[GRASS5] bugs
Hi Paolo,
just saw this one:
"I would therefore ask thos who opended the bugs to please check if they still
hold true, and to remove those that have been solved (I am reasonably sure
many of them have been, but I cannot check e.g. those on MacOSX, etc.
I can give some help if needed.
Also, please note that several wishes may not apply anymore (especially after
3 or 4 years).
Please note that many bug reporters won't see above message to
this list.
The recommended method is to
- enter such a bug and add a "reply" (not a "comment" as this won't trigger
  a mail AFAIK), asking if the report is still valid, mentioning also
  the new 6.0.0beta2.
- wait a couple of days and close it if there was no response
  and the bug obviously outdated
It's not an exciting job, but quite important to get the impressive
number of meanwhile useless reports down.
Thanks for your help,
ok, I'll try to do that in the spare time (which time?).
All the best.
pc
At 18:41, venerdì 25 febbraio 2005, Markus Neteler has probably written:
Hi Paolo,
just saw this one:
still hold true, and to remove those that have been solved (I am reasonably
sure many of them have been, but I cannot check e.g. those on MacOSX, etc.
after 3 or 4 years).
this list.
  the new 6.0.0beta2.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Paolo Cavallini
cavallini@faunalia.it www.faunalia.it www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
Shouldn't we keep a list of known GRASS 5.4 bugs somewhere rather than
just forgetting about them? e.g. 5.4's v.digit "won't fix" bugs.
I think we need to have some sort of "confirmed", "unreproducable", or
"new" tag column for bugs, so we can separate out valid bugs from
misconfigured systems at least, giving a more realistic bug number.
We should not be closing bug reports just because there are a lot of bug
reports. Clean up the bug list, sure; as long as it is by actually
fixing bugs, and not just forgetting them!
Hamish
Agreed. In my view, the best solution is to make two bugs lists, one for 5.4
and one for 6.0. Then I volunteer to manage the 6.0 bugs, changing grass57 to
grass60 where appropriate. Bernhard, would this be possible?
BTW: where do I find the total number of bugs?
or, old and unreproducible bugs could be just squashed?
Right. But it is also necessary to get rid of the rubbish, otherwise we'll
scare new users away (and, in my view, what grass needs now is a larger user
base).
All the best.
pc
Paolo Cavallini
> than just forgetting about them? e.g. 5.4's v.digit "won't fix"
> bugs.
for 5.4 and one for 6.0.
We already have these 8 "Areas":
None
RCbug
bug
grass5.0
grass5.4
grass5.7
wish
wish5.7
Click on the /\ \/ arrows at the top of the bug list to sort by type.
Adding "Area" to "Queue Filter" options at bottom of main bug list might
help clear here.
These could be updated to:
None
RCbug
grass5.0
grass5.4
wish5.4
grass6
wish6
changing grass57 to grass60 where appropriate.
Isn't it always appropriate? They are the same thing.
I think the most important thing is to tag 5.0/5.4 only bugs to "area"
grass5.0 or grass5.4 or wish5.4 and set "priority" on 5.7+ bugs/wishes.
I don't know if there is a better way than to sort by area/type and count
by hand?
> or "new" tag column for bugs, so we can separate out valid bugs from
GRASS is a huge program with many rare bugs. One can never test all
platforms/setups, so you can never say unreproducible==mistaken report.
Even if it is a mistake, if one person did it, others might as well, and
the others in the future might figure it out & post a solution.
Just deleting the contributed user experience would be a big mistake,
IMO.
> bug reports. Clean up the bug list, sure; as long as it is by
> actually fixing bugs, and not just forgetting them!
we'll scare new users away (and, in my view, what grass needs now is
a larger user base).
The bug list is not a marketing tool! The bug list is not a marketing tool!
Make default "priority" and "area" tag queue filter limits if you want
trim.
If a new user finds an obscure bug, the best thing that can happen is
for them to see that someone else has already found it and a solution is
being worked on. This gives them confidence in the future trends. This
is one of the things that makes Debian work so well.
The bug list is so hard to find (for me) in the new website layout that
I don't think new users will look at it unless they really are looking
for it.
Number of open bugs is does not equate to package stability, in fact
with respect to open software, I think it is often an inverse relationship.
