I've attached a summary of the differences between the current CVS
head and the 5.0.1 release.
I'll comment on it later (probably tomorrow).
(attachments)
grass-diff.txt (22 KB)
head and the 5.0.1 release.I'll comment on it later (probably tomorrow).
My comments follow. I'd appreciate comments from the authors of any
changes marked "Probably" or "Don't know".
BTW, the script which I use for comparing versions has been added to
the CVS head as tools/diff.sh.
Of the more wide-ranging changes:
I'm recommending the inclusion of the libgis/libraster I18N; it's been
there long enough, and there's good reason to believe that it should
be totally harmless provided that --with-nls isn't used. OTOH, I'm not
recommending the startup/tcltkgrass I18N changes, because those can't
be disabled.
I'm not recommending the MINGW32 stuff generally, as it looks a bit
rough at present. OTOH, the unlink() -> remove() change is
straightforward enough.
The Infx -> Pg changes *really* should have waited until 5.1, IMHO. It
makes it almost impossible to tell whether anything substantial has
changed, so we would either have to commit the whole lot and hope for
the best, or leave it completely alone.
NEWS.html
README
SUBMITTING
binaryInstall.src
documents/README_cygwin.html
documents/cygwin_grass50bininstall.html
documents/cygwin_grass50compile.html
documents/debugging.txt
documents/release_rules.txt
html/tips_and_tricks.html
Documentation changes
Probably.
configure
configure.in
Remove TERMLIB
Add $MATHLIB to PNG candidate dependencies
Remove postgres[_fe].h checks
Add -lstdc++ to GLU candidate dependencies
Yes.
src/include/config.h.in
Remove HAVE_POSTGRES[_FE]_H
Add HAVE_LIBPQ_FE_H
Yes.
src/CMD/head/head.in
Remove $(TERMLIB)
Remove $(XEXTRALIBS) from XDRLIB
Yes.
handheld/babyGRASS_compile.sh
handheld/babyGRASS_packagingsrc.sh
Add more modules
Probably.
html/html/d.vect.pg.html
-e
Don't know.
html/html/r.mapcalc.html
^ (exponentiation) operator
y#, i# modifiers
atan(x,y), double(x), not(x), rand(a,b)
Handling of NULL values
Yes.
html/html/r.random.cells.html
html/html/r.random.surface.html
Fix URLs
Probably.
html/html/r.watershed.html
xrefs
Probably.
html/html/s.in.ascii.html
HTML fix
Yes.
html/html/v.out.shape.html
-v, -A
HTML tidying
Probably.
html/html/xdriver.html
XDRIVER_{WIDTH,HEIGHT} -> GRASS_{WIDTH,HEIGHT}
Yes.
html/index.html
html/searchhtml.html
index2.html -> index.html
Don't know.
html/projections.html
EPSG link
Probably.
locale/Gmakefile
Add tcltkgrass, textintro targets
No.
locale/ru/LC_MESSAGES/d.rast.pg.po
locale/ru/LC_MESSAGES/d.site.pg.po
locale/ru/LC_MESSAGES/d.vect.pg.po
locale/ru/LC_MESSAGES/d.what.r.pg.po
locale/ru/LC_MESSAGES/d.what.s.pg.po
locale/ru/LC_MESSAGES/d.what.v.pg.po
locale/ru/LC_MESSAGES/g.column.pg.po
locale/ru/LC_MESSAGES/g.select.pg.po
locale/ru/LC_MESSAGES/g.stats.pg.po
locale/ru/LC_MESSAGES/g.table.pg.po
locale/ru/LC_MESSAGES/pg.in.dbf.po
locale/ru/LC_MESSAGES/v.reclass.pg.po
locale/ru/LC_MESSAGES/v.to.pg.po
Depends upon the corresponding program changes.
src.contrib/GMSL/NVIZ2.2/doconfigure
- src.contrib/GMSL/NVIZ2.2/src/query_postgr_dummy.c
- src.contrib/GMSL/NVIZ2.2/src/query_postgr_orig.c
Remove query_postgr_{orig,dummy}.c
Don't know.
src.contrib/GMSL/NVIZ2.2/src/query_postgr.c
Don't know.
src.contrib/GMSL/NVIZ2.2/scripts/fileBrowser.tcl
Default to cwd instead of $HOME
No; use built-in "pwd" rather than "exec pwd".
src.contrib/GMSL/NVIZ2.2/scripts/panel_kanimator.tcl
src.contrib/GMSL/NVIZ2.2/scripts/panel_main.tcl
src.contrib/GMSL/NVIZ2.2/src/anim_support.c
src.contrib/GMSL/NVIZ2.2/src/change_view.c
src.contrib/GMSL/NVIZ2.2/src/getCat.c
src.contrib/GMSL/NVIZ2.2/src/init_commands.c
src.contrib/GMSL/NVIZ2.2/src/interface.h
src.contrib/GMSL/NVIZ2.2/src/position.c
Don't know.
src.contrib/GMSL/NVIZ2.2/src/Gmakefile
- src.contrib/GMSL/NVIZ2.2/src/buildInfxQry.c
- src.contrib/GMSL/NVIZ2.2/src/infx.h
- src.contrib/GMSL/NVIZ2.2/src/runInfxQry.c
+ src.contrib/GMSL/NVIZ2.2/src/buildPg.c
+ src.contrib/GMSL/NVIZ2.2/src/pg.h
+ src.contrib/GMSL/NVIZ2.2/src/runPg.c
Infx -> Pg
Don't know.
+ src.contrib/GMSL/NVIZ2.2/src/README
HOWTO - Adding new header files from tcl/tk
Probably.
+ src.contrib/GMSL/NVIZ2.2/src/tkInt8.4.h
+ src.contrib/GMSL/NVIZ2.2/src/tkIntDecls8.4.h
Add Tk 8.4 support
Yes (togl.c was already updated in 5.0.1, but these files were missing).
src.contrib/GMSL/NVIZ2.2/src/togl.c
Remove $Log$
Add Tcl/Tk URL
Yes.
src.contrib/GMSL/g3d/src3d/general/g3.region/editcellhd3d.c
src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc/xcoor.c
src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc/xrowcol.c
src.contrib/GMSL/g3d/src3d/raster/r3.null/main.c
src.contrib/GMSL/g3d/src3d/raster/r3.out.ascii/main.c
src.contrib/GMSL/g3d/src3d/raster/r3.out.v5d/main.c
src.contrib/GMSL/g3d/src3d/raster/r3.out.v5d/v5d.h
src.contrib/GMSL/g3d/src3d/sites/s.vol.idw/main.c
src.contrib/GMSL/g3d/src3d/sites/s.vol.rst/user1.c
??? (AV)
Probably (g3d isn't built by default, so compatibility isn't an issue).
src.contrib/SCS/misc/m.futil/inter/Gmakefile
src.contrib/SCS/paint/Programs/color.map/inter/Gmakefile
src.contrib/SCS/paint/Programs/grey.map/inter/Gmakefile
src.contrib/SCS/paint/Programs/newp.map/inter/Gmakefile
src.contrib/SCS/raster/r.reclass.scs/inter/Gmakefile
src.contrib/SCS/vector/v.reclass/inter/Gmakefile
src/general/g.manual/inter/Gmakefile
src/general/manage/inter/Gmakefile
src/mapdev/v.extract/inter/Gmakefile
src/mapdev/v.out.dxf/backup/Gmakefile
src/paint/Programs/p.icons/Gmakefile
src/paint/Programs/p.map/inter/Gmakefile
src/ps.map/ps.map/inter/Gmakefile
src/raster/r.neighbors/inter/Gmakefile
src/raster/r.support/inter/Gmakefile
unused/general/g.manual/inter/Gmakefile
unused/sites/s.menu/driver/Gmakefile
unused/sites/s.menu/meta_report/Gmakefile
unused/sites/s.menu/site_reports/Gmakefile
unused/sites/s.menu/sites_in_cell/Gmakefile
unused/sites/s.menu/sites_to_cell/Gmakefile
Remove $(TERMLIB)
Yes.
src.garden/answers/src.answers/raster/README
Probably.
src.garden/grass.hdf/hdf5/r.in.hdf/r.in.hdf.c
Add GSFC/DAAC credit
Yes.
src.garden/grass.postgresql/Gmakefile
Disable v.in.arc.pg
Don't know.
src.garden/grass.postgresql/README
Probably.
