[GRASS5] can't latex progmanual
Hi there,
I have trouble latexing the programmer's manual. It exits with
make: *** [all] Erreur 139.
I'm using:
TeX (Web2C 7.3.7) 3.14159
kpathsea version 3.3.7
on Debian Woody
I've attached the log file. I'm really no latex expert, so I don't
really understand what is wrong.
Moritz
(attachments)
progmangrass50.log.gz (15.4 KB)
Moritz,
On Mon, Apr 29, 2002 at 03:25:03PM +0200, Moritz Lennert wrote:
Hi there,
I'm using:
on Debian Woody
the log file you have send does not contain an error, it
seems to be cut. Please send a full log.
Here it compiles fine...
Here's the output of make 2>&1 | tee ProgmanCompile.log, but again, I
don't see much of an error message, except at the end.
Moritz
On Mon, Apr 29, 2002 at 03:21:47PM +0200, Markus Neteler wrote:
Moritz,
> Hi there,
> I'm using:
> on Debian Woody
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
(attachments)
ProgmanCompile.log (19.4 KB)
Do you have enough space left on your device? :slight_smile:
... there I see:
Underfull \hbox (badness 10000) in paragraph at lines 75--77
Underfull \hbox (badness 10000) in paragraph at lines 78--81
LaTeX Warning: Reference 'Vector_Library' on page 42 undefined on input line
83
this is a warning only. Don't you find the DVI file? Look at it with
xdvi progmangrass50.dvi
To get a PDF file, run:
make pdf
To get a PS file, run:
make ps
To get a HTML set of file, run
make html
[see on top of the Makefile]
Good luck,
Moritz
> Moritz,
> > Hi there,
> > I'm using:
> > on Debian Woody
> Markus
> grass5 mailing list
> grass5@grass.itc.it
echo Rerun > progmangrass50.log
while grep Rerun progmangrass50.log >/dev/null 2>&1 ; do latex progmangrass50.tex ; done
This is TeX, Version 3.14159 (Web2C 7.3.7)
(./progmangrass50.tex
LaTeX2e <2001/06/01>
Babel <v3.7h> and hyphenation patterns for american, french, german, ngerman, n
ohyphenation, loaded.
(./scrbook.cls
Document Class: scrbook 1999/12/29 v2.5h LaTeX2e KOMA document class
(/usr/share/texmf/tex/latex/base/bk11.clo) (./typearea.sty
Package: typearea, Copyright (C) Frank Neukam, 1992-1994
                   Copyright (C) Markus Kohm, 1994-1999
)) (/usr/share/texmf/tex/latex/base/fontenc.sty
(/usr/share/texmf/tex/latex/base/t1enc.def)) (./progmangrass50.sty
(/usr/share/texmf/tex/generic/babel/babel.sty
(/usr/share/texmf/tex/generic/babel/english.ldf
(/usr/share/texmf/tex/generic/babel/babel.def)))
(/usr/share/texmf/tex/latex/graphics/graphicx.sty
(/usr/share/texmf/tex/latex/graphics/keyval.sty)
(/usr/share/texmf/tex/latex/graphics/graphics.sty
(/usr/share/texmf/tex/latex/graphics/trig.sty)
(/usr/share/texmf/tex/latex/config/graphics.cfg)
(/usr/share/texmf/tex/latex/graphics/dvips.def))) (./longtable.sty)
(/usr/share/texmf/tex/latex/base/makeidx.sty)
Writing index file progmangrass50.idx
(/usr/share/texmf/tex/latex/psnfss/times.sty) (./xspace.sty)
(/usr/share/texmf/tex/latex/fancyvrb/fancyvrb.sty
Style option: `fancyvrb' v2.7, with DG/SPQR fixes <2000/03/21> (tvz))
(/usr/share/texmf/tex/latex/base/ifthen.sty)
(/usr/share/texmf/tex/latex/hyperref/hyperref.sty
(/usr/share/texmf/tex/latex/hyperref/pd1enc.def)
Implicit mode ON; LaTeX internals redefined
(./url.sty))
*hyperref using driver hdvips*
(/usr/share/texmf/tex/latex/hyperref/hdvips.def
(/usr/share/texmf/tex/latex/hyperref/pdfmark.def)))
No file progmangrass50.aux.
