[GRASS5] Code Freeze schedule
Hi Andreas,
On Tue, Oct 10, 2000 at 11:07:30PM +0200, Andreas Lange wrote:
Hi Markus, Hi all,
i am still struggeling with some testing issues for the datum library.
But i hope/plan to check in the library until the weekend.
As only m.datum.shift is currently using the library no general
stability problems are to expect.
this sound very good!
How did you compile NVIZ on IRIX? Are the required changes in CVS?
If you cvs update
- configure
- src/CMD/head/head.in
- src.contrib/GMSL/NVIZ2.2
you should be able now to compile it on any platform.
But: NVIZ core dumps on Irix and Linux if tcl/tk8.3 is installed.
With tcl/tk8.0..8.2 everything is o.k. Do other developers have the
same experience?
PS: The src/CMD/head/os-specific/* stuff is for informational purposes
    only. All unix-based platforms generate the head from head.in and
    do not look into os-specific/ In my opinion this directory is redundant.
subject 'unsubscribe grass5'
