I am having a problem with grass51_exp_2003_03_29. I configure pointing to
the gdal-config. The problem is that there are a bunch of files that don't
get made because they can't find ogr_api.h. It appears that ./config sets
HAVE_OGR (in include/config.h) which in turn triggers vect/dig_structures.h
to include ogr_api.h. The problem apprears to be that nothing adds the path
to ogr_api.h.
If I manually add $(GDAL_CFLAGS) which is defined in Platform.make to the
local make file, this corrects the error. The problem is that I have added
this 13 times so far and still going. I assume this isn't correct.
Can someone help, please?
Red Hat 7.2
CFLAGS="-g -Wall" ./configure
--with-grass50=/home/john/grass50_exp_2003_03_29
--with-postgres-includes=/usr/include/pgsql
--without-fftw
--with-dbm
--with-dbm-includes=/usr/include/gdbm
--with-gdal=/home/john/gdal-1.1.8/apps/gdal-config
John
John Gillette wrote:
I am having a problem with grass51_exp_2003_03_29. I configure pointing to the gdal-config. The problem is that there are a bunch of files that don't get made because they can't find ogr_api.h. It appears that ./config sets HAVE_OGR (in include/config.h) which in turn triggers vect/dig_structures.h to include ogr_api.h. The problem apprears to be that nothing adds the path to ogr_api.h.
If I manually add $(GDAL_CFLAGS) which is defined in Platform.make to the local make file, this corrects the error. The problem is that I have added this 13 times so far and still going. I assume this isn't correct.
Red Hat 7.2
CFLAGS="-g -Wall" ./configure --with-grass50=/home/john/grass50_exp_2003_03_29 --with-postgres-includes=/usr/include/pgsql
--without-fftw
--with-dbm
John, etc,
In theory what configure scripts are supposed to do when pointed at gdal-config
is to run "gdal-config --cflags" to get appropriate values to add to the
CFLAGS or similar macro.
eg.
warmerda@gdal2200[127]% ~/gdal/apps/gdal-config --cflags
-I/debian/home/warmerda/gdal/port -I/debian/home/warmerda/gdal/core -I/debian/home/warmerda/gdal/ogr -I/debian/home/warmerda/gdal/ogr/ogrsf_frmts
or
warmerda@gdal2200[128]% /usr/local/bin/gdal-config --cflags
-I/usr/local/include
If you want GRASS to be able to utilize a built, but not installed GDAL you
would need to update the configure accordingly.
In the meantime John, can't you just do a "make install" for GDAL? I
think things would work fine then.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
It was missing
VECT_CFLAGS = $(GDALCFLAGS)
in Grass.make.in.
Add this row to include/Make/Grass.make.in and run configure.
Radim
path to ogr_api.h.
Red Hat 7.2
--without-fftw
--with-dbm
John
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