- src.garden/grass.postgresql/d.rast.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.rast.pg/runInfxFile.c
- src.garden/grass.postgresql/d.site.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.site.pg/runInfxFile.c
- src.garden/grass.postgresql/d.vect.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
- src.garden/grass.postgresql/d.what.r.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.what.r.pg/runInfxQry.c
- src.garden/grass.postgresql/d.what.s.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.what.s.pg/infx.h
- src.garden/grass.postgresql/d.what.s.pg/runInfxFile.c
- src.garden/grass.postgresql/d.what.v.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.what.v.pg/runInfxQry.c
- src.garden/grass.postgresql/g.column.pg/infx.h
- src.garden/grass.postgresql/g.column.pg/infxColumn.c
- src.garden/grass.postgresql/g.stats.pg/infx.h
- src.garden/grass.postgresql/g.stats.pg/infxStats.c
- src.garden/grass.postgresql/g.table.pg/infxTable.c
- src.garden/grass.postgresql/v.reclass.pg/buildInfxQry.c
- src.garden/grass.postgresql/v.reclass.pg/runInfxFile.c
- src.garden/grass.postgresql/v.to.pg/buildInfxQry.c
- src.garden/grass.postgresql/v.to.pg/runInfxFile.c
+ src.garden/grass.postgresql/d.rast.pg/buildPg.c
+ src.garden/grass.postgresql/d.rast.pg/runPg.c
+ src.garden/grass.postgresql/d.site.pg/buildPg.c
+ src.garden/grass.postgresql/d.site.pg/runPg.c
+ src.garden/grass.postgresql/d.vect.pg/buildPg.c
+ src.garden/grass.postgresql/d.vect.pg/runPg.c
+ src.garden/grass.postgresql/d.what.r.pg/buildPg.c
+ src.garden/grass.postgresql/d.what.r.pg/runPg.c
+ src.garden/grass.postgresql/d.what.s.pg/buildPg.c
+ src.garden/grass.postgresql/d.what.s.pg/runPg.c
+ src.garden/grass.postgresql/d.what.v.pg/buildPg.c
+ src.garden/grass.postgresql/d.what.v.pg/runPg.c
+ src.garden/grass.postgresql/g.column.pg/pgColumn.c
+ src.garden/grass.postgresql/g.stats.pg/pgStats.c
+ src.garden/grass.postgresql/g.table.pg/pgTable.c
+ src.garden/grass.postgresql/v.reclass.pg/buildPg.c
+ src.garden/grass.postgresql/v.reclass.pg/runPg.c
+ src.garden/grass.postgresql/v.to.pg/buildPg.c
+ src.garden/grass.postgresql/v.to.pg/runPg.c
src.garden/grass.postgresql/d.rast.pg/Gmakefile
src.garden/grass.postgresql/d.site.pg/Gmakefile
src.garden/grass.postgresql/d.vect.pg/Gmakefile
src.garden/grass.postgresql/d.what.r.pg/Gmakefile
src.garden/grass.postgresql/d.what.s.pg/Gmakefile
src.garden/grass.postgresql/d.what.v.pg/Gmakefile
src.garden/grass.postgresql/g.column.pg/Gmakefile
src.garden/grass.postgresql/g.stats.pg/Gmakefile
src.garden/grass.postgresql/v.reclass.pg/Gmakefile
src.garden/grass.postgresql/v.to.pg/Gmakefile
Infx -> Pg
No.
src.garden/grass.postgresql/g.table.pg/Gmakefile
Infx -> Pg
I18N
Don't know.
- src.garden/grass.postgresql/d.what.s.pg/graphics.h
- src.garden/grass.postgresql/d.what.s.pg/returns.c
+ src.garden/grass.postgresql/d.what.s.pg/what.h
- src.garden/grass.postgresql/g.column.pg/column.h
- src.garden/grass.postgresql/g.column.pg/delcr.c
- src.garden/grass.postgresql/g.stats.pg/stats.hsrc.garden/grass.postgresql/d.rast.pg/dbrast.h
src.garden/grass.postgresql/d.rast.pg/getAllOpts.c
src.garden/grass.postgresql/d.rast.pg/getSopts.c
src.garden/grass.postgresql/d.rast.pg/main.c
src.garden/grass.postgresql/d.site.pg/dbsite.h
src.garden/grass.postgresql/d.site.pg/getAllOpts.c
src.garden/grass.postgresql/d.site.pg/getSopts.c
src.garden/grass.postgresql/d.site.pg/main.c
src.garden/grass.postgresql/d.site.pg/plotsite.c
src.garden/grass.postgresql/d.vect.pg/bsearch.c
src.garden/grass.postgresql/d.vect.pg/dbvect.h
src.garden/grass.postgresql/d.vect.pg/find.c
src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
src.garden/grass.postgresql/d.vect.pg/getSopts.c
src.garden/grass.postgresql/d.vect.pg/main.c
src.garden/grass.postgresql/d.vect.pg/plotCat.c
src.garden/grass.postgresql/d.what.r.pg/getAllOpts.c
src.garden/grass.postgresql/d.what.r.pg/getCat.c
src.garden/grass.postgresql/d.what.r.pg/getSopts.c
src.garden/grass.postgresql/d.what.r.pg/main.c
src.garden/grass.postgresql/d.what.r.pg/opencell.c
src.garden/grass.postgresql/d.what.r.pg/what.h
src.garden/grass.postgresql/d.what.s.pg/getAllOpts.c
src.garden/grass.postgresql/d.what.s.pg/getArea.c
src.garden/grass.postgresql/d.what.s.pg/getSopts.c
src.garden/grass.postgresql/d.what.s.pg/main.c
src.garden/grass.postgresql/d.what.v.pg/getAllOpts.c
src.garden/grass.postgresql/d.what.v.pg/getCat.c
src.garden/grass.postgresql/d.what.v.pg/getSopts.c
src.garden/grass.postgresql/d.what.v.pg/main.c
src.garden/grass.postgresql/d.what.v.pg/openvect.c
src.garden/grass.postgresql/d.what.v.pg/what.h
src.garden/grass.postgresql/g.column.pg/main.c
src.garden/grass.postgresql/g.select.pg/getdbname.c
src.garden/grass.postgresql/g.select.pg/listdb.c
src.garden/grass.postgresql/g.select.pg/main.c
src.garden/grass.postgresql/g.stats.pg/main.c
src.garden/grass.postgresql/g.table.pg/main.c
src.garden/grass.postgresql/pg.in.dbf/main.c
src.garden/grass.postgresql/pg.in.dbf/pgdump.c
src.garden/grass.postgresql/tutorial/index.html
src.garden/grass.postgresql/v.in.arc.pg/pgdump.c
src.garden/grass.postgresql/v.reclass.pg/dbvect.h
src.garden/grass.postgresql/v.reclass.pg/getAllOpts.c
src.garden/grass.postgresql/v.reclass.pg/getSopts.c
src.garden/grass.postgresql/v.reclass.pg/main.c
src.garden/grass.postgresql/v.to.pg/bsearch.c
src.garden/grass.postgresql/v.to.pg/dbvect.h
src.garden/grass.postgresql/v.to.pg/find.c
src.garden/grass.postgresql/v.to.pg/getAllOpts.c
src.garden/grass.postgresql/v.to.pg/getSopts.c
src.garden/grass.postgresql/v.to.pg/main.c
src.garden/grass.postgresql/v.to.pg/plotCat.c
Infx -> Pg
Tidying
No.
