There follows a summary of the changes which have been committed to
the release branch since the 5.0.0 release.
All appear to be either trivial fixes, non-trivial but critical fixes,
or documentation changes. Although I'm not quite sure about the
v.out.shape change.
A (larger) list of changes to the head which haven't been committed to
the release branch will follow.
Makefile.in
Update "srcdist" target to include base directory
configure
configure.in
Add check for keypad() function in curses library
Change FreeType header check
documents/grasshist.html
Update
html/database.html
html/display.html
html/drivers.html
html/env_vars.html
html/export.html
html/general.html
html/grid3d.html
html/imagery.html
html/import.html
html/index.html
html/misc.html
html/models.html
html/paint.html
html/photo.html
html/projections.html
html/ps.html
html/raster.html
html/scripts.html
html/searchhtml.html
html/sites.html
html/tips_and_tricks.html
html/vector.html
Remove font tags
Misc. HTML clean-up
html/html/d.3d.html
Add box=
html/html/g.rename.html
Add -o
html/html/photo.camera.html
Update
html/html/r.covar.html
Change example matrix
html/html/r.stats.html
Remove -z
html/html/r.to.pg.html [ADDED]
Added
html/spearfish_directorytree.html [ADDED]
Added
html/terminology.html
Add link to Spearfish data set
Fix typo
Remove font tags
Misc. HTML clean-up
src/CMD/generic/make.mid
mk/mid.mk
mk/mid.mk.shlib
Change libedit -> libgedit (MacOSX name conflict)
src.contrib/GMSL/NVIZ2.2/scripts/widgets.tcl
Prevent divide-by-zero
Expose private commands (Tk 8.4 fix)
src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/dataoct.c
src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/main.c
src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/oct.c
src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/user1.c
src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/user2.c
src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/user3.c
src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/user4.c
Obtain malloc() prototype from stdlib.h, not malloc.h
src.contrib/SCS/vector/v.report/cmd/perimeter.c [REMOVED]
src.contrib/SCS/vector/v.report/cmd/Gmakefile
src.contrib/SCS/vector/v.report/cmd/do_v_stats.c
Move perimiter calculation into do_v_stats.c
src/display/d.zoom/cmd/set.c
Rename round() -> round_to() (ANSI C9X name conflict)
src/display/devices/PNGdriver/Gmakefile
Add PNG driver to monitorcap even if the executable doesn't
need to be rebuilt
src/imagery/i.pca/cmd/main.c
Rename round() -> round_c() (ANSI C9X name conflict)
src/include/config.h.in
Add HAVE_KEYPAD
src/libes/gis/get_row.c
Change G_get_map_row() to honour the mask
src/libes/gis/lzw.c [REMOVED]
Removed
src/libes/vask/V_exit.c
src/libes/vask/V_init.c
Only call keypad() if HAVE_KEYPAD is defined
src/libes/vect32/georef/vars.c [REMOVED]
src/libes/vect32/georef/Gmakefile
src/libes/vect32/georef/geo_file.c
Move variable definitions into geo_file.c (MacOSX linker fix)
src/mapdev/v.extract/cmd/main.c
Disable -n switch
src/mapdev/v.out.shape/extract.c
src/mapdev/v.out.shape/main.c
src/raster/r.mapcalc3/evaluate.c
src/raster/r.mapcalc3/expression.c
src/raster/r.mapcalc3/map.c
src/raster/r.mapcalc3/mapcalc.h
src/raster/r.mapcalc3/mapcalc.l
src/raster/r.mapcalc3/mapcalc.y
src/raster/r.mapcalc3/xnot.c
Fix handling of qualified map names
Improve handling of undefined variable, function or map names
Allow input to be terminated by "end" or "exit" as well as EOF
Fix arity of not() function
src/raster/r.param.scale/interface.c
html/html/r.param.scale.html
Change default c_tol value
Document sense of direction of maximum gradient
src/raster/r.sun/main.c
Remove reference to <malloc.h>
Fix spelling of Key_Value
src/raster/r.support/cmd/support.c
Remove unused variables
Look for map in current mapset (no qualified map names)
Use G_fatal_error()
src/raster/r.tiff/r.out.tiff.c
Add warning when writing FP maps
src/scripts/contrib/grassmirrorsmap/grass.sites.mirror
Fix URL for Taiwan
src/scripts/contrib/r.univar/r.univar
Add "(excluding NULL cells)" to message
src/scripts/contrib/v.cutregion.sh/v.cutregion.sh
Change ORGANIZATION field
Note creator
src/scripts/contrib/v.line2area/v.area2line
src/scripts/contrib/v.line2area/v.line2area
Use -o switch when calling g.rename
src/tcltkgrass/module/i.grey.scale [REMOVED]
src/tcltkgrass/main/menu.tcl
Remove references to i.grey.scale
src/tcltkgrass/module/d.zoom
Fix option names
src/tcltkgrass/module/r.stats
Update flags: add -pnNCri, remove -mz
