[GRASS5] cd $LOCATION revisited
There is probably some confusion concerning $LOCATION variable:
Writing Helena (GRASS 5.3-CVS):
> > if I work in GRASS on command line and I type
> > GRASS:~ > cd $GISDBASE/$LOCATION_NAME/$MAPSET
> > GRASS:~/grassdata/wake-spft/helena > pwd
> > /home/helena/grassdata/wake-spft/helena
> > GRASS:~/grassdata/wake-spft/helena > ls
> > cats cell cellhd cell_misc colr dig dig_att dig_cats dig_plus
> > fcell g3dcell hist WIND
Answer Markus (GRASS 5.3-CVS):
> On a standard version it doesn't work:
> GRASS:// >
... confusing!
Clarification (desired behaviour?):
I don't have any trick or modification - Jaro has explained it to me -
when you start GRASS with tcltk interface the variables get set up and
it works as written above.
If you start with -text then I get what you have described
as standard version. So far on the machines where I have tried it
it works like this without any tricks
Helena
For me it's strange if, depending how GRASS was started, $LOCATION
is set or not. Guess that this should be fixed.
That behaviour is due to the following in gis_set.tcl:
    button .frame0.frameBUTTONS.ok \
       -text [G_msg "Use Selection"] \
      -relief raised \
       -padx 10 \
       -command {
            if { $mapset != "" } {
              CheckLocation
                puts stdout "GISDBASE='$database'; export GISDBASE;"
                puts stdout "LOCATION_NAME='$location'; export LOCATION_NAME;"
                puts stdout "MAPSET='$mapset'; export MAPSET;"
                if {[string compare $location "##ERROR##"] != 0} {
        putGRASSRC $gisrc_name
    destroy .
    button .frame0.frameBUTTONS.newLoc \
      -text [G_msg "Create New Location"] \
      -relief raised \
      -padx 10 \
      -command {
            puts stdout "OLD_DB='$oldDb';"
            puts stdout "OLD_LOC='$oldLoc';"
            puts stdout "OLD_MAP='$oldMap';"
          puts stdout "LOCATION_NAME='##NONE##'; export LOCATION_NAME;"
            puts stdout "MAPSET=''; export MAPSET;"
            set location ""
      set mapset ""
      destroy .
The "export" commands shouldn't be there.
