Rado (resamp.rst question) could you email me
the full comand you are running ? (is z_50 input or output?)
David (r.flow question) the -M flag has never been tested
so there indeed may be a bug - are you getting that even if
you run it with a small file? The problem may be also with the
segment library which is used e.g. in r.watershed for large
data sets. Is the -M option really needed? Is the aspect(dir) that
you are using derived from your DEM (fill) or is it different?
please answer directly to helena@gis.uiuc.edu
Helena
subject 'unsubscribe grass5'
