[GRASS5] comment in ps.map
When I use the ps.map, I found it can only import one
comment file. For example(from one ps.map input file):
comments file1
where 1,1
end
comments file2
where 2,2
end
the output ps file only take the content from the two
files at 2,2!
so can somebody give me suggestion how to add more
comment file at diffrent place? or can I modify the
ps.map source code to do that?
Shifeng
__________________________________________________
Do You Yahoo!?
Send FREE Valentine eCards with Yahoo! Greetings!
http://greetings.yahoo.com
On Thu, 14 Feb 2002, zhang ji wrote:
comments file1
where 1,1
end
comments file2
where 2,2
end
I tried this example and didn't see the problem you described. I was
running grass 5.0.0pre2 in Linux on an intel x86 machine. Could the
problem be somewhere else?
Roger Miller
