Hello,
I get the following error compiling GRASS5.0 CVS version:
splitfont.c: In function `main':
splitfont.c:132: unrecognizable insn:
(insn 943 922 463 (set (reg/v:QI 63)
(const_int 129 [0x81])) -1 (nil)
(expr_list:REG_EQUAL (const_int 129 [0x81])
(nil)))
splitfont.c:132: Internal compiler error in extract_insn, at recog.c:2148
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://gcc.gnu.org/bugs.html> for instructions.
make[1]: *** [OBJ.i686-pc-linux-gnu/splitfont.o] Erreur 1
make[1]: Leaving directory `/data/GRASSCVS/grass/src/fonts/for_grass'
GISGEN failure at STEP: src/fonts/for_grass
Is this a gcc problem or a GRASS problem ?
Moritz
splitfont.c: In function `main': splitfont.c:132: unrecognizable
insn: (insn 943 922 463 (set (reg/v:QI 63) (const_int 129 [0x81]))
-1 (nil) (expr_list:REG_EQUAL (const_int 129 [0x81]) (nil)))
recog.c:2148 Please submit a full bug report, with preprocessed
source if appropriate. See <URL:http://gcc.gnu.org/bugs.html> for
instructions. make[1]: *** [OBJ.i686-pc-linux-gnu/splitfont.o]
Erreur 1 make[1]: Leaving directory
`/data/GRASSCVS/grass/src/fonts/for_grass' GISGEN failure at STEP:
src/fonts/for_grass
I had the same problem when compiling with gcc-3.3 and gcc-3.2. I
guess that I could have tried some other gcc-3.x versions, but at this
point I just went back to gcc-2.95, and encountered no errors. That
would seem to point the finger at gcc.
Martin
Martin Pokorny
Tucson, AZ, USA
(nil)))
A bit of both. Given that main() is declared as returning "int", it
should actually have a "return" statement. OTOH, gcc really shouldn't
be throwing an internal compiler error.
The attached patch should solve the problem.
(attachments)
splitfont.c-patch (284 Bytes)
Glynn,
I tried the proposed patch, but it still fails (gcc 3.2.2 on Mandrake 9.1).
splitfont.c: In function 'main':
(insn 947 926 463 (set (reg/v:QI 63)
(nil)))
See <URL:https://qa.mandrakesoft.com/> for instructions.
On Mon, Jul 07, 2003 at 06:11:27PM +0100, Glynn Clements wrote:
Content-Description: message body and .signature
> (nil)))
Content-Description: splitfont.c patch
--- src/fonts/for_grass/splitfont.c~ Thu Jul 3 21:41:13 2003
+++ src/fonts/for_grass/splitfont.c Mon Jul 7 18:09:56 2003
@@ -128,7 +128,7 @@
write (newfont, &newoffset, sizeof(newoffset));
close (newfont);
- exit(0);
+ return 0;
int savechar (int font, int newfont)
I should add that the file was recently updated. The previous version
compiles fine on gcc 3.2.2. So the problem was introduced with the
8bit updates. It can be still a gcc problem of course.
On Mon, Jul 07, 2003 at 10:47:17PM +0200, Markus Neteler wrote:
Glynn,
(nil)))
> > (nil)))
> @@ -128,7 +128,7 @@
> close (newfont);
> - exit(0);
> + return 0;
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
(nil)))
recog.c:2148
@@ -128,7 +128,7 @@
close (newfont);
- exit(0);
+ return 0;
As for Markus, this doesn't solve the problem for me. Linking /usr/bin/gcc
to /usr/bin/gcc-2.95 instead of /usr/bin/gcc-3.2 did the trick.
Moritz
A couple of other things to try include:
1. Change the type of the variable "achar" from char to int (the code
assumes that achar can hold negative values, but C doesn't specify
whether char is signed or unsigned).
2. Change the second argument to memset() (at line 63) from a
character literal to an integer literal, i.e.:
memset(map, 0, sizeof(map));
I don't have gcc 3.x, so I can't test any of this.
9.1).
That works. It compiles perfectly now, even with gcc3.2. Thanks !
That didn't change anything.
Moritz
This works out of the box, great.
Applying this additionally, it still compiles.
Applying only the second, gcc3.2.2 crashes. So the first change
does the trick.
Thanks for identifying the problem!
