[GRASS5] color table
Bug?:
r.mapcalc pok1=-6.0
echo -e "-10.1 green\n-5 green\n-5 blue\n10 blue" | r.colors map=pok1 color=rules
r.mapcalc pok2="int(pok1)"
r.colors map=pok2 rast=pok1
d.rast map=pok2 ---> blue!!!
Ra
Radim Blazek wrote:
Bug?:
Yep. In libgis.
r.mapcalc pok1=-6.0
It's due to an inconsistency in the convertion of negative FP values
to integers. organize_lookup() in color_org.c simply truncates:
  121: x = (CELL ) cp->min;
while G__lookup_colors() in color_look.c uses floor():
  156: dmin = cp->min;
  157: dmax = cp->max;
  158: min = floor(dmin);
Truncating rounds towards zero, while floor() rounds downwards
(towards minus infinity), so if cp->min is -10.1, truncating gives -10
while floor gives -11. This causes lookups in cp->lookup.{red,grn,blu}
to be off by one.
Try the attached patch.
(attachments)
color_look.c.patch (350 Bytes)
On Tuesday 26 August 2003 02:52, Glynn Clements wrote:
Radim Blazek wrote:
> Bug?:
Yep. In libgis.
> r.mapcalc pok1=-6.0
> color=rules r.mapcalc pok2="int(pok1)"
to be off by one.
OK, are you going to submit it to CVS?
Ra
> Radim Blazek wrote:
> > Bug?:
> Yep. In libgis.
> > r.mapcalc pok1=-6.0
> to be off by one.
If yes, should it go into the release branch?
If possible, I would like to release 5.0.3 tomorrow or
Thursday latest (then I am out of town for more than a week).
Yes.
Yes, once we're satisfied that it's correct.
I'd like more time to look at the changes. Note that nobody has posted
a comprehensive summary of what's actually changed. I'm fairly sure
that some of those changes don't belong in the release branch (e.g.
Mike's MinGW stuff in src/general/init/chk_dbase.c, possibly
elsewhere).
How is this done?
tools/diff.sh gives a list of changed files between two source files;
cvs2cl.pl will give a changelog between two CVS tags, but as far as I
can tell 5.0.2 and 5.0.3 share the same CVS tag, so it won't work.
So how to make a cvs comments changelog between 5.0.2 and 5.0.3 with the
same tag? Checking each filename in the CVS-web interface is too long a
job for the many changes. Can cvs2cl.pl work by date+tag?
Hamish
Yes.
elsewhere).
No problem to wait. I would appreciate if the changes get reviewed.
How is this done?
cvs2cl.pl -F releasebranch_26_april_2002_5_0_0 --delta \
release_10_04_2003_grass5_0_2:releasebranch_26_april_2002_5_0_0
seems to work (see below). I'm not sure it's that useful though; most
of the comments just say 'sync with HEAD' or something similar
Paul
2003-08-26 17:41 markus
  * AUTHORS: sync with HEAD
2003-08-26 08:03 markus
  * html/html/: shade.clr.sh.html, shade.rel.sh.html: sync'ed with
    HEAD
2003-08-25 15:37 markus
  * src/libes/proj/doc/: OF90-284.pdf, PROJ.4.3.I2.pdf, PROJ.4.3.pdf,
    SWISS.pdf, wwwlinks.txt: removed large files OF90-284.pdf
    PROJ.4.3.I2.pdf PROJ.4.3.pdf SWISS.pdf (available from
    http://www.remotesensing.org/proj/
2003-08-25 14:48 markus
  * NEWS.html: added shade.cls.sh fix from Hamish
