On MacOS 10.4.4, this morning's CVS GRASS6, I'm getting the following error (it compiled fine on a Fedora Linux system). Increasingly rusty C skills are preventing successful self-fix. Suggestions?
Looks like the only change in this file recently was on Jan 30, Markus logged that he removed some "unused stuff" - could that be related?
Thanks!
[OmarSosa:grass6/lib/gis] smitch% make
gcc -I/Volumes/smitchDataBank/src/grass6/dist.powerpc-apple-darwin8.4.0/include -I/usr/X11R6/include -I/sw/include -g -O2 -Wall -Wconversion -Wno-implicit-int -I/usr/X11R6/include -I/sw/include -fno-common -DPACKAGE=\""grasslibs"\" -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\" -I/Volumes/smitchDataBank/src/grass6/dist.powerpc-apple-darwin8.4.0/include \
-o OBJ.powerpc-apple-darwin8.4.0/grid_dist1.o -c grid_dist1.c
grid_dist1.c:93: error: static declaration of 'sc' follows non-static declaration
grid_dist1.c:20: error: previous declaration of 'sc' was here
make: *** [OBJ.powerpc-apple-darwin8.4.0/grid_dist1.o] Error 1
it seems that the Makefile in your copy of lib/gis/ isn't updated
yet. I strongly recommend to completely update GRASS from
CVS after running a cleanup:
make distclean
cvs up -dP
./configure ...
make
Best
related?
Sure enough, there was something wrong with updating in that directory - had to delete the whole directory and check it out again, but at least now it's all compiling cleanly.
Scott
Scott Mitchell, Assistant Professor, Carleton University
Department of Geography & Environmental Studies, Loeb A209
Mailing: Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell@carleton.ca
On Feb 21, 2006, at 3:16, Markus Neteler wrote:
Scott,
make distclean
cvs up -dP
./configure ...
make
Best
related?