(/usr/share/texmf/tex/latex/psnfss/t1ptm.fd)
(/usr/share/texmf/tex/latex/graphics/color.sty
(/usr/share/texmf/tex/latex/config/color.cfg)
(/usr/share/texmf/tex/latex/graphics/dvipsnam.def))
(/usr/share/texmf/tex/latex/hyperref/nameref.sty)
Overfull \hbox (341.43307pt too wide) in paragraph at lines 42--42
Overfull \hbox (341.43307pt too wide) in paragraph at lines 45--45
[1] [2] [3]
Overfull \hbox (0.90271pt too wide) in paragraph at lines 120--133
\T1/ptm/m/n/10.95 GRASS (Ge-o-graph-i-cal Re-sources Anal-y-sis Sup-port Sys-te
m) is a com-pre-hen-sive GIS with raster,
(/usr/share/texmf/tex/latex/psnfss/omsptm.fd)
Underfull \hbox (badness 10000) in paragraph at lines 141--142
(/usr/share/texmf/tex/latex/psnfss/t1pcr.fd)
LaTeX Warning: Reference `gfd_license' on page 4 undefined on input line 145.
Underfull \hbox (badness 10000) in paragraph at lines 143--146
[4]
Underfull \hbox (badness 10000) in paragraph at lines 192--198
Underfull \hbox (badness 10000) in paragraph at lines 199--200
Underfull \hbox (badness 10000) in paragraph at lines 201--202
Underfull \hbox (badness 10000) in paragraph at lines 203--204
[1]
Underfull \hbox (badness 10000) in paragraph at lines 229--236
Underfull \hbox (badness 10000) in paragraph at lines 237--238
[2] (./status.tex
Underfull \hbox (badness 10000) in paragraph at lines 1--2
Underfull \hbox (badness 10000) in paragraph at lines 3--4
[3]
Underfull \vbox (badness 10000) has occurred while \output is active [4])
[5] (./TODO [6]
Underfull \vbox (badness 10000) has occurred while \output is active [7])
[8] (./chapter1.tex [1] [2]
Chapter 1.
Underfull \hbox (badness 10000) in paragraph at lines 49--59
Underfull \vbox (badness 10000) has occurred while \output is active [3]
Underfull \hbox (badness 10000) in paragraph at lines 90--95
[4]
LaTeX Warning: Reference `GRASS_Information_Center' on page 5 undefined on inpu
t line 118.
t line 118.
t line 118.
Underfull \hbox (badness 10000) in paragraph at lines 136--137
[5]
Overfull \hbox (6.78607pt too wide) in alignment at lines 169--194
Package longtable Warning: Column widths have changed
(longtable) in table 1.1 on input line 194.
) (./chapter2.tex [6]
Chapter 2.
Underfull \hbox (badness 10000) in paragraph at lines 14--21
Underfull \hbox (badness 10000) in paragraph at lines 22--28
Underfull \hbox (badness 10000) in paragraph at lines 29--36
Underfull \hbox (badness 10000) in paragraph at lines 37--45
Underfull \hbox (badness 10000) in paragraph at lines 46--50
Underfull \hbox (badness 10000) in paragraph at lines 51--55
Underfull \hbox (badness 10000) in paragraph at lines 56--58
Underfull \hbox (badness 10000) in paragraph at lines 59--62
Underfull \hbox (badness 10000) in paragraph at lines 63--68
Underfull \hbox (badness 10000) in paragraph at lines 69--76
Underfull \hbox (badness 10000) in paragraph at lines 80--81
Underfull \hbox (badness 10000) in paragraph at lines 82--87
Underfull \hbox (badness 10000) in paragraph at lines 88--92
[8]
Underfull \hbox (badness 10000) in paragraph at lines 93--96
Underfull \hbox (badness 10000) in paragraph at lines 97--98
LaTeX Warning: Reference `Compiling_and_Installing_GRASS_Modules' on page 9 und
efined on input line 124.
LaTeX Warning: Reference `GRASS_CVS_repository' on page 9 undefined on input li
ne 141.
ne 141.
ne 141.
