[GRASS5] C++ compilation
I fixed a bug (committed to CVS) in src/CMD/generic/gmake.sh where the new
support for .cc files caused a problem in modules that use lex/yacc: where
the .c file was not existing at the start of compilation and a .cc extension
was appended instead of .c (y.tab.c, lex.yy.c).
I don't think it looks right yet however as $(CC) is used to compile the
C++ files; probably it should be $(CPP) or something and configure should
check for a C++ compiler on the system?
Paul
Yes, the logic was the wrong way around; .c should be the default; .f
or .cc should only be used if the file actually exists.
It should be $(CXX); if $(CPP) is used, it normally refers to the C
preprocessor.
Also, it should be using $(CXXFLAGS) rather than $(CFLAGS), but the
rest of the configure mechanism needs to be adjusted accordingly.
Presently, configure.in calls AC_PROG_CC, which sets CFLAGS. Various
bits of configure.in then add things to CFLAGS, which then ends up in
the "head" file via:
  COMPILE_FLAGS = @CFLAGS@ @INCLUDE_DIRS@
In turn, this is referenced in src/CMD/generic/make.mid as:
  CFLAGS = -I$(INCLUDE_DIR) $(COMPILE_FLAGS) $(EXTRA_CFLAGS) $(USE_TERMIO)
Basically, configure.in needs to be changed so that most of the stuff
which is currently added to CFLAGS is either kept separate, so that it
can subsequently be added to CXXFLAGS, or is added to both CFLAGS and
CXXFLAGS.
and configure should check for a C++ compiler on the system?
AC_PROG_CXX does this.
