[GRASS5] Canadian mirror wanted
the current Canadian mirror seems to be out of sync for
some month. Is anyone willing to host a Canadian GRASS mirror
site (580MB required)? Otherwise I should "eliminate" Canada
from the mirror map and list...
Regards
Markus Neteler
subject 'unsubscribe grass5'
Markus Neteler wrote:
Regards
Markus Neteler
I may volunter but not before June.
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace@grr.ulaval.ca
I'm walking through glass on this one guys...
I have tried for the better part of 24hours to get GDAL to compile _and_
work with grass.
Not only do I need it for work, but I can't see how you can trust my
binaries if r.in.gdal fails routinely.
This is the latest cvs version of GDAL (1.1.5) and grass release candidate
5_0_0.
I get a consistent "ERROR: Unable to initialize GDAL bridge (check
libgdal installation)." from grass AND the bridge_test in GDAL fails
with a similar message. I was able to get a real result only once, (after
at least one hundred failures).
The system is suse 7.1, I have not installed anything exotic so I can't
see how the system might be affecting this issue.
If anyone has any idea on what I can check to deal with this, I would
welcome it.
Matt Berglund
P.S. If it is something stupid, please remember I am not the sharpest tool
in the shed.
Other pertinent information that I should have included in the previous
post is:
I have tried the binary package of GDAL with the my grass compile: failure
I have tried the variations on the compilation of GDAL: failure
Is python _required_ for the gdal bridge to work. If so, that could be the
reason. I do not have all the headers required for a compile of GDAL with
python.
Grass and tcltkgrass seem to work just dandily.
NVIZ still fails with:
The papers are available at
http://www2.gis.uiuc.edu:2280/modviz/
Unable to load map
Unable to load map
Loading Data
child killed: segmentation violation
    while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script elevation=4117ne1.1
-name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $CMD -name NVIZ >&@stdout
    (file "/usr/local/grass5/bin/nviz2.2" line 92)
Finished
But it should be noted that there is no elevation data for 4117ne1.1, so
why is it looking for some?
In any event, this is what I have found, if it is usefull, please let me
know. If not, please don't throw tomatoes!
Later,
Matt
work with grass.
5_0_0.
r.in.gdal isn't directly linked against the GDAL library; instead, it
does a run-time link using dlopen()[1]. It looks for the library under
the following names:
  libgdal.1.1.so
  gdal.1.0.so
  gdal.so.1.0
  libgdal.so.1
For each of the above names, it looks for:
  $GISBASE/lib/<name>
  $GDAL_HOME/<name>
  <name>
The last of these should (on Linux, at least) cause the library to be
looked for in the usual places (ld.so.cache, $LD_LIBRARY_PATH).
For each filename/directory combination, it queries the symbol
"GDALOpen" from the specified file.
So, the main things to check are that the library exists under one of
the above names, and that either:
a) it's in a directory listed in /etc/ld.so.conf, and "ldconfig" has
been run since it was put there, or
b) it's in a directory listed in $LD_LIBRARY_PATH, or
c) it's in $GISBASE/lib.
I wouldn't recommend using $GDAL_HOME; it just results in one more
thing for users to deal with (see the thread on "$PAGER").
[1] Furthermore, it calls dlopen() at least 69 times; once for each
function it wishes to use. It's actually 68+N times, where N is the
number of attempts at finding the library (max 12).
Does anyone mind if I re-write gdalbridge.c and gbgetsymbol.c so that
dlopen/LoadLibrary and dlsym/GetProcAddress are separate functions?
Or, better still, can't we just link directly against libgdal?
post is:
python.
No; I'm using GDAL 1.1.3 configured "--without-python".
work with grass.
5_0_0.
welcome it.
Matt Berglund
Matt,
in the shed.
nothing stupid!
A few questions:
- did GDAL compile properly?
- did you run make install on it finally (yes, why not)
- did you copy the libgdal... to $GISBASE/lib
This is just for verification,
PS: Frank Warmerdam is also listing to this channel and may probably
    have an idea.
Ok, your "dumb butt alarms" should be going off (about me)...
A few questions:
yes...
yes...
HAHAHAH!! Don't I wish.....
It works now.
But, wouldn't it be useful to have configure check and see if gdal is
installed and use it where it sits? This seems more intuitive to me, not
that you guys don't have enough to do.
Lastly,
nviz still does not work. Not in a boat, not with a goat.
I have no doubt it is something I am doing wrong.
Later,
Matt
Unable to load map
Unable to load map
Loading Data
    while executing
    invoked from within
Finished
Mhhh, this is also surprising. How did you start nviz?
Perhaps try:
nviz2.2 el=yourelmap
           ^^^^^^^^^ use some correct raster map name
does this work?
Regards
Tcktkgrass and grass commandline.
Perhaps try:
does this work?
Nope.
Later,
Matt
> A few questions:
yes...
yes...
It works now.
Hoorray! I have added such notes to
documents/release_rules.txt
to avoid future confusion.
Yes, probably Frank Warmerdam (excuse me, Frank) has a autoconf snipplet
to check this.
Otherwise: After running "make install" on gdal, a "ldconfig" should have
helped as well to get it working. However, for a binary installation we
want to have it in GISBASE/lib/.
Lastly,
What about
nviz2.2 -q
For what it is worth, Markus, I have to admit failing the GRASS
community. I have been unable to do the maintenance needed for the
Canadian Mirror. I have been out of the GRASS arena for a year now, and
it doesn't look like I am getting back into it any time soon.
I will remove the now sadly out of date mirror. There is kruft there
from before the mid-GRASS5 shuffle.
My thanks to all who have participated in development of GRASS. Keep up
doing what you need to do to make GRASS work for you.
Angus Carr.
Regards
Markus Neteler
Dear Angus,
Angus Carr.
I am sad to hear that you leave us! We have to be grateful to
*you* as you helped so much in the earlier days of GRASS 5 and
providing web space for the growing GRASS community.
Hopefully you keep in touch with us and maybe come back later.
Thanks for all your contributions,
kind regards
Markus Neteler
> Hi all,
> Regards
> Markus Neteler
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
Angus,
As Markus said, Thank you for your contributions!!! Keep in touch.
Bruce
Dear Angus,
> Angus Carr.
kind regards
Markus Neteler
> > Hi all,
> > Regards
> > Markus Neteler
