm, I get the message (because I killed it - no brainer here);
Error: xterm: fatal IO error
32 (Broken pipe) or
KillClent on X server "0:0"
Then the menu bar redraws and starts working again.
If I start a monitor with d.mon versus going to the menu Config->Monitors->Start->x0 it does not have this effect.
Hmmm, looks like maybe its time for me to reinstall my system and everything **again**; unless someone can *save* me. I guess if nothing else, I will try and recompile all of GRASS again first...
TIA,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
