[GRASS5] config error 'ar' on OS X
I am getting a configure error I don't recognize after cvs up today. The error refers to 'ar'. What is ar?
checking for ar... ar
./configure: line 2192: syntax error near unexpected token `<<<'
./configure: line 2192: `<<<<<<< configure'
Kirk
Kirk R. Wythers, Research Fellow
Dept. of Forest Resources
University of Minnesota
1530 Cleveland Ave N
Saint Paul, MN 55108
tel: 612.625.2261
email: kwythers@umn.edu
Kirk,
this looks like a CVS conflict in the file.
Did you run autoconf? You will have to check the output
of
cvs up configure
If unexpected, delete the file and fetch it again (all configure
changes should be generally made in configure.in, if this applies
here).
good luck
On Oct 7, 2005, at 4:08 PM, Markus Neteler wrote:
Kirk,
of
cvs up configure
here).
good luck
Thanks Markus, cvs up configure yields:
C configure
Are you suggesting that I delete the configure file, run autoconfig to re-crreate configure, then re-run cvs up -dP?
Kirk
> of
> cvs up configure
C configure
Just delete the configure file then run "cvs up -dP". If you run
autoconf yourself, you'll get a conflict.
Changes to configure.in can usually be merged automatically, but the
same doesn't apply to configure. Apart from anything else, any change
will throw off the line numbers.
