I have a floasting point EVI vegetation index map from MODIS and vector fields.
Now I need to calculate the average EVI value per field. To do so, I
- used v.to.rast to generate a raster fields map (each field one number)
- run r.average: segmentation fault because the underlying 'r.stats -anC '
segfaults
- run r.statistics: doesn't support FCELL/DCELL
If you want to test with Spearfish:
g.region -dp
r.average -c base=fields cover=elevation.10m output=elev.by.farm
WARNING: r.stats: cats for elevation.10m are either missing or have no
explicit labels. Using nsteps=255
-> doesn't sound convincing either
On a 64bit box I get a segfault from r.stats (called by r.average) after this
message:
gdb `which r.stats`
(gdb) r -anC input='areecampione125m,modis_vi250m20010712.250m_16_days_EVI' fs=space
Program received signal SIGSEGV, Segmentation fault.
0x0000000000402c02 in main (argc=1, argv=0x3535323d737065) at main.c:242
242 for (i = 0; name = option.cell->answers[i]; i++)
(gdb) bt full
#0 0x0000000000402c02 in main (argc=1, argv=0x3535323d737065) at main.c:242
msg = "r.stats: cats for modis_vi250m20010712.250m_16_days_EVI are either missing or have no explicit label"
fd = (int *) 0x5090a0
i = 2
name = 0xe8 <Address 0xe8 out of bounds>
mapset = 0x1 <Address 0x1 out of bounds>
verbose = 1
raw_data = 1575156072
with_coordinates = 0
with_xy = 0
with_percents = 0
with_counts = 0
with_areas = 1
with_labels = 0
fmt = '\0' <repeats 19 times>
range = {min = 1, max = 40, first_time = 0}
fp_range = {min = -0.247, max = 1, first_time = 0}
q = {truncate_only = 0, round_only = 0, defaultDRuleSet = 4199435, defaultCRuleSet = 0, infiniteLeftSet = 0,
infiniteRightSet = 0, cRangeSet = 1569807600, maxNofRules = 0, nofRules = 0, defaultDMin = 2.7108496074642367e-312,
defaultDMax = 1.2174480074876701e-316, defaultCMin = 4199435, defaultCMax = 0, infiniteDLeft = 0,
infiniteDRight = 1.1111882213708365e-312, infiniteCLeft = -1786587576, infiniteCRight = 42, dMin = -0.247, dMax = 1, cMin = 1,
cMax = 255, table = 0x50cdc0, fp_lookup = {vals = 0x3436, rules = 0x0, nalloc = 0, active = 0,
inf_dmin = 9.0363127466918322e-313, inf_dmax = 1.1111936913593466e-312, inf_min = -1073744856, inf_max = 127}}
min = 1
max = 255
null_set = 1
dmin = -0.247
dmax = 1
module = (struct GModule *) 0xe8
flag = {A = 0x5089d0, a = 0x508a20, c = 0x508a70, p = 0x508ac0, l = 0x508b10, q = 0x508b60, n = 0x508bb0, N = 0x508c00,
one = 0x2a95705380, x = 0x508ca0, g = 0x508c50, i = 0x508d90, r = 0x508d40, C = 0x508cf0}
option = {cell = 0x3535323d737065, fs = 0x508730, nv = 0x5087c0, output = 0x508850, nsteps = 0x508900}
Any ideas? I just wonder about
/* open all cell files */
Does anyone know how to get the desired result?
Can't believe that such a standard application fails...
