[GRASS5] Can't confirm d.sites/d.what.sites bug report...
The following is in grass/BUGS
[RC]d.sites/d.what.sites:
I'm working with grass5 v7 and I'm triyng to display a site file with
119000 points. The file is well formatted but the package d.sites stop the
display after about 9000 points.
Also d.what.sites stop reading of files after about 24000 points, it says
to me that the memory used is 1860 Kb.
If I display the same set of points but with grass4.1.2 it arrives til the
end.
(reported by marino vetuschi zuccolini <zucco@ugo.dipteris.unige.it>)
  (being worked on by ?)
I looked at the code for d.sites, and the only things that stand out
are, (1) failure of 'if(G_site_get() != 0)' (which could happen due to a
format error for extra/missing parameters before EOF) or (2) Site
doesn't fall within current region. Neither of these are BUGS.
For a simple test, I "cat'ed" together three runs of s.rand(om) with the
maximum value to get a sites_list of 98 thousand sites. No problem with
either d.sites or d.what.sites (though the monitor was practically solid
red from all the sites ;). Maybe this isn't a definitive test (no dims,
or string attributes were present), but it seems to indicate the modules
are working correctly. Perhaps there was a bug in the beta7 version???
Or, perhaps it's related to sizeof(int) which doesn't have to be very
big???
P.S. Marino, if you're still seeing this, could you double check your
site_lists files for errors? Perhaps, try upgrading to newer CVS
version and see if the problem persists. If it does, please report
about your computer architechture/OS (it might help).
#! /bin/sh
# ppp-address: What's my Internet Address for ppp0 ?
/sbin/ifconfig ppp0 2> /dev/null | grep 'inet addr:' | sed \
's=.*inet addr\:\([0-9]\{1,3\}\.[0-9]\{1,3\}\.[0-9]\{1,3\}\.[0-9]\{1,3\}\).*=\1='
subject 'unsubscribe grass5'
