Dear all,
While compiling grass 5.1 I get an error due to dependence on 'pos.h'. I use
grass 5.0 HEAD branch from CVS and do in "grass51":
$ CFLAGS="-g -Wall" ./configure --with-grass50=/home/Geo/GRASS/grass
$ make mix
$ make
I get this error:
make[2]: Leaving directory `/home/Geo/GRASS/grass51/lib/proj'
raster
make[2]: Entering directory `/home/Geo/GRASS/grass51/lib/raster'
make[2]: *** No rule to make target `pos.h', needed by
`OBJ.i686-pc-linux-gnu/Box.o'. Stop.
make[2]: Leaving directory `/home/Geo/GRASS/grass51/lib/raster'
Indeed 'pos.h' does not exist in home/Geo/GRASS/grass/src/libes/raster (where
the link points to). Moreover, from the Makefile I can't see why Box.o needs
pos.h ...
Any ideas?
Aleksey
On Tuesday 16 July 2002 07:19 pm, Aleksey Naumov wrote:
Dear all,
use grass 5.0 HEAD branch from CVS and do in "grass51":
$ make mix
$ make
I get this error:
raster
(where the link points to). Moreover, from the Makefile I can't see why
Box.o needs pos.h ...
Any ideas?
Aleksey
pos.h was removed from grass50. You had most probably run 'make mix'
before pos.h was removed. Try:
make mixclean
make mix
Radim
