[GRASS5] Compile Grass 5 on Win 32
Hi John.
I upgraded from B20.1 to the new cygwin1.1.1 in order
to use the rsh for cvs access to the repository. So, your
system is different. The original zip file that I gave to
Markus was B20 but all recent builds use Cygnus1.1.1
Unless you upgrade, I cannot help you.
Thats unfortunate, as the 1.1.1 distribution GPF's all the time! Maybe I'd
better stick to binary distributions.
The memory leak may be because you have older b20.1
1998 tools with the latest cygwin1.dll. I would stick
with Mumit's cygwin1.dll from his gcc distribution if
you are using B20.1
OK.
Get the rpc library and include files off Corinna's
site for the Xdr.
ftp://ftp.franken.de/pub/win32/develop/gnuwin32/cygwin/porters/Vinschen_Cor
i
nna/B20/
The XDR problem turned out to be Gmakefiles which did not use the XDRLIB
macro.
See http://cygutils.netpedia.net/V1.1/ for ipc.
Yes, I use ansi TERM, too.
Unfortunately g.help is still hanging, presumably not a TERM problem then.
Thanks
Mike Thomas.
subject 'unsubscribe grass5'
Hi Mike,
For the non-U.S. citizens: What's GPF? :slight_smile:
macro.
Please tell me, which modules still require XDRLIB to be added.
Then I will fix asap.
Thanks