Underfull \vbox (badness 1888) has occurred while \output is active [9]
Overfull \hbox (3.63167pt too wide) in paragraph at lines 153--156
\T1/ptm/m/it/10.95 Source code \T1/ptm/m/n/10.95 -- The source code for the f
unc-tions should be ac-com-pa-nied by lib-eral amounts
LaTeX Warning: Reference `UNIX_Environment' on page 10 undefined on input line
172.
172.
172.
) (./chapter3.tex [10]
Chapter 3.
Underfull \hbox (badness 10000) in paragraph at lines 21--42
[11]
Underfull \hbox (badness 10000) in paragraph at lines 96--105
Underfull \hbox (badness 10000) in paragraph at lines 107--113
[12]
LaTeX Warning: Reference `Writing_GRASS_Shell_Scripts' on page 13 undefined on
input line 120.
input line 120.
input line 120.
Underfull \hbox (badness 10000) in paragraph at lines 115--121
Underfull \hbox (badness 10000) in paragraph at lines 122--128
LaTeX Warning: Reference `Compiling_and_Installing_GRASS_Modules' on page 13 un
defined on input line 139.
Underfull \hbox (badness 10000) in paragraph at lines 130--140
LaTeX Warning: Reference `GIS_Library' on page 13 undefined on input line 155.
LaTeX Warning: Reference `Vector_Library' on page 13 undefined on input line 16
7.
7.
7.
[13]
LaTeX Warning: Reference `Segment_Library' on page 14 undefined on input line 1
73.
73.
73.
LaTeX Warning: Reference `Vask_Library' on page 14 undefined on input line 182.
LaTeX Warning: Reference `Display_Graphics_Library' on page 14 undefined on inp
ut line 200.
ut line 200.
ut line 200.
LaTeX Warning: Reference `Raster_Graphics_Library' on page 14 undefined on inpu
t line 200.
t line 200.
t line 200.
LaTeX Warning: Reference `Writing_a_Graphics_Driver' on page 14 undefined on in
put line 218.
put line 218.
put line 218.
LaTeX Warning: Reference `Digitizer_Mouse_Trackball_Files' on page 14 undefined
on input line 223.
on input line 223.
on input line 223.
LaTeX Warning: Reference `Writing_a_Paint_Driver' on page 14 undefined on input
line 225.
line 225.
line 225.
[14]) (./chapter4.tex [15] [16]
Chapter 4.
LaTeX Warning: Reference `GIS_Library' on page 17 undefined on input line 16.
LaTeX Warning: Reference `GIS_Library' on page 17 undefined on input line 24.
LaTeX Warning: Reference `Environment_Variables' on page 17 undefined on input
line 26.
line 26.
line 26.
Underfull \hbox (badness 10000) in paragraph at lines 15--28
LaTeX Warning: Reference `Writing_GRASS_Shell_Scripts' on page 17 undefined on
input line 31.
input line 31.
input line 31.
Overfull \hbox (12.22581pt too wide) in paragraph at lines 49--55
\T1/ptm/m/n/10.95 Subdirectories un-der the GIS-D-BASE are known as lo-ca-tions
. Lo-ca-tions are in-de-pen-dent databases.
Underfull \vbox (badness 4144) has occurred while \output is active [17]
(/usr/share/texmf/tex/latex/psnfss/t1phv.fd)
LaTeX Warning: Reference `Database_Access_Rules' on page 18 undefined on input
line 102.
line 102.
line 102.
Underfull \hbox (badness 10000) in paragraph at lines 98--104
[18]
Overfull \hbox (31.89261pt too wide) in paragraph at lines 107--109
\T1/ptm/m/n/10.95 $GISDBASE/$LOCATION_NAME/$MAPSET and is re-turned by the li
-brary rou-tine G_location_path.
LaTeX Warning: Reference `Permanent_Mapset' on page 19 undefined on input line
115.
115.
115.
LaTeX Warning: Reference `Region' on page 19 undefined on input line 160.
Underfull \vbox (badness 2443) has occurred while \output is active [19]
LaTeX Warning: Reference `Mapset_Search_Path' on page 20 undefined on input lin
e 168.
e 168.
e 168.
