Below is the result of your feedback form. It was submitted by
(david_finlayson@yahoo.com) on Wednesday, September 27, 2000 at 08:59:15
subject: Bugreport GRASS 5
platform: Linux/Intel
vendor: Debian
cputype: other
cputype_other: Cyrix i686
grassversion: Linux/Intel binaries
cvsyesno: -- select --
module: r.flow
bugreport: Issuing the command (-M switch is the problem):
r.flow -M elevin=fill aspin=dir flout=flowout_M dsout=density_M
I receive the following error:
Opening output files...done.
Allocating memory: elevation, segment, aspect, density, flowline header, e/w distances, quantization tolerances.
Reading input files: elevation, aspect.
Precomputing: tangents, e/w distances, quantization tolerances, re-oriented aspects.
Working...done.
Writing density file...ERROR: r.flow: cannot write segment file for density_M
r.flow seems to work OK with no switch and with the -m switch.
(grass5beta8)
compiler: -- select --
name: David Finlayson
REMOTE_HOST: cs313-49.spmodem.washington.edu
subject 'unsubscribe grass5'