2003-08-25 14:12 markus
  * src/scripts/shells/shade.clr.sh: sync'ed from HEAD
2003-08-25 13:07 paul
  * src/misc/m.kappa/cmd/prt_hdr.c: Fix bug 2076 (reported by Stefano
    Perona)
2003-08-25 12:39 markus
  * src.garden/grass.postgresql/g.stats.pg/infxStats.c: fixed compile
    problem on Debian
2003-08-25 08:53 markus
  * src.garden/grass.postgresql/g.column.pg/main.c: hopefully fixed
2003-08-25 08:49 markus
  * html/html/: d.rgb.html, r.composite.html: sync with HEAD
2003-08-25 08:48 markus
  * html/html/d.where.html: reverted wrong sync
2003-08-25 08:42 markus
  * src/tcltkgrass/module/d.barscale, html/html/d.barscale.html: sync
    with HEAD
2003-08-25 08:33 markus
  * src/display/devices/PNGdriver/Gmakefile: sync with HEAD
2003-08-24 17:54 markus
  * NEWS.html: updated
2003-08-24 17:47 markus
  * src/display/d.barscale/cmd/main.c: fixed patch
2003-08-22 09:55 markus
  * src.garden/grass.postgresql/g.select.pg/main.c:
    G_unsetenv(PG_HOST); fix sync'ed with HEAD
2003-08-20 15:28 markus
  * NEWS.html: updated, not yet complete - please add
2003-08-20 15:08 paul
  * src/raster/r.in.gdal/: Gmakefile, main.c: New proj-related
    changes reverted
2003-08-20 14:29 markus
  * html/html/s.cellstats.html: added output of number of sites and
    sum
2003-08-20 14:21 markus
  * html/sites.html: s.cellstats added
2003-08-20 14:17 markus
  * src/raster/r.fill.dir/ppupdate.c: Sync with HEAD
2003-08-20 14:13 markus
  * src/: raster/r.profile/cmd/main.c, mapdev/v.digit/node_lines.c:
    Sync with HEAD
2003-08-20 14:10 markus
  * src/: ps.map/ps.map/cmd/do_labels.c,
    ps.map/ps.map/cmd/ps_fclrtbl.c, ps.map/ps.map/cmd/ps_map.c,
    ps.map/scripts/demo1.scr, ps.map/scripts/demo2.scr,
    ps.map/scripts/demo3.scr, ps.map/scripts/demo5.scr,
    ps.map/scripts/demo8.scr, ps.map/scripts/demo9.scr,
    raster/r.transect/cmd/main.c: Sync with HEAD
2003-08-20 10:40 markus
  * src/raster/wildfire/src/r.spread/local_proto.h: Sync to release
    branch
2003-08-20 10:35 markus
  * Makefile.in, NEWS.html,
    src/imagery/i.ortho.photo/libes/Gmakefile,
    src/mapdev/v.build/main.c, src/mapdev/v.digit/set_thresh.c,
    src/mapdev/v.in.dgn/Gmakefile, src/mapdev/v.in.dgn/README,
    src/mapdev/v.in.dgn/main.c, src/mapdev/v.in.mif/main.c,
    src/mapdev/v.in.mif/write_lines.c, src/mapdev/v.in.shape/lines.c,
    src/mapdev/v.in.shape/vmap_import.c,
    src/mapdev/v.mkquads/ask_for.c,
    src/mapdev/v.mkquads/calc_quads.c,
    src/mapdev/v.out.e00/v.out.e00.c, src/mapdev/v.timestamp/main.c,
    src/misc/m.in.e00/info.c, src/misc/m.kappa/cmd/main.c,
    src/misc/m.kappa/cmd/prt_hdr.c,
    src/misc/m.kappa/cmd/readin_data.c,
    src/ps.map/devices/ps.devices/a3,
    src/ps.map/devices/ps.devices/a4,
    src/raster/r.colors/cmd/local_proto.h,
    src/raster/r.colors/cmd/main.c, src/raster/r.colors/cmd/rules.c,
    src/raster/r.cost/cmd/btree.c, src/raster/r.cost/cmd/main.c,
    src/raster/r.cost/cmd/stash.h, src/raster/r.his/cmd/main.c,