LaTeX Warning: Reference `Creating_and_Opening_a_New_Database_File' on page 20
undefined on input line 177.
[20]
(longtable) in table 4.1 on input line 230.
Underfull \hbox (badness 10000) in paragraph at lines 241--245
Underfull \hbox (badness 10000) in paragraph at lines 246--248
Underfull \hbox (badness 10000) in paragraph at lines 249--253
Underfull \hbox (badness 10000) in paragraph at lines 254--255
Underfull \vbox (badness 6825) has occurred while \output is active [21]
LaTeX Warning: Reference `Mapsets' on page 22 undefined on input line 266.
LaTeX Warning: Reference `Mapset_Search_Path' on page 22 undefined on input lin
e 271.
e 271.
e 271.
LaTeX Warning: Reference `UNIX_File_Permissions' on page 22 undefined on input
line 272.
line 272.
line 272.
[22] [23]
Underfull \vbox (badness 10000) has occurred while \output is active [24])
(./chapter5.tex [25] [26]
Chapter 5.
(longtable) in table 5.1 on input line 153.
[27]
LaTeX Warning: Reference `Mapsets' on page 28 undefined on input line 184.
LaTeX Warning: Reference `Raster_File_Processing' on page 28 undefined on input
line 188.
line 188.
line 188.
LaTeX Warning: Reference `Multibyte_data_format' on page 28 undefined on input
line 213.
Underfull \vbox (badness 10000) has occurred while \output is active [28]
Underfull \hbox (badness 10000) in paragraph at lines 244--248
[29]
LaTeX Warning: Reference `Raster_Header_File' on page 30 undefined on input lin
e 295.
e 295.
e 295.
Overfull \hbox (0.53217pt too wide) in paragraph at lines 343--348
\T1/ptm/m/n/10.95 The ge-o-graphic bound-aries of the raster file are de-scri
bed by the \T1/ptm/m/it/10.95 north,
[30]
Underfull \hbox (badness 10000) in paragraph at lines 386--388
Underfull \hbox (badness 10000) in paragraph at lines 391--392
Underfull \hbox (badness 10000) in paragraph at lines 393--396
Underfull \vbox (badness 5189) has occurred while \output is active [31]
Underfull \hbox (badness 10000) in paragraph at lines 469--471
LaTeX Warning: Reference `Raster_Category_File' on page 32 undefined on input l
ine 473.
ine 473.
ine 473.
Underfull \hbox (badness 10000) in paragraph at lines 472--474
[32]
Underfull \hbox (badness 10000) in paragraph at lines 492--493
(longtable) in table 5.2 on input line 572.
[33] [34]
LaTeX Warning: Reference `Raster_Color_Table' on page 35 undefined on input lin
e 637.
e 637.
e 637.
Underfull \hbox (badness 10000) in paragraph at lines 636--638
Underfull \hbox (badness 10000) in paragraph at lines 643--645
[35]
LaTeX Warning: Reference `Raster_History_File' on page 36 undefined on input li
ne 683.
ne 683.
ne 683.
LaTeX Warning: Reference `Raster_Range_File' on page 36 undefined on input line
700.
700.
700.
Underfull \hbox (badness 10000) in paragraph at lines 709--710
[36]
Overfull \hbox (46.03969pt too wide) in paragraph at lines 734--742
\T1/ptm/m/n/10.95 tines: G_something_raster (..., void *raster, RASTER_MAP_TYPE
type, ...) G_something_c_raster
Overfull \hbox (62.51988pt too wide) in paragraph at lines 734--742
\T1/ptm/m/n/10.95 G_something_null_value (..., void *raster, RASTER_MAP_TYPE ty
pe, ...) G_something_c_null_value
Overfull \hbox (39.6557pt too wide) in paragraph at lines 734--742
\T1/ptm/m/n/10.95 (..., CELL *cell, ...) G_something_f_null_value (..., FCELL *
fcell, ...) G_something_d_null_value
[37]
Overfull \hbox (5.2423pt too wide) in paragraph at lines 835--837
\T1/ptm/m/n/10.95 This bi-nary file con-tains the range (min-i-mum and max-
[38]) (./chapter6.tex [39] [40]
Chapter 6.
