i'm a new to CVS write access.
i tried to commit sources, but i got the following error:
cvs [server aborted]: "commit" requires write access to the repository
hm... i got cvsid from bernhard@intevation.de.
what's wrong?
Best Regards,
Huidae Cho
subject 'unsubscribe grass5'
what's wrong?
Did you do the original checkout via that cvsid?
Check a Root file somewhere. They are kept in the CVS subdirectory
under each source directory. They should include the cvsid. If not,
the "right" way to fix is to checkout again, but I wouldn't be surprised
to find that you could also just change the CVS/Root file.