    src/raster/r.in.doq/cmd/get_newhead.c,
    src/raster/r.in.gdal/Gmakefile,
    src/raster/r.in.gdal/gbgetsymbol.c,
    src/raster/r.in.gdal/gdalbridge.c,
    src/raster/r.in.gdal/gdalbridge.h, src/raster/r.in.gdal/main.c,
    src/raster/r.info/inter/main.c,
    src/raster/r.info/inter/more_print.c,
    src/raster/r.los/cmd/delete.c, src/raster/r.los/cmd/main.c,
    src/raster/r.los/cmd/mark_pts.c, src/raster/r.los/cmd/pts_elim.c,
    src/raster/r.mapcalc3/evaluate.c,
    src/raster/r.mapcalc3/expression.c,
    src/raster/r.patch/cmd/main.c, src/raster/r.patch/cmd/nfiles.h,
    src/raster/r.reclass/cmd/reclass.c,
    src/raster/r.timestamp/main.c,
    src/raster/wildfire/src/r.ros/spot_dist.c,
    src/raster/wildfire/src/r.spread/cell_ptrHa.h,
    src/raster/wildfire/src/r.spread/cmd_line.h,
    src/raster/wildfire/src/r.spread/collect_ori.c,
    src/raster/wildfire/src/r.spread/costHa.h,
    src/raster/wildfire/src/r.spread/deleteHa.c,
    src/raster/wildfire/src/r.spread/display.c,
    src/raster/wildfire/src/r.spread/fixHa.c,
    src/raster/wildfire/src/r.spread/get_minHa.c,
    src/raster/wildfire/src/r.spread/insert2Ha.c,
    src/raster/wildfire/src/r.spread/insertHa.c,
    src/raster/wildfire/src/r.spread/main.c,
    src/raster/wildfire/src/r.spread/pick_dist.c,
    src/raster/wildfire/src/r.spread/pick_ignite.c,
    src/raster/wildfire/src/r.spread/ram2out.c,
    src/raster/wildfire/src/r.spread/replaceHa.c,
    src/raster/wildfire/src/r.spread/select_linksB.c,
    src/raster/wildfire/src/r.spread/spot.c,
    src/raster/wildfire/src/r.spread/spread.c,
    src/scripts/contrib/d.rast.labels/d.rast.labels,
    src/scripts/contrib/d.rast.leg/d.rast.leg,
    src/scripts/contrib/grassmirrorsmap/grass.sites.main,
    src/scripts/contrib/grassmirrorsmap/grass.sites.mirror,
    src/scripts/contrib/grassmirrorsmap/grass_sites.gif,
    src/scripts/contrib/grassmirrorsmap/grass_sites.htmlmap,
    src/scripts/contrib/grassmirrorsmap/grassmap.html,
    src/scripts/contrib/grassmirrorsmap/mkgrassmap.sh,
    src/scripts/contrib/r.fillnulls/r.fillnulls,
    src/scripts/contrib/r.to.pg/r.to.pg,
    src/scripts/contrib/s.in.atkisdgm/s.in.atkisdgm,
    src/scripts/contrib/s.in.atkisdgm/s.in.atkisktb,
    src/scripts/contrib/s.in.garmin.sh/s.in.garmin.sh,
    src/scripts/contrib/v.cutregion.sh/v.cutregion.sh,
    src/scripts/contrib/v.in.garmin.sh/v.in.garmin.sh,
    src/scripts/contrib/v.in.mapgen.sh/v.in.mapgen.sh,
    src/scripts/contrib/v.line2area/v.area2line,
    src/scripts/contrib/v.line2area/v.line2area,
    src/scripts/contrib/v.region.sh/v.region.sh,
    src/scripts/shells/slide.show.sh, src/sites/s.cellstats/main.c,
    src/sites/s.cellstats/univar.c, src/sites/s.cellstats/univar.h,
    src/sites/s.in.ascii/get_site.c, src/sites/s.in.ascii/main.c,
    src/sites/s.in.dbf/main.c, src/sites/s.out.ascii/main.c,
    src/sites/s.qcount/main.c, src/sites/s.qcount/tutorial/output,
