On Tue, Nov 28, 2000 at 05:33:33PM +0700, Justin Hickey wrote:
Hi Eric
"Eric G . Miller" wrote:
> Well, the problem really seems to be with the way configure handles
> $bindir. It is always set to something (at least here). Also, my
> autoconf choked on the AC_BINDIR_DEFAULT() macro (claiming no such
> thing exists). $bindir is always apparently set to
> ${exec_prefix}/bin, and ${exec_prefix} is always set to ${prefix}
> (these are defaults). So I can't figure out how to have the --bindir
> command work, but use the /usr/local/bin as a default. Piece of cake
> if I ignore --bindir and go back to using --with-bindir (as it was
> set-up before).
Good news!!! I found the error with the BINDIR stuff in configure.in.
The problem was that the test for $exec_prefix was testing if the
variable existed. Apparently autoconf defines it as NONE. So the test
needs to compare with NONE. I changed the line from:
if test -z "${exec_prefix}"; then
to the following:
if test "${exec_prefix}" = "NONE"; then
And now the following appears in my Makefile after running configure
prefix= /usr/local/grass5
exec_prefix= /usr/local
BINDIR= ${exec_prefix}/bin
I didn't test anything else though (--bindir or --with-bindir)
Hi Justin,
it seems not to help on Linux
But I'll wait for the reply from
Eric (using Linux, too).
> As far as the headers and libraries, does it work with the
> --with-tcltk-includes=[DIRs] --with-tcltk-libs=[DIRS] ?
It almost works. I get the following using those two options:
checking for /usr/include/tk.h... no
checking for /usr/include/tcl.h... no
checking TK include dirs... -I/usr/local/include
checking TCL include dirs... -I/usr/local/include
checking additional TCL and TK library dirs... -L/usr/local/lib
checking for Tk_MainWindow in -ltk$(grep #define TCL_VERSION
/usr/local/include/tcl.h | sed -e s/^\(.*\)\"\(.*\)\"$/\2/)...
./configure[3482]: no space
I don't know what is happening here but before it printed the error, it
paused for a while if that means anything.
A similar crash occurs on Solaris and CRAY.
I have used the configure build on Linux (as no autoconf is on "my"
CRAY and Solaris):
Solaris:
./configure: syntax error at line 3353: 'tcltk_ver=$' unexpected
CRAY:
configure: warning: *** Didn't find tk.h, maybe okay...
configure: warning: *** Didn't find tcl.h, maybe okay...
configure: warning: *** Unable to find TCL/TK libraries and headers
checking libpq-fe.h...
configure: warning: *** libpq-fe.h not found, but needed for PostgreSQL
support
checking libpq paths... -L/usr/lib -L/usr/local/lib
checking for PQcmdTuples in -lpq... (cached) no
checking GL/gl.h and GL/GLwMDrawA.h... configure: error: *** Didn't find
GL/GLwMDrawA.h
t3e:grass:531$
-> so on CRAY the GL/gl.h and GL/GLwMDrawA.h test break the script.
Eric, please remove the "exit"s from these lines:
Row 3870, Row 3873 (configure)
diff configure configure.org
3870c3870
< { echo "configure: error: *** Didn't find GL/gl.h" 1>&2; }
{ echo "configure: error: *** Didn't find GL/gl.h" 1>&2; exit 1; }
3873c3873
< { echo "configure: error: *** Didn't find GL/GLwMDrawA.h" 1>&2; }
{ echo "configure: error: *** Didn't find GL/GLwMDrawA.h" 1>&2; exit 1; }
This will be the same issue as the complaint from Bernhard (when he
--asked for a disable-opengl).
subject 'unsubscribe grass5'
