[GRASS5] configure again
i just updated the CVS (are the problems officially solved now?) and
tried to recompile on Linux (before i start compiling on
cygwin/Windows).
But i noticed that configure does not set the PostgreSQL and PNG paths
at all.
PQINCPATH, PQLIB, the PNG include and PNG lib lines are all empty in the
header file.
Therefore src.garden/grass.postgres and the PNGdriver are not compiled.
Nothing else changed since the last successful compilation of GRASS on
my system.
Before i delve into the details of configure, is this a known problem
and someone alreday working on it?
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
cygwin/Windows).
at all.
header file.
It's OK for "path" variables (e.g. PQINCPATH, PQLIBPATH) to be empty
if the corresponding header/library is in a standard directory (i.e.
can be found without any -L/-I switches).
However, the actual "lib" variables (e.g. PQLIB) generally need a
value. The absence of one indicates that "configure" failed to link a
test program. This can be because the library isn't present, or
because the compiler isn't looking in the right directory, or because
the library has a dependency which configure hasn't allowed for.
my system.
How long ago was that?
As of a couple of weeks ago, configure no longer adds -I or -L
switches of its own accord. Without arguments, headers/libraries will
only be found if they are in a directory which the compiler/linker
searches automatically.
You can force particular headers/libraries to be looked for in
particular directories using the --with-foo-includes= and
--with-foo-libs= switches, where foo is one of zlib, jpeg, tiff, png,
gd, tcltk, postgres, opengl, odbc, fftw, blas, lapack.
You can force directories to be searched for all headers/libraries
using the --with-includes= and --with-libs= switches.