    src/sites/s.windavg/main.c, src/tcltkgrass/main/gis_set.tcl,
    src/tcltkgrass/module/d.barscale, src/tcltkgrass/module/d.grid,
    src/tcltkgrass/module/r.proj, src/tcltkgrass/module/r.transect,
    tools/diff.sh: Sync to release branch
2003-08-20 09:53 markus
  * src/libes/gis/sleep.c: Sync to release branch
2003-08-20 09:47 markus
  * src/general/: init/Gmakefile, init/README, init/chk_dbase.c,
    init/grass.src, init/grass_intro.txt, init/init.sh,
    init/mke_loc.c, init/mke_mapset.c, init/set_data.c,
    g.ask/cmd/main.c, g.filename/cmd/main.c, g.findfile/cmd/main.c,
    g.gisenv/main.c: Sync to release branch
2003-08-20 09:35 markus
  * src/fonts/for_grass/splitfont.c,
    src.garden/grass.postgresql/tutorial/index.html: Sync to release
    branch
2003-08-20 09:31 markus
  * src/: display/d.leg.thin/main.c, display/d.what.sites/main.c,
    fonts/fonts/cyrilc.hmp: Sync to release branch
2003-08-20 09:28 markus
  * src/display/: d.area/screenpoly.h,
    devices/windows/libW11/w32/xlib.c, d.geodesic/cmd/Gmakefile: Sync
    to release branch
2003-08-20 09:19 markus
  * src/CMD/: VERSION, lists/GRASS: Sync to release branch
2003-08-20 09:16 markus
  * src/: display/d.barscale/cmd/draw_scale.c,
    display/d.barscale/cmd/main.c, display/d.barscale/cmd/mouse.c,
    display/d.barscale/cmd/options.h, general/g.parser/test.sh: Sync
    to release branch
2003-08-20 09:10 markus
  * aclocal.m4, documents/cygwin_grass50bininstall.html,
    documents/release_rules.txt, documents/sites_format50.txt,
    html/raster.html, html/sites.html, html/html/d.barscale.html,
    html/html/d.colormode.html, html/html/d.colors.html,
    html/html/d.colortable.html, html/html/d.rgb.html,
    html/html/d.save.html, html/html/d.site.labels.html,
    html/html/d.site.pg.html, html/html/d.sites.label.html,
    html/html/d.where.html, html/html/r.fill.dir.html,
    html/html/r.sun.html, html/html/s.in.ascii.html,
    html/html/s.in.dbf.html, html/html/s.in.shape.html,
    html/html/s.surf.idw.html, html/html/s.vol.rst.html,
    html/html/s.voronoi.html, html/html/shade.rel.sh.html,
    html/html/v.build.polylines.html, html/html/v.extract.html,
    html/html/v.import.html, html/html/v.in.gshhs.html,
    html/html/v.mkquads.html, html/html/v.spag.html: Sync to release
    branch
2003-08-20 08:57 markus
  * src/scripts/shells/shade.rel.sh: Sync with HEAD
2003-08-08 16:41 paul
  * src/libes/proj/do_proj_nad.c: Bugfix to old datum shifting for
    releasebranch
2003-07-10 08:24 markus
  * src/general/g.mapsets/main_cmd.c: fix typo bug: #2011
2003-07-04 09:35 markus
  * html/html/: g.findfile.html, r.cost.html, r.flow.html,
    r.flowmd.html, r.in.ascii.html, r.in.poly.html, s.buffer.html,
    s.kernel.html, v.bubble.html, v.circle.html: sync'ed with HEAD
2003-06-11 12:25 paul
  * src/raster/r.in.gdal/main.c: Important bugfix (for correct
    PROJ_INFO files) added to release branch
2003-05-29 12:19 markus
  * src/sites/s.in.dbf/dump.c: buffer enlarged (bug #1891)
