[GRASS5] compilation errors 6.cvs on MacOS
After months of distraction, I've been updating various GRASS installations here. The latest 6.x CVS (grass6 head) compiled fine on a linux machine here, but gets errors on MacOSX. Looking at the errors, I think that they're all related to the first error, in the display libraries. When I try to make that directory I get the following, which doesn't mean much to me:
[smitch@stipa:~/src/cvsgrass/grass6/display/drivers/lib]$ make
ar cr /private/Network/Servers/gracilis.carleton.ca/home/smitch/src/cvsgrass/grass6/dist.powerpc-apple-darwin8.2.0/lib/libgrass_driver.a OBJ.powerpc-apple-darwin8.2.0/Box_abs.o OBJ.powerpc-apple-darwin8.2.0/Box_rel.o OBJ.powerpc-apple-darwin8.2.0/Client.o OBJ.powerpc-apple-darwin8.2.0/Clr_table.o OBJ.powerpc-apple-darwin8.2.0/Color.o OBJ.powerpc-apple-darwin8.2.0/Cont_abs.o OBJ.powerpc-apple-darwin8.2.0/Cont_rel.o OBJ.powerpc-apple-darwin8.2.0/Erase.o OBJ.powerpc-apple-darwin8.2.0/Font_get.o OBJ.powerpc-apple-darwin8.2.0/Get_t_box.o OBJ.powerpc-apple-darwin8.2.0/Linemod.o OBJ.powerpc-apple-darwin8.2.0/Move_abs.o OBJ.powerpc-apple-darwin8.2.0/Move_rel.o OBJ.powerpc-apple-darwin8.2.0/Num_colors.o OBJ.powerpc-apple-darwin8.2.0/Plydts_abs.o OBJ.powerpc-apple-darwin8.2.0/Plydts_rel.o OBJ.powerpc-apple-darwin8.2.0/Plylne_abs.o OBJ.powerpc-apple-darwin8.2.0/Plylne_rel.o OBJ.powerpc-apple-darwin8.2.0/Polygn_rel.o OBJ.powerpc-apple-darwin8.2.0/Raster_int.o OBJ.powerpc-apple-darwin8.2.0/Raster_chr.o OBJ.powerpc-apple-darwin8.2.0/Raster_def.o OBJ.powerpc-apple-darwin8.2.0/Reset_clrs.o OBJ.powerpc-apple-darwin8.2.0/Respond.o OBJ.powerpc-apple-darwin8.2.0/Returns.o OBJ.powerpc-apple-darwin8.2.0/Set_window.o OBJ.powerpc-apple-darwin8.2.0/Text.o OBJ.powerpc-apple-darwin8.2.0/Text_size.o OBJ.powerpc-apple-darwin8.2.0/Work.o OBJ.powerpc-apple-darwin8.2.0/clip.o OBJ.powerpc-apple-darwin8.2.0/color_supp.o OBJ.powerpc-apple-darwin8.2.0/command.o OBJ.powerpc-apple-darwin8.2.0/connect_fifo.o OBJ.powerpc-apple-darwin8.2.0/connect_sock.o OBJ.powerpc-apple-darwin8.2.0/font.o OBJ.powerpc-apple-darwin8.2.0/main.o OBJ.powerpc-apple-darwin8.2.0/pad.o OBJ.powerpc-apple-darwin8.2.0/utils.o OBJ.powerpc-apple-darwin8.2.0/RGB.o OBJ.powerpc-apple-darwin8.2.0/Text2.o OBJ.powerpc-apple-darwin8.2.0/Text3.o OBJ.powerpc-apple-darwin8.2.0/font_freetype.o; ranlib /private/Network/Servers/gracilis.carleton.ca/home/smitch/src/cvsgrass/grass6/dist.powerpc-apple-darwin8.2.0/lib/libgrass_driver.a
ar: /private/Network/Servers/gracilis.carleton.ca/home/smitch/src/cvsgrass/grass6/dist.powerpc-apple-darwin8.2.0/lib/libgrass_driver.a: Resource temporarily unavailable
ranlib: file: /private/Network/Servers/gracilis.carleton.ca/home/smitch/src/cvsgrass/grass6/dist.powerpc-apple-darwin8.2.0/lib/libgrass_driver.a is not an archive
make: *** [/private/Network/Servers/gracilis.carleton.ca/home/smitch/src/cvsgrass/grass6/dist.powerpc-apple-darwin8.2.0/lib/libgrass_driver.a] Error 1
Is that enough for anyone here to understand what's wrong? Any suggestions what to try?
Scott Mitchell
smitch at mac.com
Hi Scott,
2005/10/6, Scott Mitchell <smitch@mac.com>:
This error seems the first error, which usually means that machine is
overloaded and
doesn't have enough memory to start a new task.
BABA Yoshihiko
grass maintainer for Fink/MacOSX