src/CMD/VERSION
5.0.1 -> 5.0.2-cvs
Change to 5.0.2 for release.
src/CMD/generic/POST_INSTALL.sh
Improved error message in case of compilation errors
Probably.
src/CMD/generic/gmake.sh
Allow C++ files (incomplete)
Don't know.
html/html/d.dm.html
src/display/d.dm/d.dm
Add PNG button
Fix loading of BWidget package
Don't know.
src/display/d.mon/cmd/main.c
src/display/d.mon/inter/Gmakefile
Fix exit code
Remove $(TERMLIB)
Yes.
html/html/d.text.freetype.html
+ src/display/d.text.freetype/vflib/
+ src/display/d.text.freetype/test.input
src/display/d.text.freetype/Gmakefile
src/display/d.text.freetype/freetypecap
src/display/d.text.freetype/main.c
-rpsc, text=, align=, rotation=
Command mode
Add $(MATHLIB)
Change freetypecap defaults
Probably (d.text.freetype is fairly new).
src/display/d.vect/cmd/main.c
src/display/d.vect/cmd/plot2.c
src/display/d.vect/cmd/plotCat.c
Don't know.
src/display/d.what.sites/local_proto.h
src/display/d.what.sites/main.c
src/display/d.what.sites/what.c
Don't know.
html/html/d.what.vect.html
src/display/d.what.vect/cmd/Gmakefile
src/display/d.what.vect/cmd/what.c
src/display/d.what.vect/cmd/what.h
+ src/display/d.what.vect/cmd/flash.c
Don't know.
src/display/devices/lib/command.c
Rename eof -> eofile
Yes.
src/display/devices/windows/libW11/w32/xlib.c
Fix XCreateImage() bytes_per_line == 0 bug (not committed)
Yes (now committed).
html/html/g.mapsets.html
src/general/g.mapsets/main_cmd.c
addmapset=
Don't know.
src/general/g.region/cmd/printwindow.c
src/mapdev/v.in.gshhs/main.c
src/misc/m.ll2db/main.c
src/raster/r.sun/main.c
src/raster/r.sunmask/g_solposition.c
src/sites/s.datum.shift/main.c
Don't call pj_zero_proj()
Don't know (related to generalised datum transformations?)
src/general/g.setproj/get_num.c
src/general/g.setproj/local_proto.h
src/general/g.setproj/main.c
Don't know.
src/general/init/Gmakefile
src/general/init/init.sh
+ src/general/init/license.txt
+ locale/ru/grass_intro.txt
+ locale/ru/license.txt
I18N (license, grass_intro)
No.
src/general/init/chk_dbase.c
MINGW32
No.
src/general/init/grass.src
Trap signals
Don't know.
src/imagery/i.ortho.photo/menu/menu.c
Don't know.
src/imagery/i.ortho.photo/photo.rectify/write.c
Error messages
No.
src/include/geo.h
Don't know.
src/include/gisdefs.h
color_byg.c
Yes.
G__getsome
G_number_of_tokens
Don't know.
src/include/projects.h
Generalised datum transformations
Don't know.
src/libes/dbmi/drivers/stubs/add_col.c
src/libes/dbmi/drivers/stubs/bindupdate.c
src/libes/dbmi/drivers/stubs/close_cursor.c
Doxygen comments
Yes.
src/libes/g3d/g3dcache.c
src/libes/g3d/g3dclose.c
src/libes/g3d/g3drange.c
Yes.
src/libes/g3d/g3dresample.c
src/libes/g3d/g3dwindow.c
??? (AV)
Don't know.
src/libes/gis/Gmakefile
+ src/libes/gis/color_byg.c
+ src/libes/gis/win32_pipes.c
color_byg
win32_pipes
I18N
Yes.
src/libes/gis/datum.table
ETRS89 comment
Add "ire65" (Ireland 1965)
Probably.
src/libes/gis/ellipse.table
Enable "sphere"
Yes.
src/libes/gis/flate.c
Add zlib URL
Yes.
src/libes/gis/geo_init.c
Don't know.
src/libes/gis/get_ellipse.c
Allow e2 (eccentricity-squared) to equal zero (sphere case)
I18N
Yes.
src/libes/gis/state83
3200: x_0: 0.6e+06 -> 0.60960122e+06
Probably.
src/libes/gis/token.c
Add G_number_of_tokens()
Don't know.
src/libes/gis/closecell.c
src/libes/gis/env.c
src/libes/gis/fork.c
src/libes/gis/get_datum_name.c
src/libes/gis/gets.c
src/libes/gis/intr_char.c
src/libes/gis/list.c
src/libes/gis/mapset_msc.c
src/libes/gis/popen.c
src/libes/gis/remove.c
src/libes/gis/set_prior.c
src/libes/gis/system.c
src/libes/gis/unix_socks.c
src/libes/gis/user_config.c
src/libes/gis/whoami.c
MINGW32
No.
Yes (to the extent that it can be separated from the MINGW32 stuff)
Conditionalise SIGQUIT handling
Sort of (should fix types).
I18N
Yes.
src/libes/gis/G_dump.c
src/libes/gis/adj_cellhd.c
src/libes/gis/ask.c
src/libes/gis/ask_cell.c
src/libes/gis/auto_mask.c
src/libes/gis/cats.c
src/libes/gis/color_read.c
src/libes/gis/datum.c
src/libes/gis/done_msg.c
src/libes/gis/error.c
src/libes/gis/format.c
src/libes/gis/get_cellhd.c
src/libes/gis/get_datum.c
src/libes/gis/get_ell_name.c
src/libes/gis/get_projinfo.c
src/libes/gis/get_projname.c
src/libes/gis/get_row.c
src/libes/gis/get_window.c
src/libes/gis/gishelp.c
src/libes/gis/gisinit.c
src/libes/gis/histogram.c
src/libes/gis/history.c
src/libes/gis/home.c
src/libes/gis/legal_name.c
src/libes/gis/location.c
src/libes/gis/make_colr.c
src/libes/gis/mapset.c
src/libes/gis/mask_info.c
src/libes/gis/myname.c
src/libes/gis/null_val.c
src/libes/gis/opencell.c
src/libes/gis/parser.c
src/libes/gis/proj2.c
src/libes/gis/proj3.c
src/libes/gis/put_cellhd.c
src/libes/gis/put_row.c
src/libes/gis/put_title.c
src/libes/gis/quant_io.c
src/libes/gis/quant_rw.c
src/libes/gis/range.c
src/libes/gis/rd_cellhd.c
src/libes/gis/readsites.c
src/libes/gis/readsites_xyz.c
src/libes/gis/reclass.c
src/libes/gis/set_window.c
src/libes/gis/timestamp.c
src/libes/gis/view.c
+ locale/ru/LC_MESSAGES/libgis.po
I18N
Note: it's possible that some "real" changes were overlooked
Yes.