Overfull \hbox (0.83908pt too wide) in paragraph at lines 7--9
\T1/ptm/m/n/10.95 This chap-ter pro-vides an ex-pla-na-tion of how vec-tor map
lay-ers are ac-com-mo-dated in the GRASS
Underfull \hbox (badness 10000) in paragraph at lines 13--19
Underfull \hbox (badness 10000) in paragraph at lines 20--32
LaTeX Warning: Reference `What_is_a_Raster_Map_Layer' on page 41 undefined on i
nput line 39.
nput line 39.
nput line 39.
Underfull \hbox (badness 10000) in paragraph at lines 33--41
LaTeX Warning: Reference `Mapsets' on page 41 undefined on input line 46.
Underfull \hbox (badness 10000) in paragraph at lines 42--47
[41]
Overfull \hbox (1.2103pt too wide) in paragraph at lines 61--64
\T1/ptm/m/n/10.95 For ex-am-ple, a map layer named \T1/ptm/m/it/10.95 soils \
T1/ptm/m/n/10.95 would have the files \T1/ptm/m/it/10.95 dig\T1/ptm/m/n/10.95 /
\T1/ptm/m/it/10.95 soils, dig_att\T1/ptm/m/n/10.95 /\T1/ptm/m/it/10.95 soils, d
ig_plus/soils,
LaTeX Warning: Reference `Vector_Library' on page 42 undefined on input line 83
grass5 mailing list
grass5@grass.itc.it
when I try to view the .dvi file I get
'xdvi.bin: DVI file corrupted'
when I try dvips on it I get
'dvips: ! unexpected eof on DVI file'
all of make, make pdf, make html fail (don't they all do a 'make all' to start with ?)
I'll just download the pdf-file for now, and if it compiles normally for everyone else, I guess it's a local problem.
Moritz
... there I see:
83
make pdf
make ps
make html
Good luck,
> Moritz
> > Moritz,
> > > Hi there,
> > > I'm using:
> > > on Debian Woody
> > Markus
> > _______________________________________________
> > grass5 mailing list
> > grass5@grass.itc.it
> (./scrbook.cls
> (./url.sty))
> [1] [2] [3]
> [4]
> [1]
> [2] (./status.tex
> [3]
> [5] (./TODO [6]
> Chapter 1.
> [4]
> t line 118.
> t line 118.
> t line 118.
> [5]
> Chapter 2.
> [8]
> ne 141.
> ne 141.
> ne 141.
> 172.
> 172.
> 172.
> Chapter 3.
> [11]
> [12]
> input line 120.
> input line 120.
> input line 120.
> 7.
> 7.
> 7.
> [13]
> 73.
> 73.
> 73.
> ut line 200.
> ut line 200.
> ut line 200.
> t line 200.
> t line 200.
> t line 200.
> put line 218.
> put line 218.
> put line 218.
> on input line 223.
> on input line 223.
> on input line 223.
> line 225.
> line 225.
> line 225.
> Chapter 4.
> line 26.
> line 26.
> line 26.
> input line 31.
> input line 31.
> input line 31.
> line 102.
> line 102.
> line 102.
> [18]
> 115.
> 115.
> 115.
> e 168.
> e 168.
> e 168.
> [20]
> e 271.
> e 271.
> e 271.
> line 272.
> line 272.
> line 272.
> [22] [23]
> Chapter 5.
> [27]
> line 188.
> line 188.
> line 188.
> line 213.
> [29]
> e 295.
> e 295.
> e 295.
> [30]
> ine 473.
> ine 473.
> ine 473.
> [32]
> [33] [34]
> e 637.
> e 637.
> e 637.
> [35]
> ne 683.
> ne 683.
> ne 683.
> 700.
> 700.
> 700.
> [36]
> [37]
> Chapter 6.
> nput line 39.
> nput line 39.
> nput line 39.
> [41]
> ig_plus/soils,
> grass5 mailing list
> grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
Error 139 is 128+11, i.e. a child process terminated with signal 11
(SIGSEGV, "Segmentation fault").
It isn't possible to deduce anything further from the log files.
It may be possible to obtain more information by running the
individual commands directory. OTOH, you might even need to use
strace/gdb/etc to determine the problem.
