Hi Bernhard!
Nice to meet you in this list!
Really nobody from the developers reads the users lists and looks
thorough my patches. Finally I got grass5.0beta4 compiled here on the
alphas OSF1 v4.0d with Dec's CC using strict ANSI mode.
Thanks for the patches! You know I am reading/writing to the list
daily and try to catch everything. This should be done coordinated
by several people in my opinion, not just by me.
> supercede my last two patch posts to the users list. The problems
> were not fixed in the mean time, apart from three of my last patch
> post.
Reason was, that you build your patches on beta3 although we already
had beta4m (or something). As I am currently doing all this versioning
manually (yes, we NEED an CVS, but I cannot manage that additionally),
I did not find the time to pick out the relevant changes.
Perhaps you can create an CVS for us? I am just geographer,
not programmer. This code management by hand is a hard job
which I do not want to do for much more time. On the other
hand I am afraid that suggestions get lost, therefore I am
still doing it. Beta5a will contain your changes and some
more I already got from Bill Brown and from the user's list.
O.k. - who can take care for the CVS from the team?
I cannot manage that.
If we have a versioning system a lot of problems will disappear!
Best regards
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 2020
max: 0
Greetings all,
Well, everyone will have their own user account on grass.baylor.edu
by a little later today. Use your last name as your login with your
lastname as passwd. There will be a README file in your home
directories that tells the directory structure of the machine for our
purposes. We'll have an area that all have permission to for storing
and sharing files and such. I'll let everyone know when we get it
on-line.
Bruce
Bernhard Reiter wrote:
Hi Markus,
Thanks for inviting me.
True, we need someone, who puts the patches in a ftp directory
as fast as they come available somewhere. So that developers and
interested hackers can test them.
> > post.
That, why they are patches. You can easily see if they apply.
patch --dry-run should help you next time.
Do you already have a server?
Just looking for the maintainer?
It will create some overhead in the beginning.
I cannot decide to do it right now, but maybe we can search for
someone who wants to do it.
Bernhard
Research Assistant, Geog Dept UM-Milwaukee, USA. (www.uwm.edu/~bernhard)
Free Software Projects and Consulting (intevation.de)
Part 1.2Type: application/pgp-signature
length: 3987
max: 0
I do not know if it is already fixed, but in any case I uploaded into
the incoming dir here at geog.uni-hannover.de a patch to r.mask. The
patch does the following:
- fixes the segfaulting on exit
- fixes the appearance of the category windows
by correctly initializing *char_table
- fflushes the stdout
- on mask removing changes the pausing from 3 to 1 sec
bye
Luca
--> Luca Palmeri - Dip. Proc. Chimici dell'Ingengeria
Universita' di Padova TEL: +390498275527 -------
------------------------- FAX: +390498275528 -------
--> Think holistic @ the end of the 2nd millenium <--
length: 2081
max: 0
Hi there,
it is time for a new beta internal package...
What's new:
- src/sites/v.surf.rst (Markus)
updated to reflect ../interp_float/ - working now!!
- r.mask fixed in (Luca)
src/raster/r.reclass/inter/
- src.contrib/GMSL/NVIZ2.2/src/togl_cb.c (Pierre)
commented lines 44, 73: fixes red flicker bug when moving
over NVIZ graphical window
- src.contrib/GMSL/NVIZ2.2/NVIZ2.2-UPDATE (Pierre)
src/libes/ogsf/GS.c
src.contrib/GMSL/NVIZ2.2/Gmakefile.in
src.contrib/GMSL/NVIZ2.2/scripts/panel_main.tcl
src.contrib/GMSL/NVIZ2.2/src/Gmakefile.in
src.contrib/GMSL/NVIZ2.2/src/change_view.c
src.contrib/GMSL/NVIZ2.2/src/glwrappers.c
This update corrects the following problems:
- Screen redrawn in wire mode when mouse passes over vertical sliders.
- Also a potential problem with colors in glwrappers.c
(adress of a local variable returned in color selection)
- Modified intersection function to allow the "look here"
functionality and the "What's here" functionality.
- src/scripts/contrib/metadata/ (added by Markus, found at UCDAVIS)
added r.meta, g.meta, v.meta: METADATA system from Berkeley
- src/libes/geom/basic/basic.c (Markus)
line 85: changed fprint -> fprintf
- src/libes/geom/optri/pqe2qe.c (Markus)
#include <math.h> added
- src/mapdev/ (Markus)
mv moss/ -> v.out.moss/ (this is a module, not a lib)
- updated src/CMD/lists/GRASS to reflect this
- src/general/gis/gis.shell (Markus)
updated text to "GNU General Public License".
Internal developers directory:
http://hgeo02.geog.uni-hannover.de/users/neteler/grass5beta/
So far for today.
Note: The CERL server was obviously cracked. Therefore the
mailing list is currently down.
Bruce: If you need my "minordomo" software for the new list,
please let me know. It is very easy to install.
length: 2448
max: 0