src/libes/imagery/ls_groups.c
Yes.
src/libes/imagery/vask_group.c
Increase field length 20 -> 30
Don't know.
src/libes/lock/lock.c
src/libes/lock/unlock.c
MINGW32
No.
src/libes/ogsf/GK2.c
src/libes/ogsf/GS2.c
src/libes/ogsf/gk.c
src/libes/ogsf/gpd.c
src/libes/ogsf/gsd_prim.c
src/libes/ogsf/local_proto.h
Don't know.
src/libes/proj/Gmakefile
src/libes/proj/do_proj.c
src/libes/proj/get_proj.c
- src/libes/proj/datum_shift.c
- src/libes/proj/do_proj_nad.c
Don't know.
src/libes/proj/pj_datums.c
src/libes/proj/pj_ellps.c
Add missing underscores
Don't know.
src/libes/raster/Gmakefile
src/libes/raster/io.c
src/libes/raster/new_io.c
src/libes/raster/parse_mon.c
+ locale/ru/LC_MESSAGES/libraster.po
I18N
Yes.
MINGW32
No.
src/libes/vask/V_exit.c
src/libes/vask/V_init.c
include config.h
Yes.
src/libes/vask/V_support.c
src/libes/vect32/Vlib/open1.c
src/libes/vect32/bin_digit/bin_digit.c
src/libes/vect32/georef/bin_point.c
src/libes/vect32/georef/bin_reg.c
src/libes/vect32/georef/set_key.c
src/libes/vect32_64/Vlib/open1.c
MINGW32
No/Sort of/Yes (as above).
src/mapdev/v.digit/Gmakefile
src/mapdev/v.digit/ask_driver.c
src/mapdev/v.digit/backdrop.c
src/mapdev/v.digit/bad_areas.c
src/mapdev/v.digit/break.c
src/mapdev/v.digit/build_neat.c
src/mapdev/v.digit/coll_pts.c
src/mapdev/v.digit/color.c
src/mapdev/v.digit/compress.c
src/mapdev/v.digit/contour.c
src/mapdev/v.digit/customize.c
src/mapdev/v.digit/debug.c
src/mapdev/v.digit/dig_curses.c
src/mapdev/v.digit/dig_dev.c
src/mapdev/v.digit/digitize.c
src/mapdev/v.digit/digmain.c
src/mapdev/v.digit/duplicate.c
src/mapdev/v.digit/edit.c
src/mapdev/v.digit/eq.c
src/mapdev/v.digit/find_w_dig.c
src/mapdev/v.digit/find_w_mouse.c
src/mapdev/v.digit/get_point.c
src/mapdev/v.digit/graph_input.c
src/mapdev/v.digit/head_info.c
src/mapdev/v.digit/help.c
src/mapdev/v.digit/initialize.c
src/mapdev/v.digit/interact.c
src/mapdev/v.digit/intersect.c
src/mapdev/v.digit/label.c
src/mapdev/v.digit/label_mult.c
src/mapdev/v.digit/leave.c
src/mapdev/v.digit/list.c
src/mapdev/v.digit/main.c
src/mapdev/v.digit/map_ask.c
src/mapdev/v.digit/map_ask_new.c
src/mapdev/v.digit/map_coor_new.c
src/mapdev/v.digit/map_init_new.c
src/mapdev/v.digit/map_reg.c
src/mapdev/v.digit/map_residnew.c
src/mapdev/v.digit/map_scale.c
src/mapdev/v.digit/menus.c
src/mapdev/v.digit/mk_window.c
src/mapdev/v.digit/mouse_coll.c
src/mapdev/v.digit/mouse_yn.c
src/mapdev/v.digit/move_line.c
src/mapdev/v.digit/move_point.c
src/mapdev/v.digit/node_lines.c
src/mapdev/v.digit/overlay.c
src/mapdev/v.digit/read_cap.c
src/mapdev/v.digit/remove.c
src/mapdev/v.digit/remove_block.c
src/mapdev/v.digit/replot.c
src/mapdev/v.digit/reset_map.c
src/mapdev/v.digit/retype_line.c
src/mapdev/v.digit/scal_window.c
src/mapdev/v.digit/select_digit.c
src/mapdev/v.digit/set_thresh.c
src/mapdev/v.digit/set_window.c
src/mapdev/v.digit/slid_window.c
src/mapdev/v.digit/snap.c
src/mapdev/v.digit/spline.c
src/mapdev/v.digit/toolbox.c
src/mapdev/v.digit/where_am_i.c
src/mapdev/v.digit/window.c
src/mapdev/v.digit/window_rout.c
src/mapdev/v.digit/window_setup.c
src/mapdev/v.digit/withinthresh.c
+ locale/ru/LC_MESSAGES/v.digit.po
I18N
Probably.
src/mapdev/v.in.dgn/Gmakefile
src/mapdev/v.in.dgn/README
src/mapdev/v.in.dgn/main.c
Don't know.
src/mapdev/v.label/main.c
Tidy
Yes.
html/html/m.in.e00.html
src/misc/m.in.e00/info.c
src/misc/m.in.e00/main.c
list=
Don't know.
src/misc/m.proj/geo_func.c
src/misc/m.proj/local_proto.h
src/misc/m.proj/main.c
src/misc/m.proj/process.c
src/misc/m.proj2/geo_func.c
src/misc/m.proj2/input.c
src/misc/m.proj2/local_proto.h
src/misc/m.proj2/main.c
src/misc/m.proj2/process.c
Don't know.
html/html/ps.map.html
src/ps.map/ps.map/cmd/Gmakefile
src/ps.map/ps.map/cmd/colortable.h
src/ps.map/ps.map/cmd/ctablfile.c
src/ps.map/ps.map/cmd/eps.c
src/ps.map/ps.map/cmd/local_proto.h
src/ps.map/ps.map/cmd/ps_area.c
src/ps.map/ps.map/cmd/ps_map.c
src/ps.map/ps.map/cmd/read_cfg.c
src/ps.map/ps.map/cmd/vectfile.c
src/ps.map/ps.map/cmd/vector.h
+ src/ps.map/ps.map/cmd/ps_fclrtbl.c
(colortable) height
(vector) pat, pwidth, scale
Support colour tables for FP maps
Probably.
html/html/r.colors.html
src/raster/r.colors/cmd/main.c
color=byg
Yes.
src/raster/r.in.gdal/gbgetsymbol.c
src/raster/r.in.gdal/gdalbridge.c
#ifndef USE_GDAL_H
Yes.
src/raster/r.in.gdal/gdalbridge.h
GDALGetDriverShortName
GDALGetDriverLongName
GDALGetDatasetDriver
Probably.
src/raster/r.in.gdal/main.c
Remove bogus parm.target->gisprompt setting
Yes.
