if anyone has a hint for me - I tested the current
configure on SUN/solaris 2.6, it fails to detect
the libGL (although present). Some lib is missing for
the text, see attachement. Might be trivial, but
I need a hint what to add,
thanks
(attachments)
config.gl_log (8.7 KB)
Somehow the right X11 libs are needed and missing.
(Usually it should be tested before the GL support or you might need
to speficy extra xlibs....)
configure:6009: checking for glBegin in -lGL
configure:6028: gcc -o conftest -g -O2 -L/usr/lib conftest.c -lGL -L/usr/openwin/lib -R/usr/openwin/lib -lm 1>&5
Undefined first referenced
symbol in file
XSynchronize /usr/lib/libGL.so
XShmPutImage /usr/lib/libGL.so
XDrawPoint /usr/lib/libGL.so
XFreeColors /usr/lib/libGL.so
XFreePixmap /usr/lib/libGL.so
XQueryColors /usr/lib/libGL.so
XShmQueryVersion /usr/lib/libGL.so
XCreateImage /usr/lib/libGL.so
I've committed a fix to configure[.in].
Thanks Glynn! (Just found out that -X11 was needed :-).
So: the updated NVIZ also runs on SUN/Solaris - of course without DRI.
(using the old tcl/tk8.0.4, I have added related stuff to togl.c).
I have also tested on a non-DRI Xfree4.0.3 Linux, NVIZ is also running.
