[GRASS5] can't display vector maps
Dear list,
I updated GRASS 5.7 from CVS this morning and can't display
vector maps anymore. I tried in several locations, with several maps.
I can see and select maps, but that's it.
GRASS 5.7.cvs:~ > g.list vect
vector files available in mapset PERMANENT:
archsites soils t_9961_300 t_county
bugsites soistr t_9961_300_all t_hydro
fields streams t_9961_300_bks t_powerlines
quads t_9961_100 t_9961_400 tractids
roads
GRASS 5.7.cvs:~ > d.vect roads
ERROR: Vector file [roads] not available
the more detailed error messageusing the GIS Manager is:
child process exited abnormally
    while executing
"exec -- d.vect map=roads color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,centroid,area icon=basic/cross size=5 fiel..."
    ("eval" body line 1)
    invoked from within
"eval exec -- $cmd $args >@ stdout 2>@ stderr"
    (procedure "run" line 2)
    invoked from within
"run $cmd"
    (procedure "DmVector::display" line 77)
    invoked from within
"DmVector::display $node"
    ("vector" arm line 2)
    invoked from within
"switch $type {
        group {
            DmGroup::display $node
  raster {
      DmRaster::display $node
  labels {
      DmLabels::display $node
    (procedure "Dm::display_node" line 6)
    invoked from within
"Dm::display_node $n"
    (procedure "DmGroup::display" line 11)
    invoked from within
"DmGroup::display "root""
    (procedure "Dm::display" line 6)
    invoked from within
"Dm::display"
    ("uplevel" body line 1)
    invoked from within
"uplevel \#0 $cmd"
    (procedure "Button::_release" line 18)
    invoked from within
"Button::_release .mainframe.topf.tb0.bbox1.b0"
    (command bound to event)
   Otto
On Thu, 18 Nov 2004 09:52:26 +0100
Otto Dassau <otto.dassau@gmx.de> wrote:
Dear list,
I checked again, installed GRASS CVS from scratch with the same result. I hope this is a minor bug and will be fixed soon, otherwise it is impossible to work with vector data.
I went back to CVS snapshot grass57_exp_2004_11_13, there it is still working.
  thanks
   Otto
roads
    while executing
    invoked from within
    invoked from within
"run $cmd"
    invoked from within
    invoked from within
"switch $type {
        group {
  raster {
  labels {
    invoked from within
    invoked from within
    invoked from within
"Dm::display"
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
   Otto
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Hi Otto,
Radim submitted a bunch of bugfixes yesterday early evening:
http://grass.itc.it/pipermail/grass-commit/2004-November/date.html#end
Please update again. I just tested and things seem to work ok now.
GENERAL NOTES to update to current 5.7-CVS:
Probably there was a small bug in 'make mixclean' leaving
the links to 5.3 in the include/ directory. Please check
if grass57/include/ still contains links to GRASS 5.3-CVS
which is wrong. If links are still in existing in that
directory, run
  find include -type l -exec rm {} \;
GRASS 5.7-CVS may no longer have links to 5.3-CVS.
Then:
  make distclean
  cvs up -dP
  configure ...
  make
  make install
Hope this helps
> Dear list,
  thanks
   Otto
> roads
> while executing
> invoked from within
> invoked from within
> "run $cmd"
> invoked from within
> invoked from within
> "switch $type {
> group {
> raster {
> labels {
> invoked from within
> invoked from within
> invoked from within
> "Dm::display"
> invoked from within
> "uplevel \#0 $cmd"
> invoked from within
> Otto
> grass5 mailing list
> grass5@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
On Fri, 19 Nov 2004 09:03:06 +0100
Markus Neteler <neteler@itc.it> wrote:
Hi Otto,
it is the same problem. I can't display vector maps with the current CVS snapshot. Are you sure, it works with your maps
  Otto
directory, run
Then:
  make distclean
  cvs up -dP
  configure ...
  make
  make install
Hope this helps
> > Dear list,
> Hi,
> thanks
> Otto
> > roads
> > while executing
> > invoked from within
> > invoked from within
> > "run $cmd"
> > invoked from within
> > invoked from within
> > "switch $type {
> > group {
> > raster {
> > labels {
> > invoked from within
> > invoked from within
> > invoked from within
> > "Dm::display"
> > invoked from within
> > "uplevel \#0 $cmd"
> > invoked from within
> > Otto
> > _______________________________________________
> > grass5 mailing list
> > grass5@grass.itc.it
Could you try
strace d.vect roads 2>&1 | grep access | grep roads
Radim
Hi Otto,
  Otto
directory, run
Then:
make distclean
cvs up -dP
configure ...
make
make install
Hope this helps
Dear list,
thanks
  Otto
I updated GRASS 5.7 from CVS this morning and can't display vector maps anymore. I tried in several locations, with several maps. I can see and select maps, but that's it.
archsites soils t_9961_300 t_county bugsites soistr t_9961_300_all t_hydro fields streams t_9961_300_bks t_powerlines quads t_9961_100 t_9961_400 tractids roads ...
   while executing
   invoked from within
   invoked from within
"run $cmd"
   invoked from within
   invoked from within
"switch $type {
       group {
raster {
labels {
   invoked from within
   invoked from within
   invoked from within
"Dm::display"
   invoked from within
"uplevel \#0 $cmd"
   invoked from within
  Otto
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
On Fri, 19 Nov 2004 11:00:08 +0100
Radim Blazek <blazek@itc.it> wrote:
Could you try
GRASS 5.7.cvs:~ > strace d.vect roads 2>&1 | grep access | grep roads
access("/daten/grassdata/spearfish57/PERMANENT/dig/roads", F_OK) = -1 ENOENT (No such file or directory)
  Otto
Radim
>>Hi Otto,
> Hi,
> Otto
>>directory, run
>>Then:
>> make distclean
>> cvs up -dP
>> configure ...
>> make
>> make install
>>Hope this helps
>> Markus
>>>>Dear list,
>>>Hi,
>>> thanks
>>> Otto
>>>>roads
>>>> while executing
>>>> invoked from within
>>>> invoked from within
>>>>"run $cmd"
>>>> invoked from within
>>>> invoked from within
>>>>"switch $type {
>>>> group {
>>>> raster {
>>>> labels {
>>>> invoked from within
>>>> invoked from within
>>>> invoked from within
>>>>"Dm::display"
>>>> invoked from within
>>>>"uplevel \#0 $cmd"
>>>> invoked from within
>>>> Otto
>>>>grass5 mailing list
>>>>grass5@grass.itc.it
> grass5 mailing list
> grass5@grass.itc.it
You are running 5.7 modules with 5.0/3 libs.
Radim
Could you try
  Otto