AVHRR
Probably.
src/raster/r.mapcalc3/evaluate.c
src/raster/r.mapcalc3/expression.c
src/raster/r.mapcalc3/expression.h
src/raster/r.mapcalc3/map.c
src/raster/r.mapcalc3/mapcalc.h
src/raster/r.mapcalc3/mapcalc.y
Remove debug output
Write expression to map history
Distinguish functions from infix operators
Change print_* (write to stream) to format_* (convert to string)
Improve formatting
Make to_{int,float,double} static (don't export)
Add missing break statement to column_shift()
Add missing semicolon to mapcalc.y (for recent versions of bison)
Yes.
html/html/r.neighbors.html
src/tcltkgrass/module/r.neighbors
src/raster/r.neighbors/cmd/Gmakefile
src/raster/r.neighbors/cmd/main.c
src/raster/r.neighbors/cmd/method.h
+ src/raster/r.neighbors/cmd/c_sum.c
method=sum
Probably.
html/html/r.proj.html
html/html/s.proj.html
html/html/v.proj.html
src/tcltkgrass/module/v.proj
src/raster/r.proj/cmd/bordwalk.c
src/raster/r.proj/cmd/main.c
src/sites/s.proj/main.c
src/mapdev/v.proj/local_proto.h
src/mapdev/v.proj/main.c
Don't know.
Remove m.proj xref
Don't know.
Fix v.proj tcltkgrass module
Yes.
src/raster/r.sunmask/main.c
Write history
Probably.
src/raster/r.transect/cmd/main.c
Fix r.transect invocation
Probably.
src/raster/r.weight/inter/gis_pars.y
Add missing semicolons (for recent versions of bison)
Yes.
src/scripts/contrib/d.monsize/d.monsize
Yes.
src/scripts/contrib/d.rast.labels/d.rast.labels
src/scripts/contrib/i.tm.dehaze/i.tm.dehaze
src/scripts/contrib/r.fillnulls/r.fillnulls
src/scripts/contrib/s.in.atkisdgm/s.in.atkisdgm
src/scripts/contrib/s.in.atkisdgm/s.in.atkisktb
src/scripts/contrib/v.xfig/fig2grass
src/scripts/shells/slide.show.sh
Remove "function" keyword (bash-ism)
Yes.
src/scripts/contrib/d.rast.leg/d.rast.leg
Don't know.
src/scripts/contrib/grassmirrorsmap/README
src/scripts/contrib/grassmirrorsmap/grass.sites.main
src/scripts/contrib/grassmirrorsmap/grass.sites.mirror
src/scripts/contrib/grassmirrorsmap/grass_sites.gif
src/scripts/contrib/grassmirrorsmap/grass_sites.htmlmap
src/scripts/contrib/grassmirrorsmap/grassmap.html
src/scripts/contrib/grassmirrorsmap/mkgrassmap.sh
Don't know.
src/scripts/contrib/i.image.mosaic/i.image.mosaic
Don't know.
src/scripts/contrib/r.to.pg/r.to.pg
Don't know.
src/scripts/contrib/r.univar/r.univar
Don't know.
src/sites/s.surf.rst/main.c
Remove startup message
I18N
Yes.
src/tcltkgrass/main/gis_set.tcl
src/tcltkgrass/tcltkgrass
+ locale/ru/tcltkgrass/
I18N
No.
src/tcltkgrass/main/menu.tcl
Add d.dm, s.cellstats, r.in.ascii
Change v.proj description
Probably. BTW, shouldn't there be an interface to r.proj?
html/html/d.legend.html
src/tcltkgrass/module/d.legend
-o, maxfontsize=
No. But the man page and module *should* reflect the program (d.legend
is now d.leg.thin).
src/tcltkgrass/todo/r.colortool/r.colortool
Get location info from g.gisenv
Yes.
+ html/html/s.cellstats.html
+ src/sites/s.cellstats/
+ src/tcltkgrass/module/s.cellstats
Added+ html/html/s.kernel.html
+ src/sites/s.kernel/
Added+ src/raster/r.series/
Added+ src.contrib/DUKE/
Added (r.terraflow)+ tools/sql.sh
Added+ locale/README.koi
+ locale/templates/
Added+ src.contrib/GMSL/r.simwe/
Added+ src.nonGPL/
Removed from release branch
Probably.
> ???Don't know.
2002-08-27 19:19 eric
* get_num.c, local_proto.h, main.c: Projection code cleanups: *
changes to reflect changes in geo.h and geo_init.c * copy some
globals from geo.h back here where they are used.
> src/include/geo.h
> ???Don't know.
2002-08-27 19:12 eric
* geo.h: Baby steps to cleaning up projection code: * move
definition of global structs to geo_init.c * remove/comment
several globals that shouldn't be here. * Add a couple function
prototypes for geo_init.c
> ???Don't know.
2002-11-10 14:46 eric
* geo_init.c: Only ask for "south" in UPS. All else is
predefined...
2002-08-27 19:17 eric
* geo_init.c: Projection code clean up: * define a couple global
structs here (rather than geo.h) * eliminate init_units() function
by making UNITS table defined and intialiazed at compilation (as
const struct). * make DESC table constant with initializing
strings paired with corresponding #define symbol from geo.h for
documentation. * rename functions with G_geo_ prefix to indicate
gislib membership. * comment out unused variables/functions that
don't belong in gislib.
Note that these changes were also reflected in some small changes to
[rsv].proj. And those functions have been further modified for the
changes to libproj support for datum transformations. Most of my
changes above aren't really significant changes in functionality, but
the changes need to be kept in sync with the few modules that are
impacted. Mostly I was trying to clean up the interface a little (it
seemed really wrong to me the way global variables were defined in
library units but used *only* by some modules).
echo ">gra.fcw@2ztr< eryyvZ .T pveR" | rot13 | reverse
> -o, maxfontsize=No. But the man page and module *should* reflect the program
I'll get around to fixing these soon ..
(d.legend is now d.leg.thin).
is it? Not knowing the history, I'm a little confused.
from src/display/d.leg.thin/README [which I need to update as well]:
"this is d.legend (formerly d.leg.thin)."
and from src/display/d.legend/Attic/Gmakefile
"FILE REMOVED [...] replaced by d.leg.thin, which becomes d.legend"
so d.legend was replaced by d.leg.thin, which is labeled and runs as
d.legend if I've got that right.
src/display/d.leg.thin builds into d.legend anyway. As the html & tcl
files should match whatever the executable is named, and "d.legend"
seems to me to be a more suitable name for the executable..
I suppose all this is to reduce confusion between the new d.legend [aka
d.leg.thin] and the old [4.3?] d.legend which was a different program???
regards,
Hamish
On Sunday 02 February 2003 10:13 pm, Glynn Clements wrote:
ne.
html/html/d.dm.html
Add PNG button
Package number of BWidget is important, PNG should be harmless -> yes.
It was bugfix -> yes.
Requires dgnlib which is not located by configure -> no.
(colortable) height
New features which should not break old options -> yes.
> > -o, maxfontsize=
> No. But the man page and module *should* reflect the programI'll get around to fixing these soon ..
"this is d.legend (formerly d.leg.thin)."and from src/display/d.legend/Attic/Gmakefile
"FILE REMOVED [...] replaced by d.leg.thin, which becomes d.legend"so d.legend was replaced by d.leg.thin, which is labeled and runs as
d.legend if I've got that right.src/display/d.leg.thin builds into d.legend anyway. As the html & tcl
seems to me to be a more suitable name for the executable..I suppose all this is to reduce confusion between the new d.legend [aka
Once upon a time there were d.legend *and* d.leg.thin (a try for a better
implementation of d.legend). Then I merged both, in fact I merged a few good
pieces of d.legend into d.leg.thin and renamed it in Gmakefile to d.legend
(to avoid user's confusion as a d.leg.thin without d.legend didn't make
sense).
That's why d.legend continued to live in src/display/d.leg.thin (but
in the Gmakefile it is called d.legend).
Yes, a bit confusing. But today only the directory name is confusing.
Hope this clarifies it. In 5.1 we should store it into
display/d.legend
> NEWS.html
> README
> SUBMITTING
> binaryInstall.src
> Documentation changesProbably.
