[GRASS5] Colors in the Grass Monitor
  I am having some trouble trying to understand the color handling from the
grass monitor "point of view".
I hope this is not too much sample data to sent to the list...
  My monitor, in "debug mode" prints:
BEGIN
PAD_SELECT '' -> OK
PAD_GET_ITEM 'cur_w' -> OK
  'full_screen'
PAD_SELECT 'full_screen' -> OK
PAD_SELECT '' -> OK
  'full_screen'
PAD_GET_ITEM 'd_win' -> OK
  '0 600 0 600'
PAD_GET_ITEM 'm_win' -> OK
  '1 13 634073.45932023 563243.85326423 4942105.68361531 4871276.07755932 1415
1417'
SET_WINDOW 0 600 0 600
MOVE_ABS 0 0
PAD_DELETE_ITEM 'list' -> OK
PAD_DELETE_ITEM 'cell' -> OK
PAD_DELETE_ITEM 'dig' -> OK
PAD_DELETE_ITEM 'site' -> OK
PAD_DELETE_ITEM 'cell_list' -> OK
PAD_DELETE_ITEM 'dig_list' -> OK
PAD_DELETE_ITEM 'site_list' -> OK
PAD_DELETE_ITEM 'off' -> OK
PAD_DELETE_ITEM 'm_win' -> OK
PAD_DELETE_ITEM 'erase' -> OK
PAD_GET_ITEM 'off' -> NO_ITEM
COLOR_OFFSET 0
GET_NUM_COLORS 256
RESET_COLORS 0 255
  00/00/00 00/00/00 01/01/01 02/02/02 03/03/03 04/04/04 05/05/05 06/06/06
  07/07/07 08/08/08 09/09/09 0a/0a/0a 0b/0b/0b 0c/0c/0c 0d/0d/0d 0e/0e/0e
  0f/0f/0f 10/10/10 11/11/11 12/12/12 13/13/13 14/14/14 15/15/15 16/16/16
  17/17/17 18/18/18 19/19/19 1a/1a/1a 1b/1b/1b 1c/1c/1c 1d/1d/1d 1e/1e/1e
  1f/1f/1f 20/20/20 21/21/21 22/22/22 23/23/23 24/24/24 25/25/25 26/26/26
  27/27/27 28/28/28 29/29/29 2a/2a/2a 2b/2b/2b 2c/2c/2c 2d/2d/2d 2e/2e/2e
  2f/2f/2f 30/30/30 31/31/31 32/32/32 33/33/33 34/34/34 35/35/35 36/36/36
  37/37/37 38/38/38 39/39/39 3a/3a/3a 3b/3b/3b 3c/3c/3c 3d/3d/3d 3e/3e/3e
  3f/3f/3f 40/40/40 41/41/41 42/42/42 43/43/43 44/44/44 45/45/45 46/46/46
  47/47/47 48/48/48 49/49/49 4a/4a/4a 4b/4b/4b 4c/4c/4c 4d/4d/4d 4e/4e/4e
  4f/4f/4f 50/50/50 51/51/51 52/52/52 53/53/53 54/54/54 55/55/55 56/56/56
  57/57/57 58/58/58 59/59/59 5a/5a/5a 5b/5b/5b 5c/5c/5c 5d/5d/5d 5e/5e/5e
  5f/5f/5f 60/60/60 61/61/61 62/62/62 63/63/63 64/64/64 65/65/65 66/66/66
  67/67/67 68/68/68 69/69/69 6a/6a/6a 6b/6b/6b 6c/6c/6c 6d/6d/6d 6e/6e/6e
  6f/6f/6f 70/70/70 71/71/71 72/72/72 73/73/73 74/74/74 75/75/75 76/76/76
  77/77/77 78/78/78 79/79/79 7a/7a/7a 7b/7b/7b 7c/7c/7c 7d/7d/7d 7e/7e/7e
  7f/7f/7f 80/80/80 81/81/81 82/82/82 83/83/83 84/84/84 85/85/85 86/86/86
  87/87/87 88/88/88 89/89/89 8a/8a/8a 8b/8b/8b 8c/8c/8c 8d/8d/8d 8e/8e/8e
  8f/8f/8f 90/90/90 91/91/91 92/92/92 93/93/93 94/94/94 95/95/95 96/96/96
  97/97/97 98/98/98 99/99/99 9a/9a/9a 9b/9b/9b 9c/9c/9c 9d/9d/9d 9e/9e/9e
  9f/9f/9f a0/a0/a0 a1/a1/a1 a2/a2/a2 a3/a3/a3 a4/a4/a4 a5/a5/a5 a6/a6/a6
  a7/a7/a7 a8/a8/a8 a9/a9/a9 aa/aa/aa ab/ab/ab ac/ac/ac ad/ad/ad ae/ae/ae
  af/af/af b0/b0/b0 b1/b1/b1 b2/b2/b2 b3/b3/b3 b4/b4/b4 b5/b5/b5 b6/b6/b6
  b7/b7/b7 b8/b8/b8 b9/b9/b9 ba/ba/ba bb/bb/bb bc/bc/bc bd/bd/bd be/be/be
  bf/bf/bf c0/c0/c0 c1/c1/c1 c2/c2/c2 c3/c3/c3 c4/c4/c4 c5/c5/c5 c6/c6/c6
  c7/c7/c7 c8/c8/c8 c9/c9/c9 ca/ca/ca cb/cb/cb cc/cc/cc cd/cd/cd ce/ce/ce
  cf/cf/cf d0/d0/d0 d1/d1/d1 d2/d2/d2 d3/d3/d3 d4/d4/d4 d5/d5/d5 d6/d6/d6
  d7/d7/d7 d8/d8/d8 d9/d9/d9 da/da/da db/db/db dc/dc/dc dd/dd/dd de/de/de
  df/df/df e0/e0/e0 e1/e1/e1 e2/e2/e2 e3/e3/e3 e4/e4/e4 e5/e5/e5 e6/e6/e6
  e7/e7/e7 e8/e8/e8 e9/e9/e9 ea/ea/ea eb/eb/eb ec/ec/ec ed/ed/ed ee/ee/ee
  ef/ef/ef f0/f0/f0 f1/f1/f1 f2/f2/f2 f3/f3/f3 f4/f4/f4 f5/f5/f5 f6/f6/f6
  f7/f7/f7 f8/f8/f8 f9/f9/f9 fa/fa/fa fb/fb/fb fc/fc/fc fd/fd/fd fe/fe/fe
RESPOND
  '0 600 0 600'
COLOR 255
MOVE_ABS 0 0
CONT_REL 599 0
From now on, it sends a command to fill a line before starting the raster
data, then sends RASTER_CHAR to draw the picture.
I am expecting that RESET_COLORS would be sending me the RGB values of the
pixels in the image, and than, RASTER_CHAR would send me the indexes in
that color table. But that's not what is happening. So, it seens that
RESET_COLORS should be ignored, and I should create a "standard colormap".
It also seens that only FLOAT colormaps are supported.
Since I initialize the "colormap" with the standard colors, calling d.vect and
d.area draws everything correctly, but d.rast currently only shows gray
images.
thanks for any hints,
Paulo
"debug mode"? I suspect that you're using an outdated version of the
code.
that color table.
Yep.
images.
That might be a bug. If it's still in the current version of the code,
report it.