2003-05-08 15:16 markus
  * src/sites/s.out.e00/s.out.e00.c: sync with HEAD
2003-05-07 08:23 markus
  * src/raster/r.statistics/cmd/method.h: sync with HEAD
2003-05-06 17:23 markus
  * src/raster/r.topmodel/main.c: sync with HEAD
2003-05-06 15:50 markus
  * src/raster/: r.profile/cmd/main.c, r.quant/main.c: sync with HEAD
2003-05-06 15:37 markus
  * src/raster/r.tiff/r.out.tiff.c: sync with HEAD
2003-05-06 14:33 markus
  * src/raster/r.in.bin/main.c, html/html/r.info.html: sync with HEAD
2003-05-06 09:05 markus
  * src/raster/r.thin/cmd/size.c: sync with HEAD
2003-05-06 09:01 markus
  * src/raster/r.statistics/cmd/: median.c, method.h, moment.c,
    skew.c: sync with head
2003-05-06 09:00 markus
  * src/raster/r.statistics/cmd/unused/: median.c, moment.c, skew.c:
    sync with HEAD
2003-05-06 08:55 markus
  * src/raster/r.patch/cmd/: Gmakefile, patch.c: sync with HEAD
2003-05-06 08:52 markus
  * src/raster/wildfire/src/r.spread/prob_invsqr.c: moved to
    prob_invsqr/ to avoid 5.1 conflict with two main()
2003-05-06 08:51 markus
  * src/raster/wildfire/src/r.spread/prob_invsqr/prob_invsqr.c: moved
    here from ../ for 5.1
2003-05-06 08:37 markus
  * src/raster/r.los/cmd/newsegment.c: removed leftover file
2003-05-06 08:23 markus
  * src/raster/r.coin/cmd/: Gmakefile, cmd.c, cmd_parms.c: sync with
    HEAD
2003-04-29 18:27 markus
  * src/display/d.barscale/cmd/main.c: sync'ed with HEAD
2003-04-24 09:51 markus
  * src.contrib/GMSL/NVIZ2.2/src/interface.h: added TK8.4 fix from
    HEAD
2003-04-18 13:37 markus
  * src/general/g.parser/test.sh: sync with HEAD
2003-04-18 09:58 markus
  * html/html/r.colors.html: sync with HEAD
2003-04-16 09:01 markus
  * src/imagery/i.class/draw_match.c: sync with head
2003-04-11 15:05 radim
  * src/mapdev/v.to.db/parse.c: vector option
2003-04-11 08:35 markus
  * NEWS.html: fix
> How is this done?
To compare 5.0.2 to the current release_branch, run
(inside the fresh release_branch releasebranch_26_april_2002_5_0_0):
   cvs diff -u -r release_10_04_2003_grass5_0_2
NB: The chk_dbase.c / __MINGW32__ change I have reverted.
How is this done?
5.0.2 has a non-branch tag (release_10_04_2003_grass5_0_2); 5.0.3
corresponds to the latest version of the release branch (i.e the
releasebranch_26_april_2002_5_0_0 branch tag).
> elsewhere).
A few more issues:
1. src/tcltkgrass/module/d.grid has been updated for the bordercolor=
option and -b/-g flags, but these aren't in the release version of
d.grid itself. Which one is wrong?
2. The src/tcltkgrass/module/r.proj update introduced a typo:
    {checkbox -n {Do not preform region cropping optimization} "" -n}
I've fixed this one in both head and release branch.
3. The signal handling changes in
  src/general/init/grass.src
  src/general/init/init.sh
prevent trapping SIGKILL (9) and SIGTERM (15). Not trapping SIGKILL is
sensible enough (IIRC, this will fail on some shells), but why avoid
trapping SIGTERM?
