[GRASS5] configure on systems other than linux
Hi again,
sorry to insist again, but configure does not work for me.
I just tested on Solaris 7 / SPARC and despite installing fftw-2.1.3,
jpeg6b, png, gd-1.8.4, tcl/tk 8.2 and mesa (in /usr/local/lib|include,
adding --with-libs=/usr/local/lib and --with-includes=/usr/local/include
to
./configure), all these libraries are not found.
If i put all libraries on the command line:
export
PATH=$PATH/export/home/andreas/bin:/usr/dt/bin:/usr/openwin/bin:/bin:/usr
/bin:/opt/Summertime_98.sparc/bin:/opt/sfw/bin:/usr/sbin:/usr/xpg4/bin:/usr/local/bin
./configure \
--prefix=/export/home/andreas \
--enable-postgres=no \
--enable-opengl \
--with-libes=/usr/local/include \
--with-includes=/usr/local/include \
--with-tcltk-libs=/usr/local/lib \
--with-tcltk-includes=/usr/local/include \
--with-zlib-libs=/usr/local/lib \
--with-zlib-includes=/usr/local/include \
--with-tiff-libs=/usr/local/lib \
--with-tiff-includes=/usr/local/include \
--with-opengl-libs=/usr/local/lib \
--with-opengl-includes=/usr/local/include \
--with-fftw-libs=/usr/local/lib \
--with-fftw-includes=/usr/local/include
most of the libraries are found.
I think the reason is that the dependencies are different on each
system, e.
g. libgd needs -lgd -lpng -ljpeg -lz -lm on Solaris to link, but
configure
just uses -lgd -lpng. But why are the libraries found if specified on
the command line? I am clueless.
On cygwin this is similar, but just more weird.
I can compile a test stub program with:
gcc test-gd.c -lgd -lpng -ljpeg -lz -lm
while:
gcc -lgd -lpng -ljpeg -lz -lm test-gd.c
miserably fails.
But configure just does not find the library, even if i build gd2
without
jpeg. I tried to implement the library checking the same way the tiff
lib is
checked, but i got stuck with all those nested .
I have access to machines with Solaris 7/SPARC, Solaris 7/x86, IRIX 6.5,
Linux, FreeBSD 4.3 (Intel/Alpha) and cygwin. I volunteer to check, but
first
we should fix configure.in/configure for the known dependencies.
I am waiting for your suggestions...
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
Nothing to be sorry about :wink:
The nature of autoconf is such that you need to know what tests you
should be performing, and the only way to determine that is by trial
and error.
[Aside: Imake is a better idea in principle, but sucks in practice.]
to
export
./configure \
--enable-opengl \
This should be --with-libs (no "e"). And it should be .../lib, not
.../include.
Odd. The values passed to --with-libs and --with-includes are used to
set LDFLAGS and CPPFLAGS respectively, so they should be used for all
subsequent library/header tests.
system, e.g. libgd needs -lgd -lpng -ljpeg -lz -lm on Solaris to link, but
configure
Actually, configure tries:
  -lgd
  -lgd $PNGLIB
  -lgd $JPEGLIBPATH $JPEGLIB
  -lgd $JPEGLIBPATH $JPEGLIB $PNGLIB
stopping at the first one which succeeds.
Note that $PNGLIB and $JPEGLIB may include additional -l and/or -L
switches for any detected dependencies. JPEGLIB is tried with $ZLIB if
it isn't detected without it. PNGLIB is always tried with $ZLIB and
$MATHLIB.
Note: if a shared library has dependency information, you can link
against it without specifying the dependencies. That would explain why
configure doesn't detect all of the dependencies (it stops trying once
it finds a combination which works), but not why you have to specify
each directory individually.
while:
miserably fails.
That makes sense if one or more of the libraries is static.
When linking against static libraries, only object files which define
*existing* unresolved symbols are linked in. Subsequent libraries may
introduce further unresolved symbols which would have been satisfied
by the original library had the order been reversed.
without
lib is
first
I really need to see the resulting config.log file in order to
determine what went wrong (also, the output from configure can
sometimes be useful).
