Dear Markus,
I have finally manage to compile all the modules that come with
grass5.0.0pre1. There was only one left (src/raster/wildfire) but
I compiled it manually. The problem with this was that Gmake and
some other files (e.g. src) of this module did not exist.
The problem with the other modules (apart from my missing
libraries) that I could not compile was that there is a problem either
with my tar program or with grass5.0.0pre1.tar.gz file;
when I gunzip and untar the file tree directories are missing. These are
../src/sites
../src/scripts
src.contrib
I later obtained these from snap_shots source file on your server.
I have also made a test and compiled this version. It works.
I have one problem now; when I invoke nviz I get this error mesage
Mapset <PERMANENT> in Location <spearfish>
GRASS 5.0.0pre1 > nviz
/usr/local/grass5/bin/nviz: tclsh: not found
I would be happy if you could give some suggestions about this.
Ziya
____________________________________________________________
Ziyadin CAKIR Tel:++90 +212 2856320
Istanbul Technical University Fax:++90 +212 2856210
Mining Faculty, Geology Department Mail:cakirz@itu.edu.tr
Maslak/Istanbul/TURKEY