Yes - useful and important updates.
> Add more modulesProbably.
Yes - nothing dangerous.
> Fix URLsProbably.
Yes.
> xrefsProbably.
Yes.
> -v, -A
> HTML tidyingProbably.
Yes.
> html/index.html
> index2.html -> index.htmlDon't know.
Yes (index2.html doesn't exist any more on the web)
> EPSG linkProbably.
Yes (useful)
> Remove query_postgr_{orig,dummy}.cDon't know.
> ???Don't know.
AFAIK this simplifies the PG dependency.
Didn't cause problems here so far.
> Default to cwd instead of $HOMENo; use built-in "pwd" rather than "exec pwd".
Should the suggestion be uploaded?
> ???Don't know.
Mostly IRIX fixes from Paul, I think.
> HOWTO - Adding new header files from tcl/tkProbably.
Yes.
> Add Tk 8.4 supportYes (togl.c was already updated in 5.0.1, but these files were missing).
Yes.
> ??? (AV)Probably (g3d isn't built by default, so compatibility isn't an issue).
Yes. Only then we can move reasonably forward with G3D (when spreading the
improvements)
Yes.
> Disable v.in.arc.pgDon't know.
Yes. v.in.arc.pg should not be used, instead
v.in.shape + pg.in.dbf
Yes, reflecting above change.
> src/CMD/VERSION
> 5.0.1 -> 5.0.2-cvsChange to 5.0.2 for release.
Right.
> Improved error message in case of compilation errorsProbably.
Yes (just cosmetics). Works well.
> Allow C++ files (incomplete)Don't know.
Wasn't the logic fixed recently?
> Command mode
> Add $(MATHLIB)
> Change freetypecap defaultsProbably (d.text.freetype is fairly new).
IMHO yes.
> ???Don't know.
2002-07-22 15:18 markus
* src/display/d.vect/cmd/plotCat.c: added missing stdlib.h for atoi
2002-07-17 13:14 radim
* src/display/d.vect/cmd/: main.c, plot2.c, plotCat.c: fix small
areas on level1 not plotted
yes.
> ???Don't know.
This is the flashing sites when selecting a site.
Don't know.
> ???Don't know.
This is the flashing polygon/line when selecting a vector.
Don't know.
> addmapset=Don't know.
Yes, useful & tested.
> Don't call pj_zero_proj()Don't know (related to generalised datum transformations?)
related to generalised datum transformations.
What do you think, Paul?
> Trap signalsDon't know.
I have added this to avoid that GRASS continues when the user
hits CTRL-C while defining a new location. I never liked that
GRASS continues and generates a broken new location, when
I try to stop the create-location procedure.
So, IMHO yes.
> ???Don't know.
This was a try to avoid i.ortho.photo startup crashes.
Better now than before. Not dangerous.
So, IMHO yes.
> Error messagesNo.
2002-09-24 14:57 markus
* src/imagery/i.ortho.photo/photo.rectify/write.c: changed write
error to strerror(errno) as suggested by Glynn
Is this dangerous? Of yes, it should be also reverted in HEAD.
> src/include/geo.h
> ???Don't know.
> color_byg.cYes.
> G__getsome
> G_number_of_tokensDon't know.
G_number_of_tokens is needed by g.mapsets add= and is just a shift
of a function into the library.
G_number_of_tokens(): Yes.
G__getsome: ? no idea
> ??? (AV)Don't know.
Yes, when we accept the other G3D changes. I vote for yes.
> Enable "sphere"Yes.
Note that "sphere" doesn't seem to work (will have to retry).
> ???Don't know.
2002-11-10 23:46 eric
* src/libes/gis/geo_init.c: Only ask for "south" in UPS. All else
is predefined...
Eric (maybe already answered in another mail)?
> 3200: x_0: 0.6e+06 -> 0.60960122e+06Probably.
> Add G_number_of_tokens()Don't know.
Yes, see above.
> Increase field length 20 -> 30Don't know.
Allow for longer group names. No problems so far.
> src/libes/ogsf/gk.c
> ???Don't know.
2002-11-02 17:39 markus
* src/libes/ogsf/: GK2.c, GS2.c, gk.c, gpd.c, gsd_prim.c,
local_proto.h:
Date: Fri, 18 Oct 2002 12:27:02 -0300 From: Bob Covill
<bcovill@tekmap.ns.ca> Subject: NVIZ update
The changes are running well here for quite a while.
New fixes/improvements are arriving soon from Bob.
If I am not the only one working with NVIZ from HEAD,
I would say: yes.
> list=
> ???Don't know.
2002-07-19 22:51 roger
* src/misc/m.in.e00/: info.c, main.c: Added the list= parameter and
corrected a format that was invalid for large INFO tables
Don't know as well.
> ???Don't know.
m.proj might be completely taken off if datum transformation is accepted.
m.proj2 fixes are from Eric and Paul.
> GDALGetDatasetDriverProbably.
2002-10-07 22:13 glynn
* src/raster/r.in.gdal/gdalbridge.h: Add declarations for
GDALGetDriver{Short,Long}Name, GDALGetDatasetDriver [fix submitted
by Paul Kelly]
IMHO yes.
> Remove bogus parm.target->gisprompt settingYes.
> AVHRR
Probably.
Yes.
> method=sumProbably.
Yes (harmless).
> Generalised datum transformationsDon't know.
Paul
> Write historyProbably.
2002-09-24 14:53 markus
* src/raster/r.sunmask/main.c: added history write functions. But
long lines are still truncated, we should improve the library
function
Yes (better than nothing), useful get stored the sun position parameters.
> Fix r.transect invocationProbably.
2002-09-24 14:44 markus
* src/raster/r.transect/cmd/main.c: fixed wrong r.profile call,
should have gone into 5.0.0
yes.
> ???Don't know.
Cosmetics to this script.
Yes.
> ???Don't know.
Yes, new mirror sites added.
> ???Don't know.
2002-09-24 14:43 markus
* src/scripts/contrib/i.image.mosaic/i.image.mosaic: some fixes for
2 maps composites, needs to be done for 3 and 4 maps - see top of
file
> ???Don't know.
2002-10-30 09:51 markus
* src/scripts/contrib/r.to.pg/r.to.pg: removed the word 'function'
everywhere (to make scripts cygwin compliant)
2002-08-02 16:59 markus
* src/scripts/contrib/r.to.pg/r.to.pg: Otto Dassau: cats/ID support
added
Yes, useful.
> ???Don't know.
* src/scripts/contrib/r.univar/r.univar: removed the word
'function' everywhere (to make scripts cygwin compliant)
Yes.
2002-10-23 12:06 markus
* src/scripts/contrib/r.univar/r.univar: added median, 1st and 3rd
quartile
No. It slows heavily down the script, so should be discussed first.
In any case a C implementation were much (!) better (maybe based on
s.univar).
> Change v.proj descriptionProbably. BTW, shouldn't there be an interface to r.proj?
Yes. Have added interface to r.proj and s.proj now.
> Added
> Added
> Added
> + src.contrib/DUKE/
> Added (r.terraflow)
> + tools/sql.sh
> Added
> + locale/README.koi
> + locale/templates/
> Added
All yes.
> Added
No (not yet). The authors want to finalize it first.
> + src.nonGPL/
Yes.
> Don't know.Mostly IRIX fixes from Paul, I think.
For some of the files yes that would be the most recent change, but the
bugs I fixed had only been introduced recently so there were other changes by
other people behind those.
