[GRASS5] configure and freetype2
Hi again,
yesterday I tried to compile the d.text.freetype but the
configure refuses to recognize the library. I used:
./configure --with-freetype
--with-freetype-includes=/usr/include/freetype2 [...]
but:
checking whether to use FreeType... no
checking whether to build FreeType programs... no
configure --help |grep freetype
  --with-freetype support FreeType functionality (default: no)
  --with-freetype-includes=DIRS
  --with-freetype-libs=DIRS
Inside /usr/include/freetype2 is another freetype/ directory including the
header file.
Any hints for me?
but:
Very odd. This check is simply detects whether --with-freetype was
used.
On Sun, Jan 13, 2002 at 11:41:38PM +0900, GRASS wrote:
Hi Markus,
configure tries to find ft2build.h and this file includes
.../freetype2/freetype/config/ftheader.h. In my case, ft2build.h is located
in /usr/local/include and other freetype header files are in
/usr/local/include/freetype2.
So check whether there is ft2build.h in /usr/include and use
--with-freetype-includes=/usr/include.
Hope this helps,
Huidae Cho
Hi Huidae and Glynn,
the suggestion by Huidae doesn't help because:
remains. In fact strange...