4. Some of the changes seem rather extensive for something that's
supposed to be a bug-fix release. Specifically: d.barscale, v.in.dgn,
m.in.e00, r.los, r.spread.
I've attached a summary of the changes.
(attachments)
changes.txt (8.94 KB)
Fixes the bug mentioned here:
http://op.gfz-potsdam.de/GRASS-List/Archive/msg09197.html
Updated to use the copy of dgn libary embedded within GDAL rather than a
separate dgnlib, I think. Necessary changes described in this e-mail by
Thierry although they had already been made by Radim:
http://op.gfz-potsdam.de/GRASS-List/Archive/msg09677.html
On Thu, Sep 04, 2003 at 10:04:54PM +0100, Glynn Clements wrote:
Content-Description: message body and .signature
> > elsewhere).
A few more issues:
the update was wrong - reverted.
ok
trapping SIGTERM?
Seems that I didn't recall correctly the outcome of that discussion.
Readded 15 both in HEAD and release_branch.
Concerning r.los:
It was the "trivial" update to FP done by me (based on your
recommendations). Should be ok
Content-Description: Changes between 5.0.2 and release branch
src/display/d.barscale/cmd/draw_scale.c
src/display/d.barscale/cmd/mouse.c
src/display/d.barscale/cmd/options.h
  Upgrade
The old version was partially non-functional. It's rather impossible
(for me) to take out only the bug-fix part without added the
small improvement (-t flag).
  Don't trap SIGKILL, SIGTERM
SIGTERM trapped now
SIGTERM trapped now
  Add version number
  Fix for first-time use
  Change test -e -> test -r
[see Paul's email]
Minor include file fixes and
2003-01-07 11:47 radim
        * main.c: stroke arc and curve, read mslink of given entity number
I don't see a problem here for 5.0.3.
2003-03-31 09:13 eric
        * v.out.e00.c: Fix vector/mapset lookup. Add some type casts and
        extra parens to make -Wall happy (oh, and the type casts might be
        necessary on some arches).
Should be fine.
2002-07-19 22:51 roger
        * info.c, main.c: Added the list= parameter and corrected a format
        that was invalid for large INFO tables
Sounds ok.
Relevant are:
2003-07-08 15:38 markus
        * main.c: change to channel numbers instead of color name
        extensions for multiband data in case subsequent channels have
        identical color names (as for SAA AVHRR data)
2003-04-30 14:50 markus
        * main.c: submitted compression change from Eric Miller. Added grey
        color table for GDT_UInt16
2003-03-13 13:49 markus
        * main.c: grey_scale_colors for Byte data, color name support for
        known color names (Red, Green, Blue)
2002-11-07 17:59 markus
        * main.c: use positive xy coordinates for unprojected TIFF instead
        of negative xy coordinates
Here should be checked that the PROJ4 related updates did not reach
the release_branch. AFAIK Paul already verified it.
Maybe some release_branch testers could try r.in.gdal.
-src/raster/wildfire/src/r.spread/prob_invsqr.c
+src/raster/wildfire/src/r.spread/local_proto.h
  [Tidying]
  Protect headers against repeated inclusion
  Move definitions from header files to source files
  Use ANSI prototypes
  Add local_proto.h
  Remove prob_invsqr.c
Motivation:
http://grass.itc.it/pipermail/grass5/2003-March/005069.html
The old versions seemed not to work, so the fix should go
into 5.0.3.
  Don't trap SIGKILL
minor cosmetics, no problem I think.
  Use -eq instead of = (why?)
was crashing recently - I don't know why, but the fix helped.
  *** BOGUS ***
  Add bordercolor=, -b, -g
reverted.
Also done now:
- update date in
  src/CMD/VERSION August -> September
  NEWS.html August -> September
If there are no objections, I'll package a 5.0.3RC3 today
and produce the md5 checksum as well.