> Don't know (related to generalised datum transformations?)related to generalised datum transformations.
Not tested enough yet. These are the modules that use proj but don't need
to do datum transformations. Need further changes in light of Bob's
testing.
I try to stop the create-location procedure.So, IMHO yes.
But what if someone only wants to start GRASS so they can read the man
pages or use g.help? Or use another command that creates a location, like
r.in.gdal?
> > Enable "sphere"
> Yes.Note that "sphere" doesn't seem to work (will have to retry).
What do you mean in particular? I could keep this in mind while I'm
looking over the projection functions, not promising anything though
> Don't know.m.proj might be completely taken off if datum transformation is accepted.
I didn't change anything in m.proj2 except delete the line from the TODO
file that said a datum is silently ignored.
by Paul Kelly]IMHO yes.
This probably should have been on the release branch already.
r.in.gdal doesn't compile on IRIX otherwise.
> Don't know.Paul
Well [rsv].proj seem to work fairly well but we still need to test a bit
more the other programs that use the proj library (see above). And there
will be further improvements. So if the aim of this is creating a new
ultra-stable release branch none of this should go in. But then it won't
really get tested.
I really like the idea of making releases from HEAD, and if someone
reports a bug we can fix it and tell them to get the next CVS snapshot.
But having stable releases is a good motivation for people to build
binaries for obscure platforms.
Paul
> So, IMHO yes.
r.in.gdal?
Maybe my answer was not clear. I was talking about the (rare?) case
that someone hits CTRL-C while generating a new location interactively.
The old behaviour was to leave the coordinate-definition screen and
just enter GRASS (with totally useless PROJ_* files and DEFAULT_WIND
files). As the user (like me) hit CTRL-C, he may want to break the procedure
and leave GRASS.
Now, the create-location procedure is really interrupted if someone hits
CTRL-C.
Hope this explains the idea of the minimal change.
> > > Enable "sphere"
> > Yes.
I tried to find a difference when projecting to WGS84 and sphere, there
was none. Maybe I made a mistake, but I didn't try your latest changes
on this problem.
I have mistakenly emailed this just to Glynn, but some comments from
others would be useful
so I am re-sending it to the list.
Helena
> changes marked "Probably" or "Don't know".> src.contrib/GMSL/NVIZ2.2/scripts/panel_kanimator.tcl
>>Don't know.> src/libes/ogsf/GK2.c
> src/libes/ogsf/gk.c
>>Don't know.
I assume that the above are Bob's improvements and they need some
testing.
We will try this week but getting more people to try it would help.
I have put a copy of Bob's message at the end - testing keyframe
animations may be harder for those who haven't done it before
but testing the large site files is easy and it makes a big difference
if you have million points (e.g. from LIDAR) and want to zoom into
a small place. So if these work they should be included.
> ??? (AV)>>Probably (g3d isn't built by default, so compatibility isn't an issue).
> ??? (AV)>>Don't know.
These are probably important fixes by Alfonso Vitti so they should be
included - Alfonso, John Harrop, Jaro, and whoever had a chance to work
with it can
you comment on it?
> + src.contrib/DUKE/
> Added (r.terraflow)
> Added>>Probably.
these are new modules - they work but they are being further developed
and could benefit from testing. So they can be included but I suggest
that they are in the same category as the g3d stuff - not being built
by defualt.
Helena
Bob's message:Hello,
Markus has applied some of my recent NVIZ changes to CVS. These changes
include:1. Ability to save and load key frame animations.
2. Changes to the DIR[XYZ] keyframe mask to use the center of view in
this field. Now both the eye and center of view can be changed in an
animation.3. Changes to the "Run and Save" key frame menu to allow user supplied
frame starting numbers. This will allow users to do animations in
sections and start one where the other left off (for example at frame
no. 1051). The numbers are also formatted to 4 digits to allow
compatibility with the gimp animation tool. Note that the "off-screen"
option is disabled in this menu (see below).4. Accelerated drawing of sites by skipping sites outside of the current
viewport. This routine can be applied at a later date to vectors and
rasters.5. Changed near and far clip defaults to allow closer and farther views
respectively without being clipped.6. Added a new display canvas for interactively moving the center of
view (similar to "look here"). This and the eye position canvas are
activated by radiobuttons. The canvases include call-backs to get and
set the canvas cursor to match the respective
position.7. The code for off-screen rendering is also included, but commented
out. The off-screen rendering draws to off-screen pbuffers, thus
allowing rendering to be done undisturbed by screen savers, other
windows, etc. This routine is still fairly new and requires a bit more
work. For those wishing to try the off-screen rendering use a compile
flag #define OS_RENDER to build the ogsf library and nvwish. The version
is compatible with GLX v.1.3, earlier versions will probably not work.
To enable off-screen rendering use "Noff_screen 1". When finished use
"Noff_screen 0" to destroy the pbuffer visual. Note that the togl window
should be minimized before calling Noff_screen 1. This ensures that the
pbuffer remains the currently selected visual.If you have any question, comments or problems with the above please let
me know.Also, for those interested I have got a good portion of the 3dview stuff
working in nviz. This is the saving and loading of 3d views. If anyone
is interested in testing what I have so far, please let me know.
> > html/index.html
> Don't know.Yes (index2.html doesn't exist any more on the web)
If the URLs are meant to refer to the GRASS website, they should be
absolute URLs. Bear in mind that these files are installed into
$GISBASE/documents; relative URLs should only be used when the target
is also in $GISBASE/documents.
I think that I was getting confused with the following (from
html/index.html):
<a href="../nviz/index.html">nviz visualization tool tutorial</A>
This URL is wrong for a local copy of index.html (".." doesn't make
any sense from the top-level directory); it should be:
<a href="nviz/index.html">nviz visualization tool tutorial</A>
If the GRASS website is layed out differently, then the file should be
pre-processed for use on the web site.
> Don't know.
> Don't know.AFAIK this simplifies the PG dependency.
The doconfigure simplification is good; however, there appear to be
some other changes which I'm unsure about.
> No; use built-in "pwd" rather than "exec pwd".Should the suggestion be uploaded?
I think so.
I think that most of this (along with the ogsf changes) was a
substantial update from Bob Covill.
> Don't know.Wasn't the logic fixed recently?
It was "fixed" so as to be harmless (the first attempt broke the case
when the .c file was generated, e.g. by lex/yacc). However, it's far
from correct: C++ files should use $(CXX) instead of $(CC), and
$(CXXFLAGS) instead of $(CFLAGS). This would require changes to
several other files (configure[.in], head.in).
See my previous message:
Subject: Re: [GRASS5] C++ compilation
Date: Thu, 23 Jan 2003 21:43:40 +0000
Message-ID: <15920.25100.848724.42087@cerise.nosuchdomain.co.uk>
Paul says not yet, so no.
> > Trap signals
> Don't know.I have added this to avoid that GRASS continues when the user
Doesn't this belong in Init.sh, then? That's where the code in
question is.
> > Error messages
> No.2002-09-24 14:57 markus
error to strerror(errno) as suggested by GlynnIs this dangerous? Of yes, it should be also reverted in HEAD.
Two issues: Regarding the first message, I don't know how portable
strerror() is; older BSDs don't have it.
Regarding the second, the message is over 80 characters; also, you
could reasonably argue for adding the same message to every module
which writes files (i.e. most modules), which is really an argument
for putting it lower down. Also, permissions definitely aren't an
issue, as they are checked upon open and not upon write.