Once 6.0 is released and officially the "stable" version of GRASS I have
no problem with old 5.4 bugs being archived and removed from the bug
list, with a prominent link to the 5.4 BUGS file. Until that time...
Hamish
IMO.
That's generally right, but RT should not become a museum for
unresolved bugs of old GRASS versions.
Were would you like to see it?
I have added the area "grass6.0".
(Note beside people at Intevation Markus is also has admin rights
on the tracker.)
I can run stats directly on the database of our tracker,
otherwise counting manually is possible.
(I have a script half finished to mail them out on a regular basis.
However I am missing the time to complete it.)
> IMO.
I agree with both statements, but I think Hamish also agreed that
we need to clean out, what we can clean out.
Markus: Can empty the very old BUGS file from CVS then?
Can we completely empty it? I only want to make sure because it says:
You are maintaining it and I don't know if there is any bug in there
that is not in the RT. You would know best.
None
RCbug
bug
grass5.0
grass5.4
grass5.7
wish
wish5.7
None
RCbug
grass5.0
grass5.4
wish5.4
grass6
wish6
I have added wish6 and grass6 now.
I have kept grass5.7 and wish5.7 for now
so that we do not loose the information.
If everything is updated to grass6 and wish6 I can also remove that areas.
> > IMO.
Please do whatever is necessary.
I was maintaining it...
No idea. It's not unlikely that bugs are not present in RT. Someone
has to verify carefully (I have no time for that at the moment, also
I am no longer focusing on < 6.0).
I am checking single bugs before updating from 5.7 to 6.
I have a few requests/suggestions for the bug tracker:
- force area definition (users should not be able to file a bug without
associate category)
- split it into two queues: grass5x and grass6x (with different links from
grass web site); this would make it far easier to keep everything tidy, even
if at the expenses of some replication
- a flag "reported/confirmed" (as suggested) would be useful
- bugs might better be sorted by area+priority (from grass6 - priority 100 to
wish6 - priority 0) than by date
All the best.
pc
At 11:17, lunedì 28 febbraio 2005, Bernhard Reiter has probably written:
> None
> RCbug
> bug
> grass5.0
> grass5.4
> grass5.7
> wish
> wish5.7
> None
> RCbug
> grass5.0
> grass5.4
> wish5.4
> grass6
> wish6
Paolo Cavallini
Development page between:
- Compiling GRASS - Programmer's Manual -
add a Bugs section.
I can do that, just not today.
Hamish
without associate category)
this generally happens if the bug is submitted by email.
100 to wish6 - priority 0) than by date
I take it you mean by default? You can sort by priority (or whatever) by
clicking the up/down arrows at the column headings.
Newest-bugs-first helps to keep new bugs from getting lost.
Hamish
Note as I have written before I hope to be able to offer a better system.
The current RT is quite hard to adapt, thus I'd rather focus to work
on the future system.
associate category)
IMO not done easily.
Two queues can be done by the tracker, but I would suggest
to use two links from the butracking page to archive the same.
Not easily done, though I would suggest that a developer can just
add this as reply or comment to the tracker.
Not easily done, but you can sort by priority or filter by category.
Can you come up with the best links for the grass bugs page?
I was hoping that just by reading over the list you could mark
whatever you remember without careful checking.
This is the best effort approach.
add a Bugs section.
Please do, whenever you find the time.
Nevertheless I have committed a more reasonable explanation for
within the file now.
> links from grass web site); this would make it far easier to keep
> everything tidy, even if at the expenses of some replication
...but any raster/lib bugs will affect both versions. Better to clear
out all grass5.x-specific bugs from the bug tracker to the old
grass/BUGS file in CVS, add a prominent link to that on the GRASS 5.4
webpage & main bug reporting page, and go on from there?
a warning of which bug numbers will be archived & removed from the bug
tracker a few days before it happens would be nice (posted to this
list).
Sound like a plan?
Hamish
One question: are we going to keep the two grass versions side by side for
long? This of course makes bug tracking (among other things) much more
complicated, as our emails show.
All the best.
pc
At 03:33, mercoledì 02 marzo 2005, Hamish has probably written:
list).
Sound like a plan?
Hamish
Paolo Cavallini
