Hi Eric
"Eric G . Miller" wrote:
On Tue, Nov 28, 2000 at 04:26:38PM +0700, Justin Hickey wrote:
Well here's my understanding:
foo=${bar} # Perform variable expansion on "bar", put result in foo.
foo=$(bar) # Execute "bar" in a subshell, put result in foo.
The $(cmd) syntax is supposed to be the portable equivalent of `cmd`,
only special characters $ \ and * (I think) are not treated as
"metacharacters".
This $(...) syntax is different from Makefile $(...) which apparently
is variable substitution/expansion.
Ahh, OK, I went looking into why this doesn't seem to work for SGI and
found on the man page for sh the following:
Command Substitution
The standard output from a command enclosed in parentheses preceded by a
dollar sign ( $() ) or a pair of grave accents (``) may be used as part
or all of a word; trailing newlines are removed.
Obviously it is supposed to work on SGI's, they even claim the (``)
style to be archaic. However the following script
#!/bin/sh
qwer=$(pwd)
asdf=`pwd`
echo $qwer
echo $asdf
Produces the following output
$(pwd)
/usr/people/jhickey/testDir/sh
Thus, it obviously does not work on SGI as it is supposed to. I am due
for an OS upgrade soon, so if this problem is not solved with the
upgrade, I will try to submit a bug report to SGI.
In the meantime, would it be safe to change the SRCDIR code in
configure.in to `pwd` instead of $(pwd)? Perhaps we can add a comment to
change it back to $(pwd) when SGI fixes this bug. Just an idea.
BTW, do you want me to submit the bindir change or do you want to? I
didn't change it yesterday because I didn't have time to test --bindir
and --with-bindir. I tested them today and --bindir seems to work, but
--with-bindir does not, but then I can't find --with-bindir in the
configure.in file. Please let me know what you want to do.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
subject 'unsubscribe grass5'