> > G__getsome
> > G_number_of_tokens
> Don't know.G_number_of_tokens is needed by g.mapsets add= and is just a shift
OK.
> > Enable "sphere"
Please do.
> Don't know.Allow for longer group names. No problems so far.
OK, then yes.
Yes we can do this (see below).
> ???Don't know.
> src/libes/ogsf/gk.c
> ???Don't know.
The above changes (GMSL & ogsf) are probably what Markus applied for me
(exception of getCat.c) to implement accelerated surface and sights
drawing, enhanced animation tools, etc. Markus is currently checking a
"cleaned up" version of these, before applying I will fix the
fileBrowser.tcl as noted above.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill@tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
> by Paul Kelly]
> IMHO yes.This probably should have been on the release branch already.
AFAICT, this part is tied to the changes which I labelled "AVHRR" for
src/raster/r.in.gdal/main.c. Both sets of changes have to be made
together, otherwise it won't compile on anything (unless you use
--with-gdal).
The IRIX-specific problem was due to:
#if defined(__unix__)
This has since been changed to:
#if defined(__unix) || defined(__unix__)
This change made it into 5.0.0.
I'll leave the projection stuff out for now.
> > > > Enable "sphere"
> > > Yes.
> looking over the projection functions, not promising anything thoughI tried to find a difference when projecting to WGS84 and sphere, there
on this problem.
This sounds as if the ellipsoid is simply being ignored, rather than a
problem specific to "sphere".
The most likely problem with a sphere is a division by zero if
something tries to divide by either the eccentricity or flattening.
On Mon, 3 Feb 2003 14:44:12 +0100
> Don't know.Cosmetics to this script.
Yes.
actually, probably not. It's broken for non-FP rasters right now due to the -o flag (which never made it out of HEAD) becoming -n, but it seems to have some related logic problems as well.
I wasn't aware this script existed until now, but will see what I can whip up.
Hamish
> Is this dangerous? Of yes, it should be also reverted in HEAD.Two issues: Regarding the first message, I don't know how portable
strerror has been around for some time: documented in K&R 2 (1988) and
is ANSI C. If it becomes an issue, add a macro.
#if !defined(HAS_STRERROR)
#define strerror(e) "??!??'??>"
#endif
Okay, maybe no trigraphs... |^}
> > > html/index.html
> > Don't know.
> Yes (index2.html doesn't exist any more on the web)If the URLs are meant to refer to the GRASS website, they should be
is also in $GISBASE/documents.I think that I was getting confused with the following (from
html/index.html):<a href="../nviz/index.html">nviz visualization tool tutorial</A>
any sense from the top-level directory); it should be:<a href="nviz/index.html">nviz visualization tool tutorial</A>
I agree that the current file organization is a bit messy.
If someone updates the docs as desired/proposed, I'll fix the cronjobs
on grass.itc.it subsequently.
> > Don't know.
> Wasn't the logic fixed recently?It was "fixed" so as to be harmless (the first attempt broke the case
several other files (configure[.in], head.in).See my previous message:
Ok, but if harmless we could upload it to enable people to compile
r.terraflow.
> > > Trap signals
> > Don't know.
> So, IMHO yes.Doesn't this belong in Init.sh, then? That's where the code in
question is.
Maybe. But it already works. So probably we should add is additionally
to Init.sh?
The line in question is:
trap "echo 'User break!' ; exit" 2 3 9 15
> > > Error messages
> > No.
strerror() is; older BSDs don't have it.Regarding the second, the message is over 80 characters; also, you
Ok, sounds as if it should be reverted.
> > > Enable "sphere"
> > Yes.
> Note that "sphere" doesn't seem to work (will have to retry).Please do.
Will do.
> > > > Trap signals
> > > Don't know.
> > So, IMHO yes.
> question is.Maybe. But it already works. So probably we should add is additionally
to Init.sh?
Actually, I can't see how this is meant to work. A "trap" command only
affects the signal handling of the shell itself; signal handlers are
reset when spawning a child process.
BTW, bash seems to have some "magic" in the way that it handles
terminal signals. When you press (by default) Ctrl-C, the terminal
driver sends SIGINT to all processes in the foreground process group
(this will consist of grass5, Init.sh, and anything called from
Init.sh). If a child process traps the signal and returns normally,
bash ignores the signal; OTOH, if the child process dies on the
signal, bash allows the signal to be processed (i.e. calling the
handler specified by "trap", or dying if no handler was installed).
OTOH, ash doesn't do this, and it's quite possible that other shells
won't. The way in which bash behaves isn't necessarily a good
indicator of how Bourne shells behave generally.
More generally, the grass5 script should probably be reduced to just:
#!/bin/sh
GISBASE=/opt/grass5
export GISBASE
exec "$GISBASE/etc/Init.sh" "$@"
with everything else moved to Init.sh. This would allow for invoking
grass5 with an argument which contains spaces (this won't work at
present, due to the way in which Init.sh is invoked). It also uses one
less process.
There's also the issue that, even if Init.sh handles set_data being
killed, set_data will still leave a broken location behind. That can't
be fixed in Init.sh; it would have to be fixed in set_data.
An updated version is attached. This reflects the situation after the
recent sync; that consisted of whole-file changes, i.e. new files, or
files which were replaced by the version from the CVS head.
The remaining differences correspond to cases where one or more of the
following apply:
1. The author advised against inclusion.
2. I advised against inclusion.
3. The significance of the change isn't immediately obvious, and
nobody specifically recommended inclusion.
4. There are multiple changes to a single file, and at least one of
the changes is subject to 1-3 above.
5. The change was made since the merge.
Some of these may yet make it into 5.0.2, mostly depending upon
someone being willing to advocate inclusion.
grass-diff.txt (11.4 KB)
On Wed, Feb 12, 2003 at 10:41:23AM +0000, Glynn Clements wrote:
Content-Description: message body and .signature
Thanks for your efforts, Glynn!
- html/html/v.rm.dangles.html
Removedhtml/vector.html
Remove v.rm.dangles xref
The both above may go into 5.0.2. It simply fixes the problem
that the man page was not written earlier.
-ehtml/html/r.fillnulls.html
html/html/r.flow.html
html/html/r.flowmd.html
html/html/s.surf.rst.html
html/html/s.vol.rst.html
html/html/v.surf.rst.html
Change URLs (NCSU -> UIUC)
The old server is dead. That's why the updated urls should
reach 5.0.2.
html/html/r.out.ascii.html
-M -> -s
ASCII -> binary
input -> inout
??? this doesn't appear to make sense, or agree with the source code
In my HEAD version I have
r.out.ascii help
Description:
Converts a raster map layer into an ASCII text file.
Usage:
r.out.ascii [-hsMi] input=name [output=name] [dp=value] [width=value]
[null=name]
Flags:
-h Suppress printing of header information
-s Write SURFER (Golden Software) ASCII grid
-M Write MODFLOW (USGS) ASCII array
-i Force output of integer values
Parameters:
input Name of an existing raster map
output Name of an output ASCII grid map (use out=- for stdout)
dp Number of significant digits (floating point only)
width Number of values printed before wrapping a line
null String to represent null cell (GRASS grid only)
default: *
And
reflects this (since some days) [another reason to use G_usage_html()].
html/index.html
Why not? The page index2.html doesn't exist any more.
I vote for yes.
This was requested a few times on the user list, maybe we can
add it.
list=
...Roger Miller, if I recall correctly.
I vote for no.
-o, maxfontsize=
Being author of -o, maxfontsize=, I vote for eliminating them.
The module is in hands of Hamish Bowman now.
So: yes.
